#include "cs_defs.h"#include <assert.h>#include <ctype.h>#include <errno.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_mem.h"#include "cs_tree.h"
Include dependency graph for cs_tree.c:Functions | |
| cs_tree_node_t * | cs_tree_node_create (const char *name) |
| Create an empty node. More... | |
| void | cs_tree_node_free (cs_tree_node_t **pnode) |
| Free a branch in a tree starting from a node. More... | |
| void | cs_tree_node_set_name (cs_tree_node_t *node, const char *name) |
| Name or rename a node. More... | |
| cs_tree_node_t * | cs_tree_node_get_child (cs_tree_node_t *node, const char *name) |
| Return a child node with a given name. More... | |
| cs_tree_node_t * | cs_tree_node_get_next_of_name (cs_tree_node_t *node) |
| Return the next sibling node with the same name (type) as a given node. More... | |
| const char * | cs_tree_node_get_tag (cs_tree_node_t *node, const char *tag) |
| Search for a child node (used as a tag) with a given name, and return its associated string value. More... | |
| void | cs_tree_node_set_tag (cs_tree_node_t *node, const char *tag, const char *tag_str) |
| Assign a tag to a given node. More... | |
| const char * | cs_tree_node_get_value_str (cs_tree_node_t *node) |
| Return a character string value associated to a node if present. More... | |
| void | cs_tree_node_set_value_str (cs_tree_node_t *node, const char *val) |
| Assign a character string value to a node. More... | |
| const bool * | cs_tree_node_get_values_bool (cs_tree_node_t *node) |
| Return array of boolean values associated to a node if present. More... | |
| void | cs_tree_node_set_values_bool (cs_tree_node_t *node, int n, const bool *val) |
| Assign an array of boolean values to node. More... | |
| const int * | cs_tree_node_get_values_int (cs_tree_node_t *node) |
| Return an array of integer values associated to a node if present. More... | |
| void | cs_tree_node_set_values_int (cs_tree_node_t *node, int n, const int *val) |
| Assign an array of integer values to a node. More... | |
| const cs_real_t * | cs_tree_node_get_values_real (cs_tree_node_t *node) |
| Return an array of real values associated to a node if present. More... | |
| void | cs_tree_node_set_values_real (cs_tree_node_t *node, int n, const cs_real_t *val) |
| Assign an array of real values to a node. More... | |
| const char * | cs_tree_node_get_child_value_str (cs_tree_node_t *node, const char *child_name) |
| Return a string value associated to a child node if present. More... | |
| const bool * | cs_tree_node_get_child_values_bool (cs_tree_node_t *node, const char *child_name) |
| Return array of boolean values associated to a child node if present. More... | |
| const int * | cs_tree_node_get_child_values_int (cs_tree_node_t *node, const char *child_name) |
| Return an array of integer values associated to a child node if present. More... | |
| const cs_real_t * | cs_tree_node_get_child_values_real (cs_tree_node_t *node, const char *child_name) |
| Return an array of real values associated to a child node if present. More... | |
| cs_tree_node_t * | cs_tree_node_get_sibling_with_tag (cs_tree_node_t *node, const char *tag, const char *tag_value) |
| Retrieve the pointer to a node with a child having a given (character string) tag value. More... | |
| void | cs_tree_node_dump (cs_log_t log, int depth, const cs_tree_node_t *node) |
| Dump a cs_tree_node_t structure. More... | |
| cs_tree_node_t * | cs_tree_add_node (cs_tree_node_t *node, const char *path) |
| Add a node to a tree. More... | |
| cs_tree_node_t * | cs_tree_get_node (cs_tree_node_t *node, const char *path) |
| Retrieve the pointer to a node matching a given path. More... | |
| int | cs_tree_get_node_count (cs_tree_node_t *node, const char *path) |
| Count number of nodes sharing a given path. More... | |
| cs_tree_node_t * | cs_tree_add_child (cs_tree_node_t *parent, const char *name) |
| Create and add a node in a tree below the given parent node. More... | |
| cs_tree_node_t * | cs_tree_add_sibling (cs_tree_node_t *sibling, const char *name) |
| Create and add a node in a tree at the right of the given node. More... | |
| cs_tree_node_t * | cs_tree_find_node (cs_tree_node_t *root, const char *sub_path) |
| Retrieve the pointer to a node matching a given sub-path. More... | |
| cs_tree_node_t * | cs_tree_find_node_next (cs_tree_node_t *root, cs_tree_node_t *current, const char *sub_path) |
| Retrieve the pointer to the next node matching a given sub-path and following a given node in a depth-first order. More... | |
| cs_tree_node_t * | cs_tree_find_node_simple (cs_tree_node_t *root, const char *name) |
| Retrieve the pointer to a node's descendants matching a given name. More... | |
| cs_tree_node_t * | cs_tree_find_node_next_simple (cs_tree_node_t *root, cs_tree_node_t *current, const char *name) |
| Retrieve the pointer to the next node with a given name and following a given node in a depth-first order. More... | |
| int | cs_tree_get_sub_node_count (cs_tree_node_t *root, const char *sub_path) |
| Count a node's descendants matching a given sub-path. More... | |
| int | cs_tree_get_sub_node_count_simple (cs_tree_node_t *root, const char *name) |
| Count a node's descendants with a given name. More... | |
| void | cs_tree_dump (cs_log_t log, int depth, const cs_tree_node_t *node) |
| Dump a cs_tree_node_t structure starting from the node "root". More... | |
Tree structure used to store data and settings.
