| integer | nmodmx |
| | number of specific physics More...
| integer(c_int), dimension(:), pointer, save | ippmod |
| | global indicator for speciphic physics By default, all the indicators ippmod(i.....) are initialized to -1, which means that no specific physics is activated. More...
| integer | iphpar |
| | ippmod(iphpar) is a global indicator for the specific physics: More...
| integer | icod3p |
| | pointer for specific physics More...
| integer | islfm |
| | pointer to specify steady laminar flamelet approach More...
| integer | icoebu |
| | pointer to specify Eddy Break Up pre-mixed flame with indicator ippmod(icoebu) More...
| integer | icolwc |
| | pointer to specify Libby-Williams pre-mixed flame withy indicator ippmod(icolwc) More...
| integer(c_int), pointer, save | isoot |
| integer | ieljou |
| | pointer to specify Joule effect module (Laplace forces not taken into account) with indicator ippmod(ieljou): More...
| integer | ielarc |
| | pointer to specify Electric arcs module (Joule effect and Laplace forces) with indicator ippmod(ielarc): More...
| integer | iccoal |
| | pointer to specify multi-coals and multi-classes pulverised coal combustion with indicator ippmod(iccoal). The number of different coals must be inferior or equal to ncharm = 3. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 10. More...
| integer | icompf |
| | pointer to specify compressible module with indicator ippmod(icompf) More...
| integer | iatmos |
| | pointer to specify atmospheric flow module with indicator ippmod(iatmos) More...
| integer | iaeros |
| | pointer to specify cooling towers module with indicator ippmod(iaeros) More...
| integer | igmix |
| | pointer to specify gas mixture module with indicator ippmod(igmix) More...
| integer(c_int), pointer, save | icondb |
| | Specific condensation modelling if = -1 module not activated if = 0 condensation source terms activated. More...
| integer(c_int), pointer, save | icondb_model |
| | Wall condensation correlation (only if icondb > -1) if = 0 legacy copain model if = 1 updated copain model (Benteboula and Dabbene 2020) if = 2 Uchida model (TODO : add ref) if = 3 Dehbi model (Dehbi 2015) More...
| integer(c_int), pointer, save | icondv |
| | Specific condensation modelling if = -1 module not activated if = 0 condensation source terms with metal structures activate. More...
| integer, save | ifm |
| | pointer to specify the mixing rate in isca(ifm) More...
| integer, save | ifp2m |
| | pointer to specify the variance of the mixing rate in isca(ifp2m) More...
| integer, save | ifsqm |
| | pointer to specify the second moment of the mixing rate in isca(ifsqm): More...
| integer, save | ipvm |
| | pointer to specify the transported progress variable ippmod(islfm) >= 2: More...
| integer, save | iygfm |
| | pointer to specify the fresh gas mass fraction in isca(iygfm) More...
| integer, save | icm |
| | the intersection computation mode. If its value is: More...
| integer, save | icp2m |
| | transported variable More...
| integer, save | ifpcpm |
| integer, save | iyfm |
| integer, save | iyfp2m |
| integer, save | icoyfp |
| integer, dimension(ngazgm), save | iym |
| | mass fractions : More...
| integer, dimension(ngazgm), save | ibym |
| integer, save | itemp |
| | state variable (temperature) More...
| integer, save | ifmin |
| | state variable More...
| integer, save | ifmax |
| integer, save | irecvr |
| | state variable: Pointer to the reconstructed variance in case of mode_fp2m = 1 More...
| integer, save | itotki |
| | state variable: Pointer to the total scalar dissipation rate More...
| integer, save | ihrr |
| | state variable: Pointer to volumetric heat release rate More...
| integer, save | ixr |
| | state variable: Pointer to enthalpy defect More...
| integer, save | iomgc |
| integer, save | ickabs |
| | state variable: absorption coefficient, when the radiation modelling is activated More...
| integer, save | it2m |
| | state variable: term More...
| integer, save | it3m |
| | state variable: term, when the radiation modelling is activated More...
| integer, save | it4m |
| integer, save | itsc |
| integer, save | inpm |
| | pointer for soot precursor number in isca (isoot = 1) More...
| integer, save | ifsm |
| | pointer for soot mass fraction in isca (isoot = 1) More...
| integer, dimension(ncharm), save | if1m |
| | mean value of the tracer 1 representing the light volatiles released by the coal icha More...
| integer, dimension(ncharm), save | if2m |
| | mean value of the tracer 2 representing the heavy volatiles released by the coal icha More...
| integer, save | if4m |
| | tracer 4: mass of the oxydant 2 divided by the mass of bulk More...
| integer, save | if5m |
| | tracer 5: mass of the oxydant 3 divided by the mass of bulk More...
| integer, save | if6m |
| | tracer 6: water coming from drying More...
| integer, save | if7m |
| | tracer 7: mass of the carbon from coal oxydized by O2 divided by the mass of bulk More...
| integer, save | if8m |
| | tracer 8: mass of the carbon from coal gasified by CO2 divided by the mass of bulk More...
| integer, save | if9m |
| | tracer 9: mass of the Carbon from coal gasified by H2O divided by the mass of bulk More...
| integer, save | ifvp2m |
| | f1f2 variance More...
| integer, dimension(nclcpm), save | ixck |
| | coke mass fraction related to the class icla More...
| integer, dimension(nclcpm), save | ixch |
| | reactive coal mass fraction related to the class icla More...
