| integer(c_int), pointer, save | nfbpcd |
| | number of faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine cs_user_wall_condensation More...
| integer, dimension(:,:), pointer, save | itypcd |
| | type of condensation source terms for each variable More...
| double precision, dimension(:), pointer, save | thermal_condensation_flux |
| | value of the thermal flux for the condensation model. See the user subroutine cs_user_wall_condensation More...
| double precision, dimension(:), pointer, save | flthr |
| | external heat flux used as flux conditions of the 1d thermal model (in unit ). More...
| double precision, dimension(:), pointer, save | dflthr |
| | external heat flux derivative used as flux conditions of the 1d thermal model (in unit ). More...
| double precision, dimension(:,:), pointer, save | spcond |
| | value of the condensation source terms for pressure. For the other variables, eventual imposed specific value. See the user subroutine cs_user_wall_condensation More...
| double precision, dimension(:), pointer, save | twall_cond |
| | Temperature at condensing wall faces (for post-processing purposes) More...
| double precision, dimension(:), pointer, save | hpcond |
| | value of the thermal exchange coefficient associated to the condensation model used. See the user subroutine cs_user_wall_condensation More...
| integer, dimension(:), pointer, save | ifbpcd |
| | list on the nfbpcd faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine cs_user_wall_condensation More...
| integer(c_int), pointer, save | nzones |
| | number of the zones with a specific condensation source terms depending on the wall temperature and material properties. by default (nzones = 1) if the user does not specified different zones in the user subroutine cs_user_wall_condensation.f90 . More...
| integer, dimension(:), pointer, save | izzftcd |
| | list of the zones associated to the faces where a condensation source term is imposed. On each zone a specific wall temperature and material properties can be specified by the user. More...
| integer, dimension(:), pointer, save | izcophc |
| | choice the way to compute the exchange coefficient of the condensation source term used by the copain model. More...
| integer, dimension(:), pointer, save | izcophg |
| | choice the way to compute the thermal exchange coefficient associated to the heat transfer to the wall due to the condensation phenomenon. More...
| integer, dimension(:), pointer, save | iztag1d |
| | choice the way to compute the wall temperature at the solid/fluid interface coupled with condensation to the wall More...
| integer, save | nztag1d |
| | Indicate if the thermal 1D model of severe accident is usde to compute the wall temperature at the solid/fluid interface coupled with condensation to the wall More...
| double precision, dimension(:), pointer, save | ztpar |
| | Constant value of the wall temperature given by the user when the thermal 1D model is not activated for the condensation model with different zones specified in the user subroutine cs_user_wall_condensation. More...
| double precision, dimension(:, :), pointer, save | zxrefcond |
| | Coordinates of the reference point for forced and mixed convection regimes index 1 : coordinate, index 2: zone_id More...
| double precision, dimension(:, :), pointer, save | zprojcond |
| integer(c_int), pointer, save | ncmast |
| | number of the cells in which a condensation source terms is imposed. See lstmast list and the subroutine cs_user_wall_condensation More...
| integer(c_int), pointer, save | nvolumes |
| | number of the volume strutures with a specific condensation source terms depending on the wall temperature and material properties. by default (nvolumes = 1) if the user does not specified different volumes in the user subroutine cs_user_wall_condensation.f90 . More...
| integer, dimension(:), pointer, save | ltmast |
| | list on the ncmast cells in which a condensation source terms is imposed. See the user subroutine cs_user_wall_condensation. More...
| integer, dimension(:), pointer, save | izmast |
| | zone type where a condensation source terms is imposed to model the metal structures condensation on a volumic zone. More...
| integer, dimension(:,:), pointer, save | itypst |
| double precision, dimension(:, :), pointer, save | svcond |
| | value of the condensation source terms for pressure associated to the metal structures modelling. For the other variables, eventual imposed specific value. See the user function cs_user_wall_condensation. More...
| double precision, dimension(:), pointer, save | flxmst |
| | value of the thermal flux for the condensation model associated to the metal structures modelling. See the user function cs_user_wall_condensation. More...
| integer, dimension(:), pointer, save | itagms |
| | choice the way to compute the wall temperature at the solid/fluid interface coupled with condensation to the metal mass structures wall More...
