#include "cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdarg.h>#include <string.h>#include <float.h>#include <mpi.h>#include "bft_error.h"#include "bft_mem.h"#include "cs_math.h"
Include dependency graph for cs_math.c:Functions | |
| void | cs_f_math_sym_33_inv_cramer (const cs_real_t s[6], cs_real_t sout[6]) |
| void | cs_f_math_sym_33_product (const cs_real_t s1[6], const cs_real_t s2[6], cs_real_t sout[6]) |
| void | cs_f_math_reduce_sym_prod_33_to_66 (const cs_real_t s[3][3], cs_real_t sout[6][6]) |
| void | cs_f_math_3_normalize (const cs_real_t vin[3], cs_real_t vout[3]) |
| void | cs_math_sym_33_eigen (const cs_real_t m[6], cs_real_t eig_vals[3]) |
| Compute all eigenvalues of a 3x3 symmetric matrix with symmetric storage. More... | |
| void | cs_math_33_eigen (const cs_real_t m[3][3], cs_real_t *eig_ratio, cs_real_t *eig_max) |
| Compute max/min eigenvalues ratio and max. eigenvalue of a 3x3 symmetric matrix with non-symmetric storage. More... | |
| void | cs_math_3_length_unitv (const cs_real_t xa[3], const cs_real_t xb[3], cs_real_t *len, cs_real_3_t unitv) |
| Compute the length (Euclidean norm) between two points xa and xb in a Cartesian coordinate system of dimension 3. More... | |
| double | cs_math_surftri (const cs_real_t xv[3], const cs_real_t xe[3], const cs_real_t xf[3]) |
| Compute the area of the convex_hull generated by 3 points. This corresponds to the computation of the surface of a triangle. More... | |
| double | cs_math_voltet (const cs_real_t xv[3], const cs_real_t xe[3], const cs_real_t xf[3], const cs_real_t xc[3]) |
| Compute the volume of the convex_hull generated by 4 points. This is equivalent to the computation of the volume of a tetrahedron. More... | |
| void | cs_math_33_eig_val_vec (const cs_real_t m_in[3][3], const cs_real_t tol_err, cs_real_t eig_val[restrict 3], cs_real_t eig_vec[restrict 3][3]) |
| Evaluate eigenvalues and eigenvectors of a real symmetric matrix m1[3,3]: m1*m2 = lambda*m2. More... | |
| void | cs_math_fact_lu (cs_lnum_t n_blocks, int b_size, const cs_real_t *a, cs_real_t *a_lu) |
| Compute LU factorization of an array of dense matrices of identical size. More... | |
| void | cs_math_fw_and_bw_lu (const cs_real_t a_lu[], int n, cs_real_t x[], const cs_real_t b[]) |
| Block Jacobi utilities. Compute forward and backward to solve an LU P*P system. More... | |
| void | cs_math_sym_44_factor_ldlt (cs_real_t ldlt[10]) |
| LDL^T: Modified Cholesky decomposition of a 4x4 SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More... | |
| cs_real_t | cs_math_sym_44_partial_solve_ldlt (const cs_real_t ldlt[10], const cs_real_t rhs[4]) |
Mathematical base functions.
| void cs_math_33_eig_val_vec | ( | const cs_real_t | m_in[3][3], |
| const cs_real_t | tol_err, | ||
| cs_real_t | eig_val[restrict 3], | ||
| cs_real_t | eig_vec[restrict 3][3] | ||
Use of Jacobi method for symmetric matrices (adapted from the book Numerical Recipes in C, Chapter 11.1)
| [in] | m_in | matrix of 3x3 real values (initial) |
| [in] | tol_err | absolute tolerance (sum of off-diagonal elements) |
| [out] | eig_val | vector of 3 real values (eigenvalues) |
| [out] | eig_vec | matrix of 3x3 real values (eigenvectors) |
Based on: Oliver K. Smith "eigenvalues of a symmetric 3x3 matrix", Communication of the ACM (April 1961) (Wikipedia article entitled "Eigenvalue algorithm")
| [in] | m | 3x3 matrix |
| [out] | eig_ratio | max/min |
| [out] | eig_max | max. eigenvalue |
inline |
| [in] | xa | coordinate of the first extremity |
| [in] | xb | coordinate of the second extremity |
| [out] | len | pointer to the length of the vector va -> vb |
| [out] | unitv | unitary vector along va -> vb |
| [in] | n_blocks | number of blocks |
| [in] | b_size | block size |
| [in] | a | matrix blocks |
| [out] | a_lu | LU factorizations of matrix blocks |
| [in] | a_lu | matrix LU factorization |
| [in] | n | matrix size |
| [out] | x | solution |
| [out] | b | right hand side |
inline |
| [in] | xv | coordinates of the first vertex |
| [in] | xe | coordinates of the second vertex |
| [in] | xf | coordinates of the third vertex |
| [in] | m | 3x3 symmetric matrix (m11, m22, m33, m12, m23, m13) |
| [out] | eig_vals | size 3 vector |
| void cs_math_sym_44_factor_ldlt | ( | cs_real_t | ldlt[10] | ) |
| [in,out] | ldlt | pointer to matrix coefficients: (m00, m10, m11, m20, m21, m22, m30, m31, m32, m33) in (f00, l10, f11, l20, l21, f22, l30, l31, l32, f33) out |
Here we only need to use the last element of the solution vector, so we return that value only and simplify the computation.
| [in,out] | ldlt | pointer to matrix coefficients: (f00, l10, f11, l20, l21, f22, l30, l31, l32, f33) |
| [in] | rhs | right-hand side |
| double cs_math_voltet | ( | const cs_real_t | xv[3], |
| const cs_real_t | xe[3], | ||
| const cs_real_t | xf[3], | ||
| const cs_real_t | xc[3] | ||
| [in] | xc | coordinates of the fourth vertex |
