◆ cs_turbulence_ke()
Solve the k-epsilon equations.
Solve the
for incompressible flows or slightly compressible flows for one time step.
- Parameters
| [in] | phase_id | turbulent phase id (-1 for single phase flow) |
| [in] | itypsm | mass source type for the variables size: [nvar][ncesmp] |
| [in] | smacel | values of the variables associated to the mass source (for the pressure variable, smacel is the mass flux) size: [nvar][ncesmp] |
| [out] | prdv2f | v2f production term |
◆ cs_turbulence_ke_clip()
| void cs_turbulence_ke_clip |
int |
phase_id, |
cs_lnum_t |
n_cells, |
int |
iclip |
Clipping of the turbulent kinetic energy and turbulent dissipation.
- Parameters
| [in] | iclip | indicator = 0 if viscl0 is used otherwise viscl is used. |
◆ cs_turbulence_ke_mu_t()
| void cs_turbulence_ke_mu_t |
int |
phase_id | ) |
Calculation of turbulent viscosity for the K-epsilon model.
- Parameters
◆ cs_turbulence_ke_q()
| void cs_turbulence_ke_q |
int |
phase_id, |
cs_real_6_t |
rij[] |
Calculation of non linear terms of the quadratic k-epsilon model (Baglietto et al.)
- Parameters
| [out] | rij | non linear terms of quadratic Boussinesq approximation |
◆ cs_turbulence_ke_q_mu_t()
| void cs_turbulence_ke_q_mu_t |
int |
phase_id | ) |
Calculation of turbulent viscosity for the non-linear quadratic K-epsilon from Baglietto et al. (2005)
- Parameters
