| integer, save | ipr = 0 |
| | pressure More...
| integer, save | iu = 0 |
| | velocity component More...
| integer, save | iv = 0 |
| integer, save | iw = 0 |
| integer, save | ivolf2 = 0 |
| | void fraction for VOF method More...
| integer, save | ik = 0 |
| | turbulent kinetic energy More...
| integer, save | iep = 0 |
| | turbulent dissipation More...
| integer, save | ir11 = 0 |
| | Reynolds stress component More...
| integer, save | ir22 = 0 |
| integer, save | ir33 = 0 |
| integer, save | ir12 = 0 |
| integer, save | ir23 = 0 |
| integer, save | ir13 = 0 |
| integer, save | irij = 0 |
| | Reynolds stress tenso More...
| integer, save | iphi = 0 |
| | variable of the model More...
| integer, save | ifb = 0 |
| integer, save | ial = 0 |
| integer, save | iomg = 0 |
| | variable of the SST More...
| integer, save | inusa = 0 |
| | variable of the Spalart Allmaras More...
| integer, dimension(nscamx), save | isca |
| | isca(i) is the index of the scalar i More...
| integer, dimension(nscamx), save | iscapp |
| | iscapp(i) is the index of the specific physics scalar i More...
| integer, save | nscaus = 0 |
| | number of user scalars solutions of an advection equation More...
| integer, save | nscapp = 0 |
| | number of specific physics scalars More...
| integer(c_int), pointer, save | nscasp |
| | number of species scalars More...
| integer, save | iuma = 0 |
| | mesh velocity component More...
| integer, save | ivma = 0 |
| integer, save | iwma = 0 |
| integer, save | irom = -1 |
| | Density at the current time step (equal to icrom, kept for compatibility) More...
| integer, save | iviscl = -1 |
| | dynamic molecular viscosity (in kg/(m.s)) More...
| integer, save | ivisct = -1 |
| | dynamic turbulent viscosity More...
| integer, save | kimasf = -1 |
| | interior and boundary convective mass flux key ids of the variables More...
| integer, save | kbmasf = -1 |
| integer, save | kvisl0 = -1 |
| | constant diffusivity field id key for scalars More...
| integer, save | kivisl = -1 |
| | variable diffusivity field id key for scalars More...
| integer, save | kscacp = -1 |
| | do scalars behave as a temperature (regarding multiplication by Cp) ? More...
| integer, save | kromsl = -1 |
| | variable density field id key for scalars More...
| integer, save | kstprv = -1 |
| | source terms at previous time step for 2nd order More...
| integer, save | kst = -1 |
| | source terms at the current time step (used for limiters) More...
| integer, save | ksigmas = -1 |
| | turbulent schmidt key for scalars More...
| integer, save | kctheta = -1 |
| | turbulent flow models GGDH and AFM key for scalar More...
| integer, dimension(nvarmx), save | ifluaa |
| | convective mass flux of the variables at the previous time-step More...
| integer, save | icrom = -1 |
| | cell density field ids of the variables More...
| integer, save | ibrom = -1 |
| | boundary density field ids of the variables More...
| integer, save | ipori = -1 |
| | field ids of the cell porosity More...
| integer, save | iporf = -1 |
| integer, save | ismago = -1 |
| | dynamic constant of Smagorinsky More...
| integer, save | ivsten = -1 |
| | field ids of the anisotropic viscosity More...
| integer, save | ivstes = -1 |
| integer, save | icour = -1 |
| | Courant number. More...
| integer, save | ifour = -1 |
| | Fourier number. More...
| integer, save | iprtot = -1 |
| | Total pressure at cell centers . More...
| integer, save | ivisma = -1 |
| | Mesh velocity viscosity for the ALE module. More...
| integer, dimension(nscamx), save | iustdy |
| | pointer for dilatation source terms More...
| integer, save | itsrho = -1 |
| | pointer for global dilatation source terms More...
| integer, save | ibeta = -1 |
| | pointer for thermal expansion coefficient More...
| integer, save | iddgas = -1 |
| | pointer for deduced mass fraction in case of gas mix More...
| integer, save | igmxml = -1 |
| | pointer for gas mix molar mass More...
| integer, save | iforbr = -1 |
| | field id of the stresses at boundary (if post-processed) More...
| integer, save | iyplbr = -1 |
| | field id of at boundary (if post-processed) More...
| integer, save | itempb = -1 |
| | field id of temperature at boundary More...
| integer, save | kwgrec = -1 |
| | Weighting for gradient calculation on variables. More...
| integer, dimension(nvarmx), save | ivarfl |
| | Field id for variable i. More...
| integer, save | idtten = -1 |
| | Field id for the dttens tensor. More...
Module for variable numbering.
