8.1
cs_numbering.h
1 #ifndef __CS_NUMBERING_H__
2 #define __CS_NUMBERING_H__
5  * Numbering information for vectorization or multithreading
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_base.h"
36 #include "cs_log.h"
43  * Macro definitions
45
46 /* SIMD unit length */
47 /*------------------*/
48
49 #if defined(__NEC__) && defined(__ve__) /* For NEC Aurora series */
50
51 # define CS_NUMBERING_SIMD_SIZE 256
52
53 #elif defined(SX) && defined(_SX) /* For NEC SX series (at least SX-9) */
54
55 # define CS_NUMBERING_SIMD_SIZE 256
56
57 #elif defined(__AVX512F__) /* For Intel with AVX 512 */
58
59 # define CS_NUMBERING_SIMD_SIZE 64
60
61 #elif defined(HAVE_CUDA) /* For CUDA devices (warp size) */
62
63 # define CS_NUMBERING_SIMD_SIZE 32
64
65 #else
66
67 # define CS_NUMBERING_SIMD_SIZE 4 /* Most current platforms */
68
69 #endif
70
71 /*============================================================================
72  * Type definitions
73  *============================================================================*/
74
75 /* Renumbering types */
76
77 typedef enum {
78
79  CS_NUMBERING_DEFAULT, /* Default numbering */
80  CS_NUMBERING_VECTORIZE, /* Numbered for vectorization */
81  CS_NUMBERING_THREADS /* Numbered for threads */
82
84
85 /* Renumbering structure */
86
87 typedef struct {
88
89  cs_numbering_type_t type; /* Numbering type */
90
91  int vector_size; /* Vector size if vectorized, 1 otherwise */
92
93  int n_threads; /* Number of threads */
94  int n_groups; /* Number of associated groups */
95
96  int n_no_adj_halo_groups; /* number of groups for which only non-ghost
97  entities are adjacent */
98
99  cs_lnum_t n_no_adj_halo_elts; /* Number of elements not adjacent to
100  halo elements */
101
102  cs_lnum_t *group_index; /* For thread t and group g, the start and
103  past-the-end ids for entities in a given
104  group and thread are respectively:
105  group_index[t*n_groups*2 + g] and
106  group_index[t*n_groups*2 + g + 1].
107  (size: n_groups * n_threads * 2) */
108
110
111 /*=============================================================================
112  * Global variable definitions
113  *============================================================================*/
114
115 /* Names for numbering types */
116
117 extern const char *cs_numbering_type_name[];
118
119 /*============================================================================
120  * Public function prototypes for Fortran API
121  *============================================================================*/
122
123 /*=============================================================================
124  * Public function prototypes
125  *============================================================================*/
126
135 /*----------------------------------------------------------------------------*/
136
139
140 /*----------------------------------------------------------------------------*/
150 /*----------------------------------------------------------------------------*/
151
154  int vector_size);
155
156 /*----------------------------------------------------------------------------*/
171 /*----------------------------------------------------------------------------*/
172
174 cs_numbering_create_threaded(int n_threads,
175  int n_groups,
176  cs_lnum_t group_index[]);
177
178 /*----------------------------------------------------------------------------*/
185 /*----------------------------------------------------------------------------*/
186
187 void
189
190 /*----------------------------------------------------------------------------*/
198 /*----------------------------------------------------------------------------*/
199
200 void
202  const char *description,
203  const cs_numbering_t *numbering);
204
205 /*----------------------------------------------------------------------------*/
211 /*----------------------------------------------------------------------------*/
212
213 void
214 cs_numbering_dump(const cs_numbering_t *numbering);
215
216 /*----------------------------------------------------------------------------*/
217
219
220 #endif /* __CS_NUMBERING_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:515
Definition: cs_defs.h:313
cs_log_t
Definition: cs_log.h:48
cs_numbering_t * cs_numbering_create_vectorized(cs_lnum_t n_elts, int vector_size)
Create a default numbering information structure in case of vectorization.
Definition: cs_numbering.c:556
cs_numbering_t * cs_numbering_create_threaded(int n_threads, int n_groups, cs_lnum_t group_index[])
Create a default numbering information structure in case of threading.
Definition: cs_numbering.c:598
void cs_numbering_log_info(cs_log_t log, const char *description, const cs_numbering_t *numbering)
Log information relative to a cs_numbering_t structure.
Definition: cs_numbering.c:658
void cs_numbering_destroy(cs_numbering_t **numbering)
Destroy a numbering information structure.
Definition: cs_numbering.c:635
const char * cs_numbering_type_name[]
Definition: cs_numbering.c:73
cs_numbering_type_t
Definition: cs_numbering.h:77
@ CS_NUMBERING_THREADS
Definition: cs_numbering.h:81
@ CS_NUMBERING_VECTORIZE
Definition: cs_numbering.h:80
@ CS_NUMBERING_DEFAULT
Definition: cs_numbering.h:79
cs_numbering_t * cs_numbering_create_default(cs_lnum_t n_elts)
Create a default numbering information structure.
Definition: cs_numbering.c:520
void cs_numbering_dump(const cs_numbering_t *numbering)
Dump a cs_numbering_t structure.
Definition: cs_numbering.c:746
Definition: cs_numbering.h:87
cs_lnum_t * group_index
Definition: cs_numbering.h:102
Definition: cs_numbering.h:96
int vector_size
Definition: cs_numbering.h:91
Definition: cs_numbering.h:89
int n_threads
Definition: cs_numbering.h:93
int n_groups
Definition: cs_numbering.h:94
Definition: cs_numbering.h:99