| integer, dimension(nclcpm), save | inp |
| | number of particles of the class icla per kg of air-coal mixture More...
| integer, dimension(nclcpm), save | ih2 |
| | mass enthalpy of the coal of class icla, if we are in permeatic conditions More...
| integer, dimension(nclcpm), save | ixwt |
| | transported variable of dispersed phase (particle class) More...
| integer, dimension(nclcpm), save | inagecp |
| | Pointer to Np*age(particles) More...
| integer, dimension(nclcpm), save | iv_p_x |
| integer, dimension(nclcpm), save | iv_p_y |
| integer, dimension(nclcpm), save | iv_p_z |
| integer, dimension(ngazem), save | iym1 |
| | mass fractions: More...
| integer, save | irom1 |
| | State variables of continuous phase (gas mixture) More...
| integer, save | immel |
| | molar mass of the gas mixture More...
| integer, dimension(nclcpm), save | itemp2 |
| | temperature of the particles of the class icla More...
| integer, dimension(nclcpm), save | irom2 |
| | density of the particles of the class icla More...
| integer, dimension(nclcpm), save | idiam2 |
| | diameter of the particles of the class icla More...
| integer, dimension(nclcpm), save | ix2 |
| | solid mass fraction of the class icla More...
| integer, dimension(nclcpm), save | igmdch |
| | disappearance rate of the reactive coal of the class icla More...
| integer, dimension(nclcpm), save | igmhet |
| | coke disappearance rate of the coke burnout of the class icla More...
| integer, dimension(nclcpm), save | igmtr |
| | Implicite part of the exchanges to the gas by molecular distribution. More...
| integer, dimension(nclcpm), save | ighco2 |
| | State variables of dispersed phase (particles class) More...
| integer, dimension(nclcpm), save | igmdv1 |
| | mass transfer caused by the release of light volatiles of the class icla More...
| integer, dimension(nclcpm), save | igmdv2 |
| | mass transfer caused by the release of heavy volatiles of the class icla More...
| integer, dimension(nclcpm), save | igmsec |
| integer, save | ibcarbone |
| | Used for bulk balance of Carbon. More...
| integer, save | iboxygen |
| | Used for bulk balance of Oxygen. More...
| integer, save | ibhydrogen |
| | Used for bulk balance of Hydrogen. More...
| integer, dimension(nclcpm), save | ihlf |
| | transported variable of dispersed phase More...
| integer, dimension(nclcpm), save | ixkf |
| integer, dimension(nclcpm), save | ixfol |
| integer, dimension(nclcpm), save | ing |
| integer, dimension(nclcpm), save | iyfol |
| | state variable of continuous phase More...
| integer, dimension(nclcpm), save | ih1hlf |
| | state variable of dispersed phase More...
| integer, dimension(nclcpm), save | igmhtf |
| integer, dimension(nclcpm), save | igmeva |
| integer, save | ienerg |
| | specific total energy for compressible algorithm More...
| integer, save | itempk |
| | temperature deduced from the specific total energy More...
| integer, save | ifracv |
| | homogeneous model, volume fraction More...
| integer, save | ifracm |
| | homogeneous model, mass fraction More...
| integer, save | ifrace |
| | homogeneous model, energy fraction More...
| integer, save | iviscv |
| | additional property: More...
| integer, save | irun |
| | alias for boundary conditions More...
| integer, save | irunh |
| real(c_double), pointer, save | viscv0 |
| | reference volume viscosity More...
| integer, save | ippred |
| | pressure predicion by an evolution equation More...
| integer, save | igrdpp |
| | indicates whether the pressure should be updated (=1) or not (=0) after the solution of the acoustic equation always usef More...
| integer, save | icfgrp |
| | indicates if the boundary conditions should take into account (=1) or not (=0) the hydrostatic balance. More...
| integer, save | ihm |
| | enthalpy, if transported or if deduced More...
| double precision, save | srrom |
| | with gas combustion, or pulverised coal, srrom is the sub-relaxation coefficient for the density, following the formula: hence, with a zero value, there is no sub-relaxation. srrom is initialized to -grand and the user must specify a proper value through the GUI or the initialization subroutine (cs_user_combustion). It is automatically used after the second time-step. More...
| integer(c_int), dimension(:), pointer, save | iqimp |
| | imposed flow zone indicator in a way which is similar to the process described in the framework of the EBU module, the user chooses for every inlet face to impose the mass flow or not (iqimp(izone)=1 or 0). If the mass flow is imposed, the user must set the air mass flow value qimp(izone) ant its direction in rcodcl(ifac,iu), rcodcl(ifac,iv) and rcodcl(ifac,iw). If the velocity is imposed, he has to set rcodcl(ifac,iu), rcodcl(ifac,iv), and rcodcl(ifac,iw). More...
| integer(c_int), dimension(:), pointer, save | icalke |
| | condition type turbulence indicator More...
| real(c_double), dimension(:), pointer, save | xintur |
| | turbulent intensity (k=1.5(uref*xintur)**2) More...
| real(c_double), dimension(:), pointer, save | dh |
| | hydraulic diameter More...
| integer, save | nozapm |
| | index of maximum reached boundary zone More...
| integer, save | nzfppp |
| | number of boundary zones on current process More...
| integer, dimension(nozppm), save | ilzppp |
| | list of boundary zones index More...
