8.2
cs_nz_tagmr.f90 File Reference
Module for parameters options, numerical and physical properties of the thermal 1D model for each specific zone with condensation on the wall. The zones number is defined by the user with the subroutine : cs_user_wall_condensation. More...
Data Types
interface  cs_f_wall_condensation_1d_thermal_get_pointers
interface  cs_f_wall_condensation_1d_thermal_get_mesh_pointers
interface  cs_f_wall_condensation_1d_thermal_create
interface  cs_f_wall_condensation_0d_thermal_create
interface  cs_f_wall_condensation_1d_thermal_mesh_create
interface  cs_f_wall_condensation_0d_thermal_get_pointers
interface  cs_f_wall_condensation_0d_thermal_solve
Modules
module  cs_nz_tagmr
Functions/Subroutines
subroutine init_nz_tagmr
subroutine init_nz_mesh_tagmr
subroutine finalize_nz_mesh_tagmr
integer(c_int), pointer, save znmurx
  Maximal number of discretized points associated to the (ii)th face with the 1-D thermal model coupled with condensation More...
integer, dimension(:), pointer, save znmur
double precision, dimension(:,:), pointer, save zdxp
  space step associated to the spatial discretization of the 1-D thermal model coupled with condensation model More...
double precision, dimension(:), pointer, save ztheta
 of the 1-D thermal model More...
double precision, dimension(:), pointer, save zdxmin
  the minimal space step of 1-D thermal model by default equal to 0 with a homogeneus space step. this numerical parameter is used to impose a geometric progression ratio of the mesh refinement associated to (ii)th face with the 1-D thermal model. More...
double precision, dimension(:), pointer, save zepais
  the wall thickness associated to the (ii)th face with 1-D thermal module More...
double precision, dimension(:), pointer, save zrob
  the concrete density associated to solid material More...
double precision, dimension(:), pointer, save zcondb
  the concrete conductivity coefficient associated to solid material More...
double precision, dimension(:), pointer, save zcpb
  the concrete specific heat coefficient associated to solid material More...
double precision, dimension(:), pointer, save zhext
  the exterior exchange coefficient associated to solid material More...
double precision, dimension(:), pointer, save ztext
  the exterior temperature associated to solid material More...
double precision, dimension(:), pointer, save ztpar0
  the initial temperature associated to solid material More...
double precision, dimension(:,:), pointer, save ztmur
  the wall temperature computed with the 1-D thermal model associated to concrete solid material More...
double precision, dimension(:), pointer, save xem
  the wall thickness of the metal mass structures used by the 0-D thermal model More...
double precision, dimension(:), pointer, save xro_m
  the density (kg.m-3) of the metal mass structures More...
double precision, dimension(:), pointer, save xcond_m
  the conductivity coefficient (W.m-1.C-1) of the metal mass structures More...
double precision, dimension(:), pointer, save xcp_m
  the specific heat coefficient (J.kg-1.C-1) of the metal mass structures More...
double precision, dimension(:), pointer, save m_metal
  the metal mass (kg) of the metal mass structures More...
double precision, dimension(:), pointer, save s_metal
  the exchange surface (m2) of the metal mass structures More...
double precision, dimension(:), pointer, save v_metal
  the volume mesaure (m3) of the metal mass structures More...
double precision, dimension(:), pointer, save tmet0
  the initial temperature of the metal mass structures More...
double precision, dimension(:,:), pointer, save t_metal
  the wall temperature computed with the 0-D thermal model associated to the metal mass structure material More...
