#include <stdarg.h>
#include "MEDCouplingUMesh.hxx"
| cs_medcoupling_mesh_t * | cs_medcoupling_mesh_from_base (cs_mesh_t *csmesh, const char *name, const char *selection_criteria, int elt_dim, int use_bbox) |
| | create a new cs_medcoupling_mesh_t instance based on cs_mesh_t More...
| cs_medcoupling_mesh_t * | cs_medcoupling_mesh_from_ids (cs_mesh_t *csmesh, const char *name, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int elt_dim, int use_bbox) |
| void | cs_medcoupling_mesh_destroy (cs_medcoupling_mesh_t *mesh) |
| | Destroy a cs_medcoupling_mesh_t. More...
| void | cs_medcoupling_mesh_destroy_all (void) |
| | Destroy all cs_medcoupling_mesh_t instances. More...
| int | cs_medcoupling_mesh_get_dim (cs_medcoupling_mesh_t *m) |
| | Return a cs_medcoupling_mesh_t structure's spatial dimension. More...
| cs_lnum_t | cs_medcoupling_mesh_get_n_elts (cs_medcoupling_mesh_t *m) |
| | Return a cs_medcoupling_mesh_t structure's number of elements. More...
| const cs_lnum_t * | cs_medcoupling_mesh_get_elt_list (cs_medcoupling_mesh_t *m) |
| | Return a cs_medcoupling_mesh_t structure's (parent) elements list. More...
| cs_lnum_t | cs_medcoupling_mesh_get_n_vertices (cs_medcoupling_mesh_t *m) |
| | Return a cs_medcoupling_mesh_t structure's number of vertices. More...
| const cs_lnum_t * | cs_medcoupling_mesh_get_vertex_list (cs_medcoupling_mesh_t *m) |
| | Return a cs_medcoupling_mesh_t structure's (parent) vertices list. More...
| const cs_lnum_t * | cs_medcoupling_mesh_get_connectivity (cs_medcoupling_mesh_t *m) |
| MEDCouplingUMesh * | cs_medcoupling_create_plane_mesh (const cs_real_t origin[], const cs_real_t normal[], const cs_real_t length1, const cs_real_t length2) |
| | Returns a pointer to a MEDCouplingUMesh of a plane. More...
| MEDCouplingUMesh * | cs_medcoupling_create_disc_mesh (const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius, const int n_sectors) |
| | Returns a pointer to a MEDCouplingUMesh of a disc. More...
| MEDCouplingUMesh * | cs_medcoupling_create_annulus_mesh (const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius1, const cs_real_t radius2, const int n_sectors) |
| | Returns a pointer to a MEDCouplingUMesh of an annulus. More...
◆ cs_medcoupling_create_annulus_mesh()
- Parameters
| [in] | origin | Annulus origin coordinates |
| [in] | normal | Annulus normal vector |
| [in] | radius1 | Annulus inner radius |
| [in] | radius2 | Annulus outer radius |
| [in] | n_sectors | Number of sectors for discretization. If negative, default value of 36 is taken. |
- Returns
- pointer to the MEDCouplingUMesh structure.
◆ cs_medcoupling_create_disc_mesh()
| MEDCouplingUMesh* cs_medcoupling_create_disc_mesh |
const cs_real_t |
origin[], |
const cs_real_t |
normal[], |
const cs_real_t |
radius, |
const int |
n_sectors |
- Parameters
| [in] | origin | Disc origin coordinates |
| [in] | normal | Disc normal vector |
| [in] | radius | Disc radius |
- Returns
◆ cs_medcoupling_create_plane_mesh()
- Parameters
| [in] | origin | Plane origin coordinates |
| [in] | normal | Plane normal vector |
| [in] | length1 | Plane's edge length along first axis |
| [in] | length2 | Plane's edge length along second axis |
- Returns
◆ cs_medcoupling_mesh_destroy()
◆ cs_medcoupling_mesh_destroy_all()
| void cs_medcoupling_mesh_destroy_all |
void |
◆ cs_medcoupling_mesh_from_base()
| cs_medcoupling_mesh_t* cs_medcoupling_mesh_from_base |
cs_mesh_t * |
csmesh, |
const char * |
name, |
const char * |
selection_criteria, |
int |
elt_dim, |
int |
use_bbox |
- Parameters
| [in] | csmesh | pointer to cs_mesh_t instance |
| [in] | name | name of the mesh |
| [in] | selection_criteria | selection criteria string |
| [in] | elt_dim | dimension of elements (2: faces, 3: cells) |
| [in] | use_bbox | Use a reduced bounding box |
- Returns
- pointer to the newly created cs_medcoupling_mesh_t struct
◆ cs_medcoupling_mesh_from_ids()
- Parameters
| [in] | n_elts | local number of elements |
| [in] | elt_ids | list of local elements |
| [in] | use_bbox | use a reduced bounding box |
- Returns
◆ cs_medcoupling_mesh_get_connectivity()
- Parameters
- Returns
- ids of associated elements, or NULL
◆ cs_medcoupling_mesh_get_dim()
- Parameters
- Returns
- associated spatial dimension
◆ cs_medcoupling_mesh_get_elt_list()
- Parameters
- Returns
◆ cs_medcoupling_mesh_get_n_elts()
- Parameters
- Returns
- associated number of elements
◆ cs_medcoupling_mesh_get_n_vertices()
- Parameters
- Returns
- associated number of vertices
◆ cs_medcoupling_mesh_get_vertex_list()
- Parameters
- Returns
- ids of associated vertices, or NULL if all or no local vertices o parent mesh are present.
