8.2
cs_nz_tagmr Module Reference
Data Types
interface  cs_f_wall_condensation_1d_thermal_get_pointers
interface  cs_f_wall_condensation_1d_thermal_get_mesh_pointers
interface  cs_f_wall_condensation_1d_thermal_create
interface  cs_f_wall_condensation_0d_thermal_create
interface  cs_f_wall_condensation_1d_thermal_mesh_create
interface  cs_f_wall_condensation_0d_thermal_get_pointers
interface  cs_f_wall_condensation_0d_thermal_solve
Functions/Subroutines
subroutine init_nz_tagmr
subroutine init_nz_mesh_tagmr
subroutine finalize_nz_mesh_tagmr
integer(c_int), pointer, save znmurx
  Maximal number of discretized points associated to the (ii)th face with the 1-D thermal model coupled with condensation More...
integer, dimension(:), pointer, save znmur
double precision, dimension(:,:), pointer, save zdxp
  space step associated to the spatial discretization of the 1-D thermal model coupled with condensation model More...
double precision, dimension(:), pointer, save ztheta
 of the 1-D thermal model More...
double precision, dimension(:), pointer, save zdxmin
  the minimal space step of 1-D thermal model by default equal to 0 with a homogeneus space step. this numerical parameter is used to impose a geometric progression ratio of the mesh refinement associated to (ii)th face with the 1-D thermal model. More...
double precision, dimension(:), pointer, save zepais
  the wall thickness associated to the (ii)th face with 1-D thermal module More...
double precision, dimension(:), pointer, save zrob
  the concrete density associated to solid material More...
double precision, dimension(:), pointer, save zcondb
  the concrete conductivity coefficient associated to solid material More...
double precision, dimension(:), pointer, save zcpb
  the concrete specific heat coefficient associated to solid material More...
double precision, dimension(:), pointer, save zhext
  the exterior exchange coefficient associated to solid material More...
double precision, dimension(:), pointer, save ztext
  the exterior temperature associated to solid material More...
double precision, dimension(:), pointer, save ztpar0
  the initial temperature associated to solid material More...
double precision, dimension(:,:), pointer, save ztmur
  the wall temperature computed with the 1-D thermal model associated to concrete solid material More...
double precision, dimension(:), pointer, save xem
  the wall thickness of the metal mass structures used by the 0-D thermal model More...
double precision, dimension(:), pointer, save xro_m
  the density (kg.m-3) of the metal mass structures More...
double precision, dimension(:), pointer, save xcond_m
  the conductivity coefficient (W.m-1.C-1) of the metal mass structures More...
double precision, dimension(:), pointer, save xcp_m
  the specific heat coefficient (J.kg-1.C-1) of the metal mass structures More...
double precision, dimension(:), pointer, save m_metal
  the metal mass (kg) of the metal mass structures More...
double precision, dimension(:), pointer, save s_metal
  the exchange surface (m2) of the metal mass structures More...
double precision, dimension(:), pointer, save v_metal
  the volume mesaure (m3) of the metal mass structures More...
double precision, dimension(:), pointer, save tmet0
  the initial temperature of the metal mass structures More...
double precision, dimension(:,:), pointer, save t_metal
  the wall temperature computed with the 0-D thermal model associated to the metal mass structure material More...
◆ finalize_nz_mesh_tagmr()
subroutine cs_nz_tagmr::finalize_nz_mesh_tagmr
◆ init_nz_mesh_tagmr()
subroutine cs_nz_tagmr::init_nz_mesh_tagmr
◆ init_nz_tagmr()
subroutine cs_nz_tagmr::init_nz_tagmr
