| int | cs_mesh_cartesian_get_number_of_meshes (void) |
| | Return number of structured meshes to build. More...
| cs_mesh_cartesian_params_t * | cs_mesh_cartesian_by_id (const int id) |
| | Return pointer to cartesian mesh parameters structure. More...
| cs_mesh_cartesian_params_t * | cs_mesh_cartesian_by_name_try (const char *name) |
| | Get function for structured mesh based on its name. More...
| cs_mesh_cartesian_params_t * | cs_mesh_cartesian_by_name (const char *name) |
| cs_mesh_cartesian_params_t * | cs_mesh_cartesian_create (const char *name) |
| | Create cartesian mesh structure. More...
| int | cs_mesh_cartesian_define_simple (const char *name, int ncells[3], cs_real_t xyz[6]) |
| | Define a simple cartesian mesh with a constant step in all directions. More...
| void | cs_mesh_cartesian_define_dir_user (cs_mesh_cartesian_params_t *mp, int idir, int ncells, cs_real_t vtx_coord[]) |
| | Define directions parameters based on a user input. More...
| void | cs_mesh_cartesian_define_dir_geom_by_part (cs_mesh_cartesian_params_t *mp, int idir, int n_parts, const cs_real_t part_coords[], const cs_lnum_t n_part_cells[], const cs_real_t amp_factors[]) |
| | Define direction parameters based on a piecewise definition. Each part follows a geometric (or uniform) sequence. To get the uniform sequence, set the amplification factor to 1 in the wanted part. More...
| void | cs_mesh_cartesian_define_from_csv (const char *name, const char *csv_file_name) |
| | Define a simple cartesian mesh based on a CSV file. CSV file needs to contain : (1) First line which is empty or contains a header (2) Second line containing number of vertices per direction: format is 'nx;ny;nz' (3) Third line is empty or contains a header (4) Fourth line and onwards contains vertices coordinates for each direction. Format is "X1[i];X2[i];X3[i]" for index i. If current vertex index is beyond max value for a given direction, an empty value is expected. For example, if for index 'j' the first direction is empty, format is : ';X2[j];X3[j]'. More...
| void | cs_mesh_cartesian_define_dir_params (cs_mesh_cartesian_params_t *mp, int idim, cs_mesh_cartesian_law_t law, int ncells, cs_real_t smin, cs_real_t smax, cs_real_t progression) |
| | Define parameters for a given direction. More...
| int | cs_mesh_cartesian_need_build (void) |
| | Indicate if a cartesian mesh is to be built. More...
| const char * | cs_mesh_cartesian_get_name (int id) |
| | Get name of structured mesh. More...
| int | cs_mesh_cartesian_get_gc_id_shift (int id) |
| | Get group class id shift of cartesian mesh. More...
| void | cs_mesh_cartesian_set_gc_id_shift (int id, int shift) |
| | Set group class id shift of cartesian mesh. More...
| cs_gnum_t | cs_mesh_cartesian_get_n_g_cells (int id) |
| | Get global number of cells of a cartesian mesh. More...
| cs_gnum_t | cs_mesh_cartesian_get_n_g_faces (int id) |
| | Get global number of faces of a cartesian mesh. More...
| cs_gnum_t | cs_mesh_cartesian_get_n_g_vtx (int id) |
| | Get global number of vertices of a cartesian mesh. More...
| int | cs_mesh_cartesian_get_ncells (int id, int idim) |
| | Get number of cells in a given direction. More...
| void | cs_mesh_cartesian_block_connectivity (int id, cs_mesh_t *m, cs_mesh_builder_t *mb, long echo) |
| | Build unstructured connectivity needed for partitionning. More...
| void | cs_mesh_cartesian_finalize_definition (void) |
| | Compute all global values for meshes. More...
| void | cs_mesh_cartesian_params_destroy (void) |
| | Destroy cartesian mesh parameters. More...
| void | cs_mesh_cartesian_set_max_number_of_blocks (int n_blocks) |
| | Set maximum number of cartesian blocks (by default is set to None) More...
| void cs_mesh_cartesian_define_dir_geom_by_part |
mp, |
int |
idir, |
int |
n_parts, |
const cs_real_t |
part_coords[], |
const cs_lnum_t |
n_part_cells[], |
const cs_real_t |
amp_factors[] |
A direction is split in several parts. Each part contains a number of cells, its starting and ending position (stored in a compact way) inside part_coords, the amplification factor (f) between the first and last cell size of each part. Notice that if f = 1, this leads to a uniform refinement. If f > 1, (resp f < 1) this leads to a growing (resp. decreasing) geometric progression of the cell size when moving along the direction of increasing coordinates.
- Parameters
| [in] | mp | Pointer to mesh parameters |
| [in] | idir | Direction index. 0->X, 1->Y, 2->Z |
| [in] | n_parts | Number of parts to define the direction |
| [in] | part_coords | Position delimiting each part (size = n_parts + 1) |
| [in] | n_part_cells | Number of cells in each part (size = n_parts) |
| [in] | amp_factors | Amplification factor in each part (size = n_parts) |
