1 #ifndef __CS_TIME_TABLE_H__
2 #define __CS_TIME_TABLE_H__
45 typedef struct _cs_time_table_t cs_time_table_t;
104 const char **headers);
124 const char *file_name,
125 const char *separator,
129 const bool ignore_missing_tokens);
146 const char *file_name,
147 const char *separator);
165 const char *file_name,
166 const char *separator,
167 const int n_headers);
191 const char *time_label);
219 bool reset_time_value);
238 bool overwrite_prev);
257 bool overwrite_prev);
299 const char *labels[],
Definition: cs_defs.h:509
Definition: cs_defs.h:319
@ t
void cs_time_table_set_time_col_id(cs_time_table_t *table, const int col_id)
Define the column id for time based on an index.
Definition: cs_time_table.c:519
void cs_time_table_compute_n_time_values_by_label(const char *name, cs_real_t t, const int n_cols, const char *labels[], bool overwrite_prev, cs_real_t *retvals)
Compute values for several columns of a time table for a given abscissa.
Definition: cs_time_table.c:730
void cs_time_table_update_position(cs_time_table_t *table, cs_real_t time, bool reset_time_value)
Update time coefficients used for data interpolation.
Definition: cs_time_table.c:584
void cs_time_table_destroy_all(void)
Free all data structures related to datasets.
Definition: cs_time_table.c:753
void cs_time_table_set_headers(cs_time_table_t *table, const int n_headers, const char **headers)
Set headers labels for a time table. Number of headers needs to be equal to the number of columns,...
Definition: cs_time_table.c:349
cs_time_table_t * cs_time_table_from_csv_file_simple_headers(const char *name, const char *file_name, const char *separator, const int n_headers)
Define a time table from a CSV file. We suppose that all columns are to be read and that missing toke...
Definition: cs_time_table.c:492
cs_time_table_t * cs_time_table_from_csv_file_simple(const char *name, const char *file_name, const char *separator)
Define a time table from a CSV file. We suppose that all columns are to be read, no headers line to s...
Definition: cs_time_table.c:461
cs_time_table_t * cs_time_table_from_csv_file(const char *name, const char *file_name, const char *separator, const int n_headers, const int n_columns, const int *col_idx, const bool ignore_missing_tokens)
Definition: cs_time_table.c:391
cs_time_table_t * cs_time_table_by_name(const char *name)
Get time table based on name.
Definition: cs_time_table.c:307
void cs_time_table_set_time_from_label(cs_time_table_t *table, const char *time_label)
Define the column id for time based on a label.
Definition: cs_time_table.c:536
static cs_real_t CS_TIME_TABLE(const char *name, const char *label)
Compute value from time table based on label and current time. Positions are not updated for the tabl...
Definition: cs_time_table.h:316
cs_real_t cs_time_table_compute_time_value(const char *name, cs_real_t t, const int col, bool overwrite_prev)
Compute value using a given abscissa and a specific column.
Definition: cs_time_table.c:640
void cs_time_table_compute_n_time_values(const char *name, cs_real_t t, const int n_cols, const int cols[], bool overwrite_prev, cs_real_t *retvals)
Definition: cs_time_table.c:699
void cs_time_table_set_offset(cs_time_table_t *table, cs_real_t time_offset)
Set time offset value for a time table.
Definition: cs_time_table.c:329
void cs_time_table_reset_position(cs_time_table_t *table)
Reset time table time value (force search from beginning of table).
Definition: cs_time_table.c:561
cs_time_table_t * cs_time_table_by_name_try(const char *name)
Try to get time table based on name.
Definition: cs_time_table.c:289
cs_real_t cs_time_table_compute_time_value_by_label(const char *name, cs_real_t t, const char *label, bool overwrite_prev)
Compute value using a given abscissa and a label.
Definition: cs_time_table.c:666
char * label
Definition: keywords.h:71
double t_cur
Definition: cs_time_step.h:80