| cs_tree_node_t* cs_tree_add_child | ( | cs_tree_node_t * | parent, |
| const char * | name | ||
Create and add a node in a tree below the given node.
| [in,out] | parent | pointer to the parent node to handle. |
| [in] | name | name of the node to add |
| cs_tree_node_t* cs_tree_add_node | ( | cs_tree_node_t * | node, |
| const char * | path | ||
This node is located at "path" from the given node, with the path separator indicated by a "/".
Exits on error if a node already exists on this path.
| [in,out] | node | pointer to the node where we start searching |
| [in] | path | string describing the path access |
| cs_tree_node_t* cs_tree_add_sibling | ( | cs_tree_node_t * | sibling, |
| [in,out] | sibling | pointer to the sibling node to handle |
| void cs_tree_dump | ( | cs_log_t | log, |
| int | depth, | ||
| const cs_tree_node_t * | node | ||
Dump a cs_tree_node_t structure starting from a given node.
| [in] | log | indicate which log file to use |
| [in] | depth | starting depth in the tree |
| [in] | node | pointer to a cs_tree_node_t to dump |
| cs_tree_node_t* cs_tree_find_node | ( | cs_tree_node_t * | root, |
| const char * | sub_path | ||
This node is located at "path" from the given node or one of its descendants, with the path separator indicated by a "/".
In case of multiple nodes sharing the given path, the first such node is returned, using a depth-first search.
| [in] | root | pointer to the root node where we start searching |
| [in] | sub_path | string describing the path access |
| cs_tree_node_t* cs_tree_find_node_next | ( | cs_tree_node_t * | root, |
| cs_tree_node_t * | current, | ||
If current is NULL, this function behaves as cs_tree_find_node.
| [in] | current | pointer to the current node |
| cs_tree_node_t* cs_tree_find_node_next_simple | ( | cs_tree_node_t * | root, |
This function is similar to cs_tree_find_node_next, but is simpler (as it assumes a simple name instead of a more general path) and should thus be faster.
| [in] | name | node name searched for |
| cs_tree_node_t* cs_tree_find_node_simple | ( | cs_tree_node_t * | root, |
This function is similar to cs_tree_find_node, but is simpler (as it assumes a simple name instead of a more general path) and should thus be faster.
| cs_tree_node_t* cs_tree_get_node | ( | cs_tree_node_t * | node, |
In case of multiple nodes sharing the given path, the first such node is returned.
| [in] | node | pointer to the node where we start searching |
| int cs_tree_get_node_count | ( | cs_tree_node_t * | node, |
| int cs_tree_get_sub_node_count | ( | cs_tree_node_t * | root, |
These nodes are located at "path" from the given node or one of its descendants, with the path separator indicated by a "/".
| int cs_tree_get_sub_node_count_simple | ( | cs_tree_node_t * | root, |
This function is similar to cs_tree_get_sub_node_count, but is simpler (as it assumes a simple name instead of a more general path) and should thus be faster.
| cs_tree_node_t* cs_tree_node_create | ( | const char * | name | ) |
Only the name is assigned if given
| [in] | name | name of the node, or NULL |
| void cs_tree_node_dump | ( | cs_log_t | log, |
| int | depth, | ||
| [in] | depth | shift to apply when printing |
| void cs_tree_node_free | ( | cs_tree_node_t ** | pnode | ) |
If the node is the root of the tree, the whole tree is freed.
| [in,out] | pnode | pointer to a pointer to a cs_tree_node_t to free |
| cs_tree_node_t* cs_tree_node_get_child | ( | cs_tree_node_t * | node, |
The child node must be located directly under the given node (i.e. it is a child, not a grand-child or beyond).
This function is similar to cs_tree_get_node, but is simpler (albeit more restricted in scope) and may be faster in cases where one level of the tree is searched at a time.
