8.2
cs_gwf_tracer.h File Reference
#include "cs_advection_field.h"
#include "cs_equation.h"
#include "cs_gwf_param.h"
+ Include dependency graph for cs_gwf_tracer.h:
Data Structures
struct  cs_gwf_tracer_decay_chain_t
struct  cs_gwf_tracer_default_context_t
struct  cs_gwf_tracer_t
Typedefs
typedef void() cs_gwf_tracer_init_setup_t(cs_gwf_tracer_t *tracer)
 Generic function to update the first setup stage (the one done before building mesh and its related quantities) for a tracer equation. More...
typedef void() cs_gwf_tracer_finalize_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
 Generic function to finalize the setup of parameters related to a tracer equation. At this stage, mesh and its related quantities have been built. More...
typedef void() cs_gwf_tracer_update_t(cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
 Generic function to update the properties related to a tracer. This function depends on a numerical scheme and a physical model. More...
typedef void() cs_gwf_tracer_free_context_t(cs_gwf_tracer_t *tracer)
 Generic function to free the input of a tracer model. More...
typedef void() cs_gwf_tracer_integrate_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_zone_t *zone, void *context, double results[])
 Compute the quantity of tracer using an integral of the tracer concentration over a given set of cells (the cells of the volume zone). Several terms can be computed. The quantity is given in moles. A parallel operation (a sum reduction) is performed inside this function. More...
cs_gwf_tracer_tcs_gwf_tracer_by_name (const char *eq_name)
 Retrieve the pointer to the cs_gwf_tracer_t structure associated to the name given as parameter. More...
cs_gwf_tracer_tcs_gwf_tracer_add (cs_gwf_tracer_model_t tr_model, cs_gwf_model_type_t gwf_model, const char *eq_name, const char *var_name, cs_adv_field_t *adv_field, double lambda, int chain_position, int chain_id, cs_gwf_tracer_init_setup_t *init_setup, cs_gwf_tracer_finalize_setup_t *finalize_setup)
 Create a new cs_gwf_tracer_t structure and initialize its members. This creation of a new tracer is fully done in the case of a default tracer. Additional settings has to be done in the case of a user-defined tracer. More...
void cs_gwf_tracer_free_all (void)
 Free all tracer structures and all decay chains. More...
cs_real_t cs_gwf_tracer_get_time_theta_max (void)
 Retrieve the max. value of the theta parameter associated to a time scheme. Loop on all tracer equations. More...
void cs_gwf_tracer_set_soil_param (cs_gwf_tracer_t *tracer, const char *soil_name, double wmd, double alpha_l, double alpha_t, double distrib_coef)
 Set the main parameters corresponding to a default modelling of a tracer transport equation for a specified soil. More...
void cs_gwf_tracer_set_precip_param (cs_gwf_tracer_t *tracer, const char *soil_name, double conc_l_star)
 For a specified soil set the parameters corresponding to a precipitation modelling of a tracer transport. More...
void cs_gwf_tracer_init_setup (void)
 Initial setup step for tracer equations. Soils and equation parameters are defined at this stage. Create new cs_field_t structures according to the setting. More...
void cs_gwf_tracer_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
 Finalize the tracer setup. More...
void cs_gwf_tracer_update_diff_pty (const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
 Update the diffusion property related to each tracer equation The update strategy depends on the soil/tracer features and also on the hydraulic model. More...
void cs_gwf_tracer_log_all (void)
 Display the main features related to each tracer. More...
void cs_gwf_tracer_compute_steady_all (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
 Compute the steady-state for all tracer equations. Nothing is done if all equations are unsteady. More...
void cs_gwf_tracer_compute_all (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
 Compute the new (unsteady) state for all tracer equations. Nothing is done if all equations are steady. More...
void cs_gwf_tracer_default_init_setup (cs_gwf_tracer_t *tracer)
 Add terms to the algebraic system related to a tracer equation according to the settings. Case of the default tracer modelling Rely on the generic function: cs_gwf_tracer_add_terms_t. More...
void cs_gwf_tracer_sat_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
 Set the parameters related to a standard tracer equation case of a fully saturated flow model. More...
void cs_gwf_tracer_unsat_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
 Set the parameters related to a standard tracer equation in case of an unsaturated flow model. More...
double cs_gwf_tracer_integrate (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name)
 Compute the integral of the tracer concentration over a given set of cells. This integral gives the number of moles of tracer inside the related volume. Moreover, it turns out to be exact for linear functions. A parallel operation (a sum reduction) is performed. More...
