Macros | |
#define | CS_SLES_AMGX_PREFER_COMM_FROM_MAPS (1 << 0) |
typedef struct _cs_sles_amgx_t | cs_sles_amgx_t |
cs_sles_amgx_t * | cs_sles_amgx_define (int f_id, const char *name) |
Define and associate an AmgX linear system solver for a given field or equation name. More... | |
cs_sles_amgx_t * | cs_sles_amgx_create (void) |
Create AmgX linear system solver info and context. More... | |
void * | cs_sles_amgx_copy (const void *context) |
Create AmgX linear system solver info and context based on existing info and context. More... | |
void | cs_sles_amgx_destroy (void **context) |
Destroy AmgX linear system solver info and context. More... | |
const char * | cs_sles_amgx_get_config (void *context) |
return the solver configuration for an AmgX solver. More... | |
void | cs_sles_amgx_set_config (void *context, const char *config) |
Define the configuration for an AmgX solver. More... | |
const char * | cs_sles_amgx_get_config_file (void *context) |
return the name of the solver configuration file for an AmgX solver. More... | |
void | cs_sles_amgx_set_config_file (void *context, const char *path) |
Set the solver configuration file for an AmgX solver. More... | |
bool | cs_sles_amgx_get_use_device (void *context) |
Define whether an AmgX solver should use the device or host. More... | |
void | cs_sles_amgx_set_use_device (void *context, bool use_device) |
void | cs_sles_amgx_set_flags (void *context, int flags) |
Define additional AmgX solver usage flags. More... | |
int | cs_sles_amgx_get_flags (void *context) |
Query additional AmgX solver usage flags. More... | |
void | cs_sles_amgx_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
Setup AmgX linear equation solver. More... | |
cs_sles_convergence_state_t | cs_sles_amgx_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
Call AmgX linear equation solver. More... | |
void | cs_sles_amgx_free (void *context) |
Free AmgX linear equation solver setup context. More... | |
void | cs_sles_amgx_log (const void *context, cs_log_t log_type) |
Log sparse linear equation solver info. More... | |
void | cs_sles_amgx_library_info (cs_log_t log_type) |
Print information on AmgX library. More... | |
#define CS_SLES_AMGX_PREFER_COMM_FROM_MAPS (1 << 0) |
AmgX wrapper option flags
Use AMGX_comm_from_maps_1_ring instead of AMGX_distribution for parallel matrices when its use seems possible
typedef struct _cs_sles_amgx_t cs_sles_amgx_t |
void* cs_sles_amgx_copy | ( | const void * | context | ) |
[in] | context | pointer to reference info and context (actual type: cs_sles_amgx_t *) |
cs_sles_amgx_t* cs_sles_amgx_create | ( | void | ) |
cs_sles_amgx_t* cs_sles_amgx_define | ( | int | f_id, |
const char * | name | ||
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_amgx_create.
[in] | f_id | associated field id, or < 0 |
[in] | name | associated name if f_id < 0, or NULL |
void cs_sles_amgx_destroy | ( | void ** | context | ) |
[in,out] | context | pointer to AmgX solver info and context (actual type: cs_sles_amgx_t **) |
void cs_sles_amgx_free | ( | void * | context | ) |
[in,out] | context | pointer to AmgX solver info and context (actual type: cs_sles_amgx_t *) |
const char* cs_sles_amgx_get_config | ( | void * | context | ) |
Check the AmgX docummentation for configuration strings syntax.
[in,out] | context | pointer to AmgX solver info and context |
const char* cs_sles_amgx_get_config_file | ( | void * | context | ) |
Check the AmgX docummentation for configuration file syntax.
int cs_sles_amgx_get_flags | ( | void * | context | ) |
[in] | context | pointer to AmgX solver info and context |
bool cs_sles_amgx_get_use_device | ( | void * | context | ) |
By default, the device will be used, but by callingg this function with "use_device = false", only the host will be used.
void cs_sles_amgx_library_info | ( | cs_log_t | log_type | ) |
[in] | log_type | log type |
void cs_sles_amgx_log | ( | const void * | context, |
cs_log_t | log_type | ||
[in] | context | pointer to AmgX solver info and context (actual type: cs_sles_amgx_t *) |
void cs_sles_amgx_set_config | ( | void * | context, |
const char * | config | ||
If this function is not called, a default configuration will be used.
[in] | config | string defining configuration to use |
void cs_sles_amgx_set_config_file | ( | void * | context, |
const char * | path | ||
[in] | path | path to configuration file |
void cs_sles_amgx_set_flags | ( | void * | context, |
int | flags | ||
[in] | flags | flags (sum/bitwise of) for AmgX usage options. |
void cs_sles_amgx_set_use_device | ( | void * | context, |
bool | use_device | ||
[in] | use_device | true for devince, false for host only |
void cs_sles_amgx_setup | ( | void * | context, |
const char * | name, | ||
const cs_matrix_t * | a, | ||
int | verbosity | ||
[in] | name | pointer to system name |
[in] | a | associated matrix |
[in] | verbosity | associated verbosity |
cs_sles_convergence_state_t cs_sles_amgx_solve | ( | void * | context, |
int | verbosity, | ||
double | precision, | ||
double | r_norm, | ||
int * | n_iter, | ||
double * | residue, | ||
const cs_real_t * | rhs, | ||
cs_real_t * | vx, | ||
size_t | aux_size, | ||
void * | aux_vectors | ||
[in] | a | matrix |
[in] | precision | solver precision |
[in] | r_norm | residue normalization |
[out] | n_iter | number of "equivalent" iterations |
[out] | residue | residue |
[in] | rhs | right hand side |
[in,out] | vx | system solution |
[in] | aux_size | number of elements in aux_vectors (in bytes) |
aux_vectors | optional working area (internal allocation if NULL) |
