#include "cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdarg.h>#include <stdlib.h>#include <string.h>#include <math.h>#include <float.h>#include <mpi.h>#include <ple_locator.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "fvm_nodal.h"#include "fvm_nodal_extract.h"#include "fvm_point_location.h"#include "cs_base.h"#include "cs_boundary_conditions_set_coeffs.h"#include "cs_boundary_zone.h"#include "cs_coupling.h"#include "cs_domain.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_field_default.h"#include "cs_field_operator.h"#include "cs_file_csv_parser.h"#include "cs_geom.h"#include "cs_halo.h"#include "cs_io.h"#include "cs_log.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_connect.h"#include "cs_mesh_location.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_porous_model.h"#include "cs_equation_iterative_solve.h"#include "cs_physical_constants.h"#include "cs_post.h"#include "cs_timer.h"#include "cs_volume_zone.h"#include "cs_porosity_from_scan.h"
Include dependency graph for cs_porosity_from_scan.c:Functions | |
| void | cs_porosity_from_scan_set_file_name (const char *file_name) |
| Set the file name of points for the computation of the porosity from scan. More... | |
| void | cs_porosity_from_scan_set_output_name (const char *output_name) |
| Set the output name for the FVM writer of scan points. More... | |
| void | cs_porosity_from_scan_add_source (const cs_real_t source[3], bool transform) |
| Add a scanner source point. More... | |
| void | cs_ibm_add_sources_by_file_name (const char *file_name) |
| Add the scanner sources from csv file to fill fluid space. More... | |
| void | cs_compute_porosity_from_scan (void) |
| Computes the porosity which is equal to one from a source, radiating sphericaly, and is 0 when touching points of the scan. More... | |
| void cs_compute_porosity_from_scan | ( | void | ) |
Compute the porosity which is equal to one from a source, radiating sphericaly, and is 0 when touching points of the scan.
This function solves the following transport equation on
where
is the radial direction from the source
The boundary conditions on
is an homogeneous Neumann, and a penalisation term is impose in the cell of center
Remarks:
| void cs_ibm_add_sources_by_file_name | ( | const char * | file_name | ) |
| [in] | csv | file containing the (x,y,z) coordinates of each scanner |
| void cs_porosity_from_scan_add_source | ( | const cs_real_t | source[3], |
| bool | transform | ||
| [in] | source | source vector |
| [in] | transform | flag to apply the transformation matrix to the source |
| void cs_porosity_from_scan_set_file_name | ( | const char * | file_name | ) |
| [in] | file_name | name of the file. |
| void cs_porosity_from_scan_set_output_name | ( | const char * | output_name | ) |
| [in] | output_name | name of the output (a suffix will be added) |
