#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <math.h>#include "bft_error.h"#include "bft_mem.h"#include "cs_array.h"#include "cs_base.h"#include "cs_equation_param.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_time_step.h"#include "cs_volume_mass_injection.h"
Include dependency graph for cs_volume_mass_injection.c:Functions | |
| void | cs_f_volume_mass_injection_get_arrays (int var_id, cs_lnum_t *ncesmp, cs_lnum_t **icetsm, int **itpsmp, cs_real_t **smcelp) |
| void | cs_volume_mass_injection_flag_zones (void) |
| Flag volume zones with the appropriate CS_VOLUME_ZONE_MASS_SOURCE_TERM flag when at least one volume mass injection on that zone is present. More... | |
| void | cs_volume_mass_injection_build_lists (cs_lnum_t n_cells, cs_lnum_t cell_num[], int cell_zone_id[]) |
| Build the list and zone ids of cells with volume mass injection. More... | |
| void | cs_volume_mass_injection_eval (int nvar, cs_lnum_t ncesmp, int itypsm[], cs_real_t smacel[]) |
| Evaluate contributions to volume mass injection. More... | |
| void | cs_volume_mass_injection_get_arrays (const cs_field_t *f, cs_lnum_t *ncesmp, cs_lnum_t **icetsm, int **itpsmp, cs_real_t **smcelp, cs_real_t **gamma) |
| Return pointers to the mass source term arrays. More... | |
Volume mass injection and associated source terms computation.
| void cs_f_volume_mass_injection_get_arrays | ( | int | var_id, |
| cs_lnum_t * | ncesmp, | ||
| cs_lnum_t ** | icetsm, | ||
| int ** | itpsmp, | ||
| cs_real_t ** | smcelp | ||
| void cs_volume_mass_injection_build_lists | ( | cs_lnum_t | n_cells, |
| cs_lnum_t | cell_num[], | ||
| int | cell_zone_id[] | ||
| [in] | n_cells | number of cells in mass source term zones |
| [out] | cell_num | numbers (1-based) cells in mass source term zones |
| [out] | cell_zone_id | associated zone ids |
| [in] | itypsm | mass source type for the working variable size: [nvar][ncesmp] |
| [in] | smacel | values of the variables associated to the mass source (for the pressure variable, smacel is the mass flux) size: [nvar][ncesmp] |
| void cs_volume_mass_injection_flag_zones | ( | void | ) |
This is necessary for the reverse zone indexing required by the legacy code to function with defintions that are partially unrolled an not purely zone-based.
| void cs_volume_mass_injection_get_arrays | ( | const cs_field_t * | f, |
| cs_real_t ** | smcelp, | ||
| cs_real_t ** | gamma | ||
| [in] | f | pointer to associated field |
| [out] | ncesmp | number of cells with mass source terms |
| [out] | icetsm | pointet to source mass cells list (1-based numbering) |
| [out] | itpsmp | mass source type for the working variable |
| [out] | s_type | mass source types (0: ambient value, 1: s_val value) |
| [out] | smcelp | pointer to mass source values |
| [out] | gamma | pointer to flow mass value |
