8.1
cs_medcoupling_mesh.hxx
1 #ifndef __CS_MEDCOUPLING_MESH_HXX__
2 #define __CS_MEDCOUPLING_MESH_HXX__
5  * Usage of MEDCoupling base components.
30 #include "cs_defs.h"
36 #include <stdarg.h>
37 #include <stdio.h>
38 #include <stdlib.h>
39 #include <string.h>
41 #include "cs_mesh.h"
43 /*----------------------------------------------------------------------------
44  * MEDCOUPLING library headers
45  *----------------------------------------------------------------------------*/
46
47 #if defined(HAVE_MEDCOUPLING)
48
49 #include "MEDCouplingUMesh.hxx"
50
51 using namespace MEDCoupling;
52
53 #endif
54
56
58  * MEDCoupling mesh structure
59  *----------------------------------------------------------------------------*/
60
61 typedef struct {
62
63  char *sel_criteria; /* Element selection criteria
64  (if provided) */
65
66  int elt_dim; /* Element dimension */
67
68  cs_lnum_t n_elts; /* Number of coupled elements */
69  cs_lnum_t *elt_list; /* List of associated elements
70  (0 to n-1) */
71
72  cs_lnum_t n_vtx; /* Number of vertices */
73  cs_lnum_t *vtx_list; /* List of associated vertices
74  (0 to n-1), or NULL */
75
76  cs_lnum_t *new_to_old; /* Connectivity used if only a section of
77  the mesh is read */
78
79  cs_real_t *bbox; /* Bounding box to optimize search */
80
81 #if defined(HAVE_MEDCOUPLING)
82  MEDCouplingUMesh *med_mesh; /* MED mesh structure */
83 #else
84  void *med_mesh;
85 #endif
86
88
89 /*=============================================================================
90  * Public functions
91  *============================================================================*/
92
93 /*----------------------------------------------------------------------------*/
105 /*----------------------------------------------------------------------------*/
106
109  const char *name,
110  const char *selection_criteria,
111  int elt_dim,
112  int use_bbox);
113
114 /*----------------------------------------------------------------------------*/
128
131  const char *name,
132  cs_lnum_t n_elts,
133  const cs_lnum_t elt_ids[],
134  int elt_dim,
135  int use_bbox);
136
137 /*----------------------------------------------------------------------------*/
143 /*----------------------------------------------------------------------------*/
144
145 void
147
148 /*----------------------------------------------------------------------------*/
152 /*----------------------------------------------------------------------------*/
153
154 void
156
157 /*----------------------------------------------------------------------------*/
166
167 int
169
170 /*----------------------------------------------------------------------------*/
178 /*----------------------------------------------------------------------------*/
179
180 cs_lnum_t
182
183 /*----------------------------------------------------------------------------*/
191 /*----------------------------------------------------------------------------*/
192
193 const cs_lnum_t *
195
196 /*----------------------------------------------------------------------------*/
204 /*----------------------------------------------------------------------------*/
205
206 cs_lnum_t
208
209 /*----------------------------------------------------------------------------*/
218 /*----------------------------------------------------------------------------*/
219
220 const cs_lnum_t *
222
223 /*----------------------------------------------------------------------------*/
231 /*----------------------------------------------------------------------------*/
232
233 const cs_lnum_t *
235
236 /*----------------------------------------------------------------------------*/
247 /*----------------------------------------------------------------------------*/
248
249 #if defined(HAVE_MEDCOUPLING)
250 MEDCouplingUMesh *
251 #else
252 void *
253 #endif
255  const cs_real_t normal[],
256  const cs_real_t length1,
257  const cs_real_t length2);
258
259 /*----------------------------------------------------------------------------*/
271 /*----------------------------------------------------------------------------*/
272
273 #if defined(HAVE_MEDCOUPLING)
274 MEDCouplingUMesh *
275 #else
276 void *
277 #endif
279  const cs_real_t normal[],
280  const cs_real_t radius,
281  const int n_sectors);
282
283 /*----------------------------------------------------------------------------*/
296 /*----------------------------------------------------------------------------*/
297
298 #if defined(HAVE_MEDCOUPLING)
299 MEDCouplingUMesh *
300 #else
301 void *
302 #endif
304  const cs_real_t normal[],
305  const cs_real_t radius1,
306  const cs_real_t radius2,
307  const int n_sectors);
308
309 /*----------------------------------------------------------------------------*/
310
312
313 #endif /* __CS_MEDCOUPLING_MESH_HXX__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
const cs_lnum_t * cs_medcoupling_mesh_get_vertex_list(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's (parent) vertices list.
