8.2
cs_lagr_model_t Struct Reference
#include <cs_lagr.h>
+ Collaboration diagram for cs_lagr_model_t:
Data Fields
int physical_model
int n_temperature_layers
int modcpl
int idistu
int idiffl
int deposition
int dlvo
int roughness
int resuspension
int clogging
int shape
int consolidation
int precipitation
int fouling
int agglomeration
int fragmentation
int n_stat_classes
int n_user_variables
bool viscous_terms
Main physical model parameters for the Lagrangian module
Field Documentation
◆ agglomeration
int agglomeration
  • 0: no agglomeration model
  • 1: agglomeration model used
◆ clogging
int clogging
  • 0: no clogging model
  • 1: clogging model
◆ consolidation
int consolidation
  • 0: no consolidation model
  • 1: consolidation model
◆ deposition
int deposition
  • 0: no deposition model
  • 1: depositionion model
◆ dlvo
int dlvo
◆ fouling
int fouling
◆ fragmentation
int fragmentation
  • 0: no fragmentation model
  • 1: fragmentation model used
◆ idiffl
int idiffl
Suppress the crossing trajectory effect (if set to 1), making turbulent dispersion for the particles identical to the turbulent diffusion of fluid particles. Default is off if modcpl = 1, on if modcpl = 0).
◆ idistu
int idistu
Activation of the turbulent dispersion (on: 1; off). Default is on; This is compatible with RANS and LES turbulent models ( $k-\varepsilon$, $R_{ij}-\varepsilon$, v2f or $k-\omega$).
◆ modcpl
int modcpl
Activates (1) or not (0) the assumption that we have regular particles. When set to, 0 then the particles are assumed to be fluid particles (and only the turbulence dispersion model is taken into account by default, but not crossing trajectory effects). Since this model uses volume statistics, is use forces their activation even if not otherwise requested (see idstnt).
◆ n_stat_classes
int n_stat_classes
◆ n_temperature_layers
◆ n_user_variables
◆ physical_model
int physical_model
activates (>0) or deactivates (=0) the physical models associated to the particles:
  • CS_LAGR_PHYS_HEAT: allows to associate with the particles evolution equations on their temperature (in degrees Celsius), their diameter and their mass
  • CS_LAGR_PHYS_COAL: the particles are pulverised coal particles. Evolution equations on temperature (in degree Celsius), mass of reactive coal, mass of char and diameter of the shrinking core are associated with the particles. This option is available only if the continuous phase represents a pulverised coal flame.
  • CS_LAGR_PHYS_CTWR: cooling tower model in the context of an Lagrangian formulation.
◆ precipitation
int precipitation
◆ resuspension
int resuspension
  • 0: no resuspension model
  • 1: resuspension model
◆ roughness
int roughness
  • 0: no DLVO conditions with roughness surface
  • 1: DLVO conditions with roughness surface
◆ shape
int shape
  • 0: spherical particles (default)
  • 1: spheroid particles
  • 2: ellipsoids
◆ viscous_terms
bool viscous_terms
Take viscous terms into account
