Include dependency graph for cs_post_util.h:Go to the source code of this file.
| void | cs_cell_segment_intersect_select (void *input, cs_lnum_t *n_cells, cs_lnum_t **cell_ids) |
| Select cells cut by a given segment. More... | |
| void | cs_cell_polyline_intersect_select (void *input, cs_lnum_t n_points, cs_lnum_t *n_cells, cs_lnum_t **cell_ids, cs_real_t **seg_c_len, cs_real_3_t **seg_c_cen) |
| Select cells cut by a line composed of segments. More... | |
| void | cs_cell_segment_intersect_probes_define (void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s) |
| Define probes based on the centers of cells intersected by a given segment. More... | |
| void | cs_b_face_criterion_probes_define (void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s) |
| Define a profile based on centers of faces defined by a given criterion. More... | |
| cs_real_t | cs_post_turbomachinery_head (const char *criteria_in, cs_mesh_location_type_t location_in, const char *criteria_out, cs_mesh_location_type_t location_out) |
| Compute the head of a turbomachinery (total pressure increase) More... | |
| cs_real_t | cs_post_moment_of_force (cs_lnum_t n_b_faces, const cs_lnum_t b_face_ids[], cs_real_t axis[3]) |
| Compute the magnitude of a moment of force torque) given an axis and the stress on a specific boundary. More... | |
| void | cs_post_stress_tangential (cs_lnum_t n_b_faces, const cs_lnum_t b_face_ids[], cs_real_3_t stress[]) |
| Compute tangential stress on a specific boundary. More... | |
| void | cs_post_b_pressure (cs_lnum_t n_b_faces, const cs_lnum_t b_face_ids[], cs_real_t pres[]) |
| Compute pressure on a specific boundary region. More... | |
| void | cs_post_b_total_pressure (cs_lnum_t n_b_faces, const cs_lnum_t b_face_ids[], cs_real_t pres[]) |
| Compute total pressure on a specific boundary region. More... | |
| void | cs_post_evm_reynolds_stresses (cs_field_interpolate_t interpolation_type, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_3_t *coords, cs_real_6_t *rst) |
| Compute Reynolds stresses in case of Eddy Viscosity Models. More... | |
| void | cs_post_anisotropy_invariant (cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_t coords[][3], cs_real_t inv[][2]) |
| Compute the invariant of the anisotropy tensor. More... | |
| void | cs_post_boundary_flux (const char *scalar_name, cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[], cs_real_t b_face_flux[]) |
| Compute scalar flux on a specific boundary region. More... | |
| void | cs_post_field_cell_to_b_face_values (const cs_field_t *f, cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[], cs_real_t *b_val) |
| Compute values at a selection of boundary faces of a given field located on cells. More... | |
| cs_real_t | cs_post_scalar_boundary_integral (const cs_real_t *scalar_vals, const cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[]) |
| Compute the surface integral of a scalar array of values located on boundary faces over a selection of boundary faces. More... | |
| cs_real_t | cs_post_bnd_scalar_boundary_integral (const cs_real_t *scalar_vals, const cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[]) |
| Compute the surface integral over a selection of boundary faces for a scalar array of values located over the selection. More... | |
| cs_real_t | cs_post_scalar_boundary_mean (const cs_real_t *scalar_vals, const cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[]) |
| Compute the surface mean of a scalar array of values located on boundary faces over a selection of boundary faces. Weighting is done using total surface of boundary faces. More... | |
| cs_real_t | cs_post_bnd_scalar_boundary_mean (const cs_real_t *scalar_vals, const cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[]) |
| Compute the surface mean over a selection of boundary faces for a scalar array of values located over the selection. Weighting is done using total surface of boundary faces. More... | |
| cs_real_t | cs_post_scalar_b_zone_integral (const cs_zone_t *z, const cs_real_t *scalar_vals) |
| Compute the surface integral of a scalar array of values located on boundary faces over a boundary zone. More... | |
| cs_real_t | cs_post_bnd_scalar_b_zone_integral (const cs_zone_t *z, const cs_real_t *scalar_vals) |
| Compute the surface integral of a scalar over a boundary zone faces, for an array of values located on the zone's faces. More... | |
| cs_real_t | cs_post_scalar_b_zone_mean (const cs_zone_t *z, const cs_real_t *scalar_vals) |
| Compute the surface mean of a scalar array of values located on boundary faces over a boundary zone. Weighting is done using total surface of boundary faces. More... | |
| cs_real_t | cs_post_bnd_scalar_b_zone_mean (const cs_zone_t *z, const cs_real_t *scalar_vals) |
| Compute the surface mean of a scalar over a boundary zone faces, for an array of values located on the zone's faces. Weighting is done using total surface of boundary faces. More... | |
| void cs_b_face_criterion_probes_define | ( | void * | input, |
| cs_lnum_t * | n_elts, | ||
| cs_real_3_t ** | coords, | ||
| cs_real_t ** | s | ||
Here, the input points to string describing a selection criterion.
| [in] | input | pointer to selection criterion |
| [out] | n_elts | number of selected coordinates |
| [out] | coords | coordinates of selected elements. |
| [out] | s | curvilinear coordinates of selected elements |
| void cs_cell_polyline_intersect_select | ( | void * | input, |
| cs_lnum_t | n_points, | ||
| cs_lnum_t * | n_cells, | ||
| cs_lnum_t ** | cell_ids, | ||
| cs_real_t ** | seg_c_len, | ||
| cs_real_3_t ** | seg_c_cen | ||
This selection function may be used as an elements selection function for postprocessing.
