8.1
cs_multigrid_smoother.h
1 #ifndef __CS_MULTIGRID_SMOOTHER_H__
2 #define __CS_MULTIGRID_SMOOTHER_H__
5  * Sparse Linear Equation Solvers
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_halo_perio.h"
36 #include "cs_matrix.h"
37 #include "cs_sles.h"
38 #include "cs_sles_it.h"
45  * Macro definitions
49  * Type definitions
51
52 /* Iterative linear solver context (opaque) */
53
54 typedef struct _cs_multigrid_smoother_t cs_multigrid_smoother_t;
55
56 /*============================================================================
57  * Global variables
59
60 /*=============================================================================
61  * Public function prototypes
62  *============================================================================*/
63
64 /*----------------------------------------------------------------------------*/
78 /*----------------------------------------------------------------------------*/
79
82  int poly_degree,
83  int n_iter);
84
93 /*----------------------------------------------------------------------------*/
94
95 void
97
98 /*----------------------------------------------------------------------------
99  * Setup iterative sparse linear equation solver.
100  *
101  * parameters:
102  * context <-> pointer to iterative sparse linear solver info
103  * (actual type: cs_multigrid_smoother_t *)
104  * name <-- pointer to system name
105  * a <-- associated matrix
106  * verbosity <-- verbosity level
107  *----------------------------------------------------------------------------*/
108
109 void
110 cs_multigrid_smoother_setup(void *context,
111  const char *name,
112  const cs_matrix_t *a,
113  int verbosity);
114
115 /*----------------------------------------------------------------------------
116  * Call iterative sparse linear equation solver.
117  *
118  * parameters:
119  * context <-> pointer to iterative sparse linear solver info
120  * (actual type: cs_multigrid_smoother_t *)
121  * name <-- pointer to system name
122  * a <-- matrix
123  * verbosity <-- verbosity level
124  * precision <-- solver precision
125  * r_norm <-- residual normalization
126  * n_iter --> number of iterations
127  * residual --> residual
128  * rhs <-- right hand side
129  * vx <-> system solution
130  * aux_size <-- number of elements in aux_vectors (in bytes)
131  * aux_vectors --- optional working area (internal allocation if NULL)
132  *
133  * returns:
134  * convergence state
135  *----------------------------------------------------------------------------*/
136
138 cs_multigrid_smoother_solve(void *context,
139  const char *name,
140  const cs_matrix_t *a,
141  int verbosity,
142  double precision,
143  double r_norm,
144  int *n_iter,
145  double *residual,
146  const cs_real_t *rhs,
147  cs_real_t *vx,
148  size_t aux_size,
149  void *aux_vectors);
150
151 /*----------------------------------------------------------------------------
152  * Free iterative sparse linear equation solver setup context.
153  *
154  * This function frees resolution-related data, such as
155  * buffers and preconditioning but does not free the whole context,
156  * as info used for logging (especially performance data) is maintained.
157
158  * parameters:
159  * context <-> pointer to iterative sparse linear solver info
160  * (actual type: cs_multigrid_smoother_t *)
161  *----------------------------------------------------------------------------*/
162
163 void
165
166 /*----------------------------------------------------------------------------
167  * Log sparse linear equation solver info.
168  *
169  * parameters:
170  * context <-> pointer to iterative sparse linear solver info
171  * (actual type: cs_multigrid_smoother_t *)
172  * log_type <-- log type
173  *----------------------------------------------------------------------------*/
174
175 void
176 cs_multigrid_smoother_log(const void *context,
177  cs_log_t log_type);
178
179 /*----------------------------------------------------------------------------
180  * Return iterative solver type.
181  *
182  * parameters:
183  * context <-- pointer to iterative solver info and context
184  *
185  * returns:
186  * selected solver type
187  *----------------------------------------------------------------------------*/
188
191
192 /*----------------------------------------------------------------------------*/
193
195
196 #endif /* __CS_MULTIGRID_SMOOTHER_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
cs_log_t
Definition: cs_log.h:48
Definition: cs_matrix.h:110
cs_sles_it_t * cs_multigrid_smoother_create(cs_sles_it_type_t smoother_type, int poly_degree, int n_iter)
Create iterative sparse linear system solver info and context used as a smoother in a multigrid solve...
Definition: cs_multigrid_smoother.c:1933
cs_sles_convergence_state_t cs_multigrid_smoother_solve(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Definition: cs_multigrid_smoother.c:2181
Definition: cs_multigrid_smoother.h:54
cs_sles_it_type_t cs_multigrid_smoother_get_type(const cs_multigrid_smoother_t *context)
void cs_multigrid_smoother_free(void *context)
void cs_multigrid_smoother_destroy(void **context)
Destroy iterative sparse linear system solver info and context used as a smoother in a multigrid solv...
void cs_multigrid_smoother_setup(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Setup iterative sparse linear equation solver in case of used as a multigrid smoother.
Definition: cs_multigrid_smoother.c:2042
void cs_multigrid_smoother_log(const void *context, cs_log_t log_type)
Definition: cs_sles.h:56
struct _cs_sles_it_t cs_sles_it_t
Definition: cs_sles_it.h:86
cs_sles_it_type_t
Definition: cs_sles_it.h:55
