8.2
lagran.f90 File Reference
Module for Lagrangian model. More...
Data Types
interface  cs_f_lagr_dim_pointers
interface  cs_f_lagr_params_pointers
interface  cs_f_lagr_source_terms_pointers
interface  cs_lagr_map_specific_physics
interface  cs_lagr_options_definition
 Execute one time step of the Lagrangian model. More...
interface  cs_lagr_precipitation_mass_st
 Mass source term due to precipitation. More...
interface  cs_lagr_solve_initialize
 Prepare for execution of the Lagrangian model. More...
interface  cs_lagr_solve_time_step
interface  cs_lagr_init_arrays
 Allocate source term arrays. More...
interface  cs_lagr_init_par
interface  lagr_restart_write_particle_data
 Write particle data to checkpoint. More...
Modules
module  lagran
Functions/Subroutines
subroutine lagran_pointers ()
subroutine init_lagr_dim_pointers ()
subroutine lagran_init_map
integer(c_int), pointer, save iilagr
  activates (>0) or deactivates (=0) the Lagrangian module the different values correspond to the following modellings: More...
integer(c_int), pointer, save ntersl
  More...
double precision, dimension(:,:), pointer, save ptsvar
  More...
integer(c_int), pointer, save idepst
integer(c_int), pointer, save iflow
integer(c_int), pointer, save ipreci
integer(c_int), pointer, save ltsdyn
 activation (=1) or not (=0) of the two-way coupling on the dynamics of the continuous phase. Useful if iilagr = 2 and iccvfg = 0 More...
integer(c_int), pointer, save ltsmas
 activation (=1) or not (=0) of the two-way coupling on the mass. Useful if iilagr = 2, cs_lagr_model_t::physical_model = 1 and cs_lagr_specific_physics_t::impvar = 1 More...
integer(c_int), pointer, save ltsthe
 if cs_lagr_model_t::physical_model = 1 and cs_lagr_specific_physics_t::itpvar = 1, ltsthe !> activates (=1) or not (=0) the two-way coupling on temperature. if cs_lagr_model_t::physical_model = 2, ltsthe activates (=1) or not (=0) the two-way coupling on the eulerian variables related to pulverized coal combustion. Useful if iilagr = 2 More...
integer(c_int), pointer, save itsli
 implicit source term for the continuous phase velocity and for the turbulent energy if the $k-\varepsilon$ model is used More...
integer(c_int), pointer, save itske
 explicit source term for the turbulent dissipation and the turbulent energy if the $k-\varepsilon$ turbulence model is used for the continuous phase More...
integer(c_int), pointer, save itste
 explicit thermal source term for the thermal scalar of the continuous phase More...
integer(c_int), pointer, save itsti
 implicit thermal source term for the thermal scalar of the continuous phase More...
integer(c_int), pointer, save itsmas
 mass source term More...