In this case, the input points to a real array containing the segment's start and end coordinates.
Note: the input pointer must point to valid data when this selection function is called, so either:
The caller is responsible for freeing the returned cell_ids array. When passed to postprocessing mesh or probe set definition functions, this is handled automatically.
| [in] | input | pointer to segments starts and ends: [x0, y0, z0, x1, y1, z1] |
| [in] | n_points | number of vertices in the polyline |
| [out] | n_cells | number of selected cells |
| [out] | cell_ids | array of selected cell ids (0 to n-1 numbering) |
| [out] | seg_c_len | array of length of the segment in the selected cells |
| [out] | seg_c_cen | array of center coordinates of the segment in the selected cells |
| void cs_cell_segment_intersect_probes_define | ( | void * | input, |
This selection function may be used as a probe set definition function for postprocessing.
| [in] | input | pointer to segment start and end: [x0, y0, z0, x1, y1, z1] |
| void cs_post_anisotropy_invariant | ( | cs_lnum_t | n_cells, |
| const cs_real_t | coords[][3], | ||
| cs_real_t | inv[][2] | ||
| [in] | n_cells | number of points |
| [in] | cell_ids | cell location of points (indexed from 0 to n-1) |
| [in] | coords | point coordinates |
| [out] | inv | Anisotropy tensor invariant [xsi, eta] |
| [in] | n_b_faces | number of faces |
| [in] | b_face_ids | list of faces (0 to n-1) |
| [out] | pres | pressure on a specific boundary region |
| void cs_post_b_total_pressure | ( | cs_lnum_t | n_b_faces, |
| cs_real_t | pres[] | ||
| [out] | pres | total pressure on a specific boundary region |
| [in] | z | pointer to boundary zone |
| [in] | scalar_vals | array of scalar values of size n_b_faces |
| cs_real_t cs_post_bnd_scalar_boundary_integral | ( | const cs_real_t * | scalar_vals, |
| const cs_lnum_t | n_loc_b_faces, | ||
| const cs_lnum_t | b_face_ids[] | ||
| [in] | n_loc_b_faces | number of selected boundary faces |
| [in] | b_face_ids | ids of selected boundary faces |
| cs_real_t cs_post_bnd_scalar_boundary_mean | ( | const cs_real_t * | scalar_vals, |
| void cs_post_boundary_flux | ( | const char * | scalar_name, |
| cs_real_t | b_face_flux[] | ||
The flux is counted negatively through the normal.
| [in] | scalar_name | scalar name |
| [out] | b_face_flux | surface flux through selected faces |
| void cs_post_evm_reynolds_stresses | ( | cs_field_interpolate_t | interpolation_type, |
| cs_lnum_t | n_cells, | ||
| const cs_real_3_t * | coords, | ||
| cs_real_6_t * | rst | ||
| [in] | interpolation_type | interpolation type for turbulent kinetic energy field |
| [in] | cell_ids | cell location of points (indexed from 0 to n-1, or NULL if 1-to-1) |
| [in] | coords | point coordinates (or NULL for cell centers) |
| [out] | rst | Reynolds stresses stored as vector [r11, r22, r33, r12, r23, r13] |
| void cs_post_field_cell_to_b_face_values | ( | const cs_field_t * | f, |
| cs_real_t * | b_val | ||
Field BCs are taken into account and boundary cell values are reconstructed using the cell gradient.
| [in] | f | field pointer |
| [out] | b_val | values on boundary faces |
| cs_real_t cs_post_moment_of_force | ( | cs_lnum_t | n_b_faces, |
| cs_real_t | axis[3] | ||
| [in] | axis | axis |
| cs_real_t cs_post_scalar_boundary_integral | ( | const cs_real_t * | scalar_vals, |
| cs_real_t cs_post_scalar_boundary_mean | ( | const cs_real_t * | scalar_vals, |
| void cs_post_stress_tangential | ( | cs_lnum_t | n_b_faces, |
| cs_real_3_t | stress[] | ||
| [out] | stress | tangential stress on the specific boundary |
| cs_real_t cs_post_turbomachinery_head | ( | const char * | criteria_in, |
| cs_mesh_location_type_t | location_in, | ||
| const char * | criteria_out, | ||
| cs_mesh_location_type_t | location_out | ||
| [in] | criteria_in | selection criteria of turbomachinery suction |
| [in] | location_in | mesh location of turbomachinery suction |
| [in] | criteria_out | selection criteria of turbomachinery discharge |
| [in] | location_out | mesh location of turbomachinery discharge |