Definition: cs_medcoupling_mesh.cxx:1124
const cs_lnum_t * cs_medcoupling_mesh_get_connectivity(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's (parent) elements list.
Definition: cs_medcoupling_mesh.cxx:1145
cs_lnum_t cs_medcoupling_mesh_get_n_elts(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's number of elements.
Definition: cs_medcoupling_mesh.cxx:1062
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_ids(cs_mesh_t *csmesh, const char *name, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int elt_dim, int use_bbox)
create a new cs_medcoupling_mesh_t instance based on cs_mesh_t
Definition: cs_medcoupling_mesh.cxx:948
cs_lnum_t cs_medcoupling_mesh_get_n_vertices(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's number of vertices.
Definition: cs_medcoupling_mesh.cxx:1103
void cs_medcoupling_mesh_destroy(cs_medcoupling_mesh_t *mesh)
Destroy a cs_medcoupling_mesh_t.
Definition: cs_medcoupling_mesh.cxx:995
MEDCouplingUMesh * cs_medcoupling_create_disc_mesh(const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius, const int n_sectors)
Returns a pointer to a MEDCouplingUMesh of a disc.
Definition: cs_medcoupling_mesh.cxx:1246
MEDCouplingUMesh * cs_medcoupling_create_annulus_mesh(const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius1, const cs_real_t radius2, const int n_sectors)
Returns a pointer to a MEDCouplingUMesh of an annulus.
Definition: cs_medcoupling_mesh.cxx:1343
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_base(cs_mesh_t *csmesh, const char *name, const char *selection_criteria, int elt_dim, int use_bbox)
Definition: cs_medcoupling_mesh.cxx:889
void cs_medcoupling_mesh_destroy_all(void)
Destroy all cs_medcoupling_mesh_t instances.
Definition: cs_medcoupling_mesh.cxx:1017
int cs_medcoupling_mesh_get_dim(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's spatial dimension.
Definition: cs_medcoupling_mesh.cxx:1042
MEDCouplingUMesh * cs_medcoupling_create_plane_mesh(const cs_real_t origin[], const cs_real_t normal[], const cs_real_t length1, const cs_real_t length2)
Returns a pointer to a MEDCouplingUMesh of a plane.
Definition: cs_medcoupling_mesh.cxx:1173
const cs_lnum_t * cs_medcoupling_mesh_get_elt_list(cs_medcoupling_mesh_t *m)
Definition: cs_medcoupling_mesh.cxx:1082
Definition: mesh.f90:26
Definition: cs_medcoupling_mesh.hxx:61
char * sel_criteria
Definition: cs_medcoupling_mesh.hxx:63
cs_lnum_t n_vtx
Definition: cs_medcoupling_mesh.hxx:72
cs_lnum_t n_elts
Definition: cs_medcoupling_mesh.hxx:68
cs_lnum_t * vtx_list
Definition: cs_medcoupling_mesh.hxx:73
cs_lnum_t * new_to_old
Definition: cs_medcoupling_mesh.hxx:76
MEDCouplingUMesh * med_mesh
Definition: cs_medcoupling_mesh.hxx:82
int elt_dim
Definition: cs_medcoupling_mesh.hxx:66
cs_lnum_t * elt_list
Definition: cs_medcoupling_mesh.hxx:69
cs_real_t * bbox
Definition: cs_medcoupling_mesh.hxx:79
Definition: cs_mesh.h:85