In case of multiple children sharing the given name, the first such node is returned.
| [in] | node | pointer to the given node |
| [in] | name | name of child node |
| const char* cs_tree_node_get_child_value_str | ( | cs_tree_node_t * | node, |
| const char * | child_name | ||
The behavior is similar to that of cs_tree_node_get_value_str.
| [in] | node | pointer to a cs_tree_node_t to access, or NULL |
| [in] | child_name | name of child node |
| const bool* cs_tree_node_get_child_values_bool | ( | cs_tree_node_t * | node, |
The behavior is similar to that of cs_tree_node_get_values_bool.
| const int* cs_tree_node_get_child_values_int | ( | cs_tree_node_t * | node, |
The behavior is similar to that of cs_tree_node_get_values_int.
| const cs_real_t* cs_tree_node_get_child_values_real | ( | cs_tree_node_t * | node, |
The behavior is similar to that of cs_tree_node_get_values_real.
| cs_tree_node_t* cs_tree_node_get_next_of_name | ( | cs_tree_node_t * | node | ) |
The first node of a series is obtained using cs_tree_get_node.
| [in] | node | pointer to the starting node |
| cs_tree_node_t* cs_tree_node_get_sibling_with_tag | ( | cs_tree_node_t * | node, |
| const char * | tag, | ||
| const char * | tag_value | ||
This node is searched for among siblings of a given node sharing the same path (i.e. the same name).
Using the following example tree:
/ section1 section2 entry label (value = a) entry label (value = b)
Using cs_tree_get_node(node, "section2/entry") will return the first node with path "section2/entry" (which has a child named "label" with value a).
Using cs_tree_node_get_sibling_with_tag(node, "label", "a") from that node will return the same node, while cs_tree_node_get_sibling_with_tag(node, "label", "b") will return the second "section2/entry" node.
This function can be called from any sibling (not necessarily the first).
| [in] | tag | name of the required "tag" child |
| [in] | tag_value | value of the required "tag" child |
| const char* cs_tree_node_get_tag | ( | cs_tree_node_t * | node, |
| const char * | tag | ||
If the child "tag" node does not exist, NULL is returned.
The CS_TREE_NODE_TAG flag is set for child nodes accessed by this function. It is currently only relevant for possible mapping to XML.
| [in] | tag | name of child node used as tag |
| const char* cs_tree_node_get_value_str | ( | cs_tree_node_t * | node | ) |
If the node was never accessed before and the value type was not defined, it is set to CS_TREE_NODE_CHAR. If it was previously converted to a different type, an error is returned.
| const bool* cs_tree_node_get_values_bool | ( | cs_tree_node_t * | node | ) |
If the value type was not defined, or defined as a string, values are converted and the type flag set to CS_TREE_NODE_BOOL. If it was previously accessed (and converted) using a different type, an error is returned.
The following strings (case-independent) are converted to "true": "true", "yes", "on", "1". All other strings are converted to "false".
| const int* cs_tree_node_get_values_int | ( | cs_tree_node_t * | node | ) |
If the value type was not defined, or defined as a string, values are converted and the type flag set to CS_TREE_NODE_INT. If it was previously accessed (and converted) using a different type, an error is returned.
| const cs_real_t* cs_tree_node_get_values_real | ( | cs_tree_node_t * | node | ) |
If the value type was not defined, or defined as a string, values are converted and the type flag set to CS_TREE_NODE_REAL. If it was previously accessed (and converted) using a different type, an error is returned.
| void cs_tree_node_set_name | ( | cs_tree_node_t * | node, |
| [in,out] | node | pointer to a cs_tree_node_t to modify |
| [in] | name | name to set |
| void cs_tree_node_set_tag | ( | cs_tree_node_t * | node, |
| const char * | tag_str | ||
A tag is simply a string-valued child node.
The CS_TREE_NODE_TAG flag is also set for this child. It is currently only relevant for possible mapping to XML.
| [in,out] | node | pointer to the given node |
| [in] | tag_str | character string to be copied to tag |
| void cs_tree_node_set_value_str | ( | cs_tree_node_t * | node, |
| const char * | val | ||
The assigned string is copied to the node.
| [in] | val | pointer to character string |
| void cs_tree_node_set_values_bool | ( | cs_tree_node_t * | node, |
| int | n, | ||
| const bool * | val | ||
| [in] | n | number of elements in val |
| [in] | val | array of boolean |
| void cs_tree_node_set_values_int | ( | cs_tree_node_t * | node, |
| int | n, | ||
| const int * | val | ||
The array values are copied to the node.
| [in] | val | array of integers |
| void cs_tree_node_set_values_real | ( | cs_tree_node_t * | node, |
| int | n, | ||
| const cs_real_t * | val | ||
| [in] | val | array of real values |
