Physical properties are using the field API. See cs_user_boundary_conditions for some examples. More...
Collaboration diagram for Physical properties:Variables | |
| integer, save | irom = -1 |
| Density at the current time step (equal to icrom, kept for compatibility) More... | |
| integer, save | iviscl = -1 |
| dynamic molecular viscosity (in kg/(m.s)) More... | |
| integer, save | ivisct = -1 |
| dynamic turbulent viscosity More... | |
| integer, save | kimasf = -1 |
| interior and boundary convective mass flux key ids of the variables More... | |
| integer, save | kbmasf = -1 |
| integer, save | kvisl0 = -1 |
| constant diffusivity field id key for scalars More... | |
| integer, save | kivisl = -1 |
| variable diffusivity field id key for scalars More... | |
| integer, save | kscacp = -1 |
| do scalars behave as a temperature (regarding multiplication by Cp) ? More... | |
| integer, save | kromsl = -1 |
| variable density field id key for scalars More... | |
| integer, save | kstprv = -1 |
| source terms at previous time step for 2nd order More... | |
| integer, save | kst = -1 |
| source terms at the current time step (used for limiters) More... | |
| integer, save | ksigmas = -1 |
| turbulent schmidt key for scalars More... | |
| integer, save | kctheta = -1 |
| turbulent flow models GGDH and AFM key for scalar More... | |
| integer, dimension(nvarmx), save | ifluaa |
| convective mass flux of the variables at the previous time-step More... | |
| integer, save | icrom = -1 |
| cell density field ids of the variables More... | |
| integer, save | ibrom = -1 |
| boundary density field ids of the variables More... | |
| integer, save | ipori = -1 |
| field ids of the cell porosity More... | |
| integer, save | iporf = -1 |
| integer, save | ismago = -1 |
| dynamic constant of Smagorinsky More... | |
| integer, save | ivsten = -1 |
| field ids of the anisotropic viscosity More... | |
| integer, save | ivstes = -1 |
| integer, save | icour = -1 |
| Courant number. More... | |
| integer, save | ifour = -1 |
| Fourier number. More... | |
| integer, save | iprtot = -1 |
| Total pressure at cell centers | |
| integer, save | ivisma = -1 |
| Mesh velocity viscosity for the ALE module. More... | |
| integer, dimension(nscamx), save | iustdy |
| pointer for dilatation source terms More... | |
| integer, save | itsrho = -1 |
| pointer for global dilatation source terms More... | |
| integer, save | ibeta = -1 |
| pointer for thermal expansion coefficient More... | |
| integer, save | iddgas = -1 |
| pointer for deduced mass fraction in case of gas mix More... | |
| integer, save | igmxml = -1 |
| pointer for gas mix molar mass More... | |
| integer, save | iforbr = -1 |
| field id of the stresses at boundary (if post-processed) More... | |
| integer, save | iyplbr = -1 |
| field id of | |
| integer, save | itempb = -1 |
| field id of temperature at boundary More... | |
| integer, save ibeta = -1 |
| integer, save ibrom = -1 |
| integer, save icour = -1 |
Courant number.
| integer, save icrom = -1 |
| integer, save iddgas = -1 |
| integer, dimension(nvarmx), save ifluaa |
| integer, save iforbr = -1 |
| integer, save ifour = -1 |
Fourier number.
| integer, save igmxml = -1 |
| integer, save iporf = -1 |
| integer, save ipori = -1 |
| integer, save iprtot = -1 |
| integer, save irom = -1 |
| integer, save ismago = -1 |
| integer, save itempb = -1 |
| integer, save itsrho = -1 |
| integer, dimension(nscamx), save iustdy |
| integer, save iviscl = -1 |
| integer, save ivisct = -1 |
| integer, save ivisma = -1 |
| integer, save ivsten = -1 |
| integer, save ivstes = -1 |
| integer, save iyplbr = -1 |
field id of
| integer, save kbmasf = -1 |
| integer, save kctheta = -1 |
| integer, save kimasf = -1 |
| integer, save kivisl = -1 |
| integer, save kromsl = -1 |
| integer, save kscacp = -1 |
| integer, save ksigmas = -1 |
| integer, save kst = -1 |
| integer, save kstprv = -1 |
| integer, save kvisl0 = -1 |