void cs_gwf_tracer_integrate_by_terms (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name, double results[])
 Compute the quantity of tracer using the integral of the tracer concentration over a given set of cells. Two terms are computed: one for the quantity of moles inside the liquid phase and another one for the quantity of tracer inside the precipitation state (in moles). A parallel operation (a sum reduction) is performed inside this function. More...
cs_gwf_tracer_decay_chain_tcs_gwf_tracer_create_decay_chain (int n_tracers, const char *chain_name, cs_gwf_tracer_unit_t unit)
 Create a decay chain structure to manage several linked tracers. More...
cs_gwf_tracer_decay_chain_tcs_gwf_tracer_decay_chain_by_id (int id)
 Retrieve the decay chain structure associated to the given id If not found, it returns the NULL pointer. More...
cs_gwf_tracer_decay_chain_tcs_gwf_tracer_decay_chain_by_name (const char *chain_name)
 Retrieve the decay chain structure associated to the name given as parameter. If not found, it returns the NULL pointer. More...
cs_gwf_tracer_tcs_gwf_tracer_decay_chain_get_tracer (cs_gwf_tracer_decay_chain_t *tdc, int id)
 Retrieve the tracer structure for the tracer at the position "id" in the decay chain structure. If "id" is not valid, then a NULL pointer is returned. More...
cs_equation_tcs_gwf_tracer_decay_chain_get_equation (cs_gwf_tracer_decay_chain_t *tdc, int id)
 Retrieve the equation structure for the tracer at the position "id" in the decay chain structure. If "id" is not valid, then a NULL pointer is returned. More...
cs_equation_param_tcs_gwf_tracer_decay_chain_get_equation_param (cs_gwf_tracer_decay_chain_t *tdc, int id)
 Retrieve the equation parameters for the tracer at the position "id" in the decay chain structure. If "id" is not valid, then a NULL pointer is returned. More...
Typedef Documentation
◆ cs_gwf_tracer_finalize_setup_t
[in]advpointer to an advection field structure
[in,out]tracerpointer to a cs_gwf_tracer_t structure
◆ cs_gwf_tracer_free_context_t
[in,out]tracerpointer to a structure cs_gwf_tracer_t
◆ cs_gwf_tracer_init_setup_t
◆ cs_gwf_tracer_integrate_t
[in]eqequation related to a tracer
[in]zonepointer to a volume zone structure
[in]contextpointer to a context structure for a tracer
[in,out]resultsresulting array of values
◆ cs_gwf_tracer_update_t
[in,out]tracerpointer to a cs_gwf_tracer_structure
[in,out]contextNULL or pointer to a structure cast on-the-fly
[in]tspointer to a cs_time_step_t structure
◆ cs_gwf_tracer_add()
cs_gwf_tracer_t* cs_gwf_tracer_add ( cs_gwf_tracer_model_t  tr_model,
const char *  eq_name,
const char *  var_name,
cs_adv_field_t adv_field,
double  lambda,
int  chain_position,
int  chain_id,
cs_gwf_tracer_init_setup_t init_setup,
cs_gwf_tracer_finalize_setup_t finalize_setup
Add a new equation related to the groundwater flow module. This equation is a specific transport equation. The tracer is advected thanks to the darcian velocity (in the liquid phase) which is given by the resolution of the Richards equation. Diffusion and reaction coefficients result from a physical modelling.
