8.1
cs_matrix_default.h File Reference
#include "cs_halo.h"
#include "cs_matrix.h"
#include "cs_numbering.h"
#include "cs_halo_perio.h"
+ Include dependency graph for cs_matrix_default.h:
void cs_matrix_vector_native_multiply (bool symmetric, cs_lnum_t db_size, cs_lnum_t eb_size, int f_id, const cs_real_t *dam, const cs_real_t *xam, cs_real_t *vx, cs_real_t *vy)
void cs_matrix_initialize (void)
void cs_matrix_finalize (void)
void cs_matrix_update_mesh (void)
cs_matrix_tcs_matrix_default (bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
cs_matrix_tcs_matrix_msr (bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
cs_matrix_tcs_matrix_native (bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
cs_matrix_tcs_matrix_external (const char *type_name, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
 Return matrix wrapper for external library for a given fill type. More...
cs_matrix_tcs_matrix_copy_to_external (cs_matrix_t *src, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
 Copy base matrix to external library matrix type for given fill type. More...
void cs_matrix_default_set_tuned (cs_matrix_t *m)
void cs_matrix_set_tuning_runs (int n_min_products, double t_measure)
void cs_matrix_get_tuning_runs (int *n_min_products, double *t_measure)
void cs_matrix_default_set_type (cs_matrix_fill_type_t fill_type, cs_matrix_type_t type)
 Set default matrix type for a given fill type. More...
const cs_gnum_tcs_matrix_get_block_row_g_id (const cs_matrix_t *m)
 Return a (0-based) global block row numbering for a given matrix. More...
cs_matrix_tcs_matrix_set_coefficients_by_assembler (const cs_field_t *f, cs_matrix_type_t type, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa)
 Assign coefficients to a matrix using a matrix assembler. More...
◆ cs_matrix_copy_to_external()
cs_matrix_t* cs_matrix_copy_to_external ( cs_matrix_t src,
bool  symmetric,
Coefficients and matching structures are not copied or created.
This function is intended to allow sharing of a base structure or assembler with an external library matrix wrapper, so as to allow efficient coefficient assignment, but with external coefficient handling.
The matrix shoud be converted to the desired external type after calling this function, so that it can the be accessed using cs_matrix_external.
[in]symmetricIndicates if matrix coefficients are symmetric
[in]diag_block_sizeBlock sizes for diagonal
[in]extra_diag_block_sizeBlock sizes for extra diagonal
pointer to native matrix adapted to fill type
◆ cs_matrix_default()
cs_matrix_t* cs_matrix_default ( bool  symmetric,
◆ cs_matrix_default_set_tuned()
void cs_matrix_default_set_tuned ( cs_matrix_t m)
◆ cs_matrix_default_set_type()
void cs_matrix_default_set_type ( cs_matrix_fill_type_t  fill_type,
[in]filltype Fill type for which tuning behavior is set
[in]typeMatrix type to use
◆ cs_matrix_external()
cs_matrix_t* cs_matrix_external ( const char *  type_name,
bool  symmetric,
[in]type_nameMatrix type name
[in]symmetricIndicates if coefficients are symmetric
Pointer to matrix matching requested type
◆ cs_matrix_finalize()
void cs_matrix_finalize ( void  )
◆ cs_matrix_get_block_row_g_id()
const cs_gnum_t* cs_matrix_get_block_row_g_id ( const cs_matrix_t m)
The numbering is built or updated if not previously used, or if the previous call considered a differeent matrix, and is simply returned otherwise. In other words, this works as a matrix global numbering cache.
[in]massociated matrix
pointer to requested global numbering
◆ cs_matrix_get_tuning_runs()
void cs_matrix_get_tuning_runs ( int *  n_min_products,
double *  t_measure
◆ cs_matrix_initialize()
void cs_matrix_initialize ( void  )
◆ cs_matrix_msr()
cs_matrix_t* cs_matrix_msr ( bool  symmetric,
◆ cs_matrix_native()
cs_matrix_t* cs_matrix_native ( bool  symmetric,
◆ cs_matrix_set_coefficients_by_assembler()
cs_matrix_t* cs_matrix_set_coefficients_by_assembler ( const cs_field_t f,
bool  symmetric,
const cs_real_t da,
const cs_real_t xa
[in]fpointer to associated field
[in]typematrix type
[in]symmetricis matrix symmetric ?
[in]diag_block_sizeblock sizes for diagonal
[in]extra_diag_block_sizeblock sizes for extra diagonal
[in]dadiagonal values (NULL if zero)
[in]xaextradiagonal values (NULL if zero) casts as: xa[n_edges] if symmetric, xa[n_edges][2] if non symmetric
pointer to associated matrix structure
[in]typematrix type
[in]diag_block_sizeblock sizes for diagonal, or NULL
[in]extra_diag_block_sizeblock sizes for extra diagonal, or NULL
◆ cs_matrix_set_tuning_runs()
void cs_matrix_set_tuning_runs ( int  n_min_products,
double  t_measure
◆ cs_matrix_update_mesh()
void cs_matrix_update_mesh ( void  )
◆ cs_matrix_vector_native_multiply()
void cs_matrix_vector_native_multiply ( bool  symmetric,
cs_lnum_t  db_size,
cs_lnum_t  eb_size,
int  f_id,
const cs_real_t dam,
const cs_real_t xam,
cs_real_t vx,
cs_real_t vy
