integer, save | irun |
alias for boundary conditions More... | |
integer, save | irunh |
real(c_double), pointer, save | viscv0 |
reference volume viscosity More... | |
integer, save | ippred |
pressure predicion by an evolution equation More... | |
integer, save | igrdpp |
indicates whether the pressure should be updated (=1) or not (=0) after the solution of the acoustic equation always usef More... | |
integer, save | icfgrp |
indicates if the boundary conditions should take into account (=1) or not (=0) the hydrostatic balance. More... | |
integer, save icfgrp |
Always useful.
In the cases where gravity is predominant, taking into account the hydrostatic pressure allows to get rid of the disturbances which may appear near the horizontal walls when the flow is little convective.
Otherwise, when icfgrp=0, the pressure condition is calculated from the solution of the unidimensional Euler equations for a perfect gas near a wall, for the variables "normal velocity", "density" and "pressure":
Case of an expansion (M <= 0):
Case of a schock (M > 0):
with , internal Mach number calculated with the variables taken in the cell.
integer, save igrdpp |
integer, save ippred |
integer, save irun |
integer, save irunh |
real(c_double), pointer, save viscv0 |
