| integer(c_int), pointer, save | nfbpcd |
| | number of faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine cs_user_wall_condensation More...
| integer, dimension(:,:), pointer, save | itypcd |
| | type of condensation source terms for each variable More...
| double precision, dimension(:), pointer, save | thermal_condensation_flux |
| | value of the thermal flux for the condensation model. See the user subroutine cs_user_wall_condensation More...
| double precision, dimension(:), pointer, save | flthr |
| | external heat flux used as flux conditions of the 1d thermal model (in unit ). More...
| double precision, dimension(:), pointer, save | dflthr |
| | external heat flux derivative used as flux conditions of the 1d thermal model (in unit ). More...
| double precision, dimension(:,:), pointer, save | spcond |
| | value of the condensation source terms for pressure. For the other variables, eventual imposed specific value. See the user subroutine cs_user_wall_condensation More...
| double precision, dimension(:), pointer, save | twall_cond |
| | Temperature at condensing wall faces (for post-processing purposes) More...
| double precision, dimension(:), pointer, save | hpcond |
| | value of the thermal exchange coefficient associated to the condensation model used. See the user subroutine cs_user_wall_condensation More...
| integer, dimension(:), pointer, save | ifbpcd |
| | list on the nfbpcd faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine cs_user_wall_condensation More...
| integer(c_int), pointer, save | nzones |
| | number of the zones with a specific condensation source terms depending on the wall temperature and material properties. by default (nzones = 1) if the user does not specified different zones in the user subroutine cs_user_wall_condensation.f90 . More...
| integer, dimension(:), pointer, save | izzftcd |
| | list of the zones associated to the faces where a condensation source term is imposed. On each zone a specific wall temperature and material properties can be specified by the user. More...
| integer, dimension(:), pointer, save | izcophc |
| | choice the way to compute the exchange coefficient of the condensation source term used by the copain model. More...
| integer, dimension(:), pointer, save | izcophg |
| | choice the way to compute the thermal exchange coefficient associated to the heat transfer to the wall due to the condensation phenomenon. More...