[in]tr_modelmodel related to this tracer
[in]gwf_modelmain model for the GWF module
[in]eq_namename of the tracer equation
[in]var_namename of the related variable
[in]adv_fieldpointer to a cs_adv_field_t structure
[in]lambdavalue of the first order decay coefficient
[in]chain_position-1 if not used or the id in the chain position
[in]chain_id-1 or id of the associated decay chain
[in]init_setupfunction pointer (predefined prototype)
[in]finalize_setupfunction pointer (predefined prototype)
a pointer to the new allocated structure
◆ cs_gwf_tracer_by_name()
cs_gwf_tracer_t* cs_gwf_tracer_by_name ( const char *  eq_name)
the pointer to a cs_gwf_tracer_t structure
◆ cs_gwf_tracer_compute_all()
void cs_gwf_tracer_compute_all ( const cs_mesh_t mesh,
const cs_time_step_t time_step,
const cs_cdo_quantities_t cdoq
◆ cs_gwf_tracer_compute_steady_all()
void cs_gwf_tracer_compute_steady_all ( const cs_mesh_t mesh,
◆ cs_gwf_tracer_create_decay_chain()
cs_gwf_tracer_decay_chain_t* cs_gwf_tracer_create_decay_chain ( int  n_tracers,
const char *  chain_name,
[in]n_tracersnumber of tracers equations
[in]chain_namename of the decay chain
[in]unittype of unit used in the tracer equations
a pointer to the new cs_gwf_tracer_decay_chain_t structure
◆ cs_gwf_tracer_decay_chain_by_id()
cs_gwf_tracer_decay_chain_t* cs_gwf_tracer_decay_chain_by_id ( int  id)
[in]idid of the decay chain to retrieve
a pointer to a new cs_gwf_tracer_decay_chain_t structure or NULL
◆ cs_gwf_tracer_decay_chain_by_name()
cs_gwf_tracer_decay_chain_t* cs_gwf_tracer_decay_chain_by_name ( const char *  chain_name)
◆ cs_gwf_tracer_decay_chain_get_equation()
cs_equation_t* cs_gwf_tracer_decay_chain_get_equation ( cs_gwf_tracer_decay_chain_t tdc,
int  id
[in]tdcpointer to a decay chain structure
[in]idposition of the tracer in the decay chain
a pointer to a cs_equation_t structure or NULL
◆ cs_gwf_tracer_decay_chain_get_equation_param()
cs_equation_param_t* cs_gwf_tracer_decay_chain_get_equation_param ( cs_gwf_tracer_decay_chain_t tdc,
int  id
a pointer to a cs_equation_param_t structure or NULL
◆ cs_gwf_tracer_decay_chain_get_tracer()
cs_gwf_tracer_t* cs_gwf_tracer_decay_chain_get_tracer ( cs_gwf_tracer_decay_chain_t tdc,
int  id
a pointer to a cs_gwf_tracer_t structure or NULL
◆ cs_gwf_tracer_default_init_setup()
void cs_gwf_tracer_default_init_setup ( cs_gwf_tracer_t tracer)
◆ cs_gwf_tracer_finalize_setup()
void cs_gwf_tracer_finalize_setup ( const cs_cdo_connect_t connect,
const cs_cdo_quantities_t quant
◆ cs_gwf_tracer_free_all()
void cs_gwf_tracer_free_all ( void  )
◆ cs_gwf_tracer_get_time_theta_max()
cs_real_t cs_gwf_tracer_get_time_theta_max ( void  )
the computed value
◆ cs_gwf_tracer_init_setup()
void cs_gwf_tracer_init_setup ( void  )
◆ cs_gwf_tracer_integrate()
double cs_gwf_tracer_integrate ( const cs_cdo_connect_t connect,
const cs_cdo_quantities_t cdoq,
const cs_gwf_tracer_t tracer,
const char *  z_name
[in]tracerpointer to a cs_gwf_tracer_t structure
[in]z_namename of the volumic zone where the integral is done (if NULL or "" all cells are considered)
the value of the integral (number of moles in the zone) parallel synchronization is done
◆ cs_gwf_tracer_integrate_by_terms()
void cs_gwf_tracer_integrate_by_terms ( const cs_cdo_connect_t connect,
const char *  z_name,
double  results[]
[in]z_namename of the volume zone where the integral is done (if NULL or "" all cells are considered)
[in,out]resultsarray of values. [0]= the quantity of moles in the liquid phase, [1]= the quantity of moles inside the precipitation state
◆ cs_gwf_tracer_log_all()
void cs_gwf_tracer_log_all ( void  )
◆ cs_gwf_tracer_sat_finalize_setup()
void cs_gwf_tracer_sat_finalize_setup ( const cs_cdo_connect_t connect,
const cs_adv_field_t adv,
◆ cs_gwf_tracer_set_precip_param()
void cs_gwf_tracer_set_precip_param ( cs_gwf_tracer_t tracer,
const char *  soil_name,
double  conc_l_star
[in]soil_namename of the related soil (or NULL if all soils are selected)
[in]conc_l_starvalue of the saturated concentration in the liquid phase
◆ cs_gwf_tracer_set_soil_param()
void cs_gwf_tracer_set_soil_param ( cs_gwf_tracer_t tracer,
double  wmd,
double  alpha_l,
double  alpha_t,
double  distrib_coef
[in]wmdvalue of the water molecular diffusivity
[in]alpha_lvalue of the longitudinal dispersivity
[in]alpha_tvalue of the transversal dispersivity
[in]distrib_coefvalue of the distribution coefficient
◆ cs_gwf_tracer_unsat_finalize_setup()
void cs_gwf_tracer_unsat_finalize_setup ( const cs_cdo_connect_t connect,
◆ cs_gwf_tracer_update_diff_pty()
void cs_gwf_tracer_update_diff_pty ( const cs_time_step_t ts,
