8.0
cs_notebook.h File Reference
+ Include dependency graph for cs_notebook.h:
void cs_notebook_load_from_file (void)
 Initialize the notebook object (based on cs_tree_node_t). More...
int cs_notebook_parameter_is_present (const char *name, int *editable)
 Check if a parameter value is present. More...
cs_real_t cs_notebook_parameter_value_by_name (const char *name)
 Return a parameter value (real). More...
void cs_notebook_parameter_set_value (const char *name, cs_real_t val)
 Set a parameter value (real) for an editable parameter. More...
int cs_notebook_parameter_get_openturns_status (char *name)
 Indicate whether the parameter is used for a study with openturns. More...
const char * cs_notebook_parameter_get_description (char *name)
 Returns the description of the parameter (GUI defined). More...
int cs_notebook_parameter_get_id (const char *name)
 Get id associated with a notebook parameter. More...
void cs_notebook_get_values (int n, const int ids[], double values[])
 Get a group of notebook variable values. More...
void cs_notebook_set_values (int n, const int ids[], const double values[])
 Set a group of notebook variable values. More...
void cs_notebook_destroy_all (void)
 Destroy the notebook structure. More...
void cs_notebook_log (void)
 Output the notebook info to the setup log. More...
void cs_notebook_uncertain_output (void)
 Write uncertain values to output file. More...
◆ cs_notebook_destroy_all()
void cs_notebook_destroy_all ( void  )
Destroys the structures related to the notebook.
◆ cs_notebook_get_values()
void cs_notebook_get_values ( int  n,
const int  ids[],
double  values[]
[in]nnumber of notebook variables to query
[in]idsids of notebook variables to query (value set to 0 where id < 0)
[out]valuesvalues of notebook variables to query
◆ cs_notebook_load_from_file()
void cs_notebook_load_from_file ( void  )
◆ cs_notebook_log()
void cs_notebook_log ( void  )
◆ cs_notebook_parameter_get_description()
const char* cs_notebook_parameter_get_description ( char *  name)
[in]namename of the parameter
a const char pointer containing the description.
◆ cs_notebook_parameter_get_id()
int cs_notebook_parameter_get_id ( const char *  name)
-1 if not present, id if present
◆ cs_notebook_parameter_get_openturns_status()
int cs_notebook_parameter_get_openturns_status ( char *  name)
Returns an int flag to indicate whether this paramter is used for an OpenTurns study. -1 : The parameter is not used with OpenTurns 0 : The parameter is used as an input from OpenTurns 1 : The parameter is used as an output to OpenTurns
an int flag value
◆ cs_notebook_parameter_is_present()
int cs_notebook_parameter_is_present ( const char *  name,
int *  editable
[out]editable1 if the value is editable, 0 otherwise (optional)
0 if not present, 1 if present
◆ cs_notebook_parameter_set_value()
void cs_notebook_parameter_set_value ( const char *  name,
cs_real_t  val
The name used is the same as the one in the GUI.
[in]valvalue of the parameter
◆ cs_notebook_parameter_value_by_name()
cs_real_t cs_notebook_parameter_value_by_name ( const char *  name)
value of the given parameter
◆ cs_notebook_set_values()
void cs_notebook_set_values ( int  n,
const int  ids[],
[in]nnumber of notebook variables to set
[in]idsids of notebook variables to set (ignored where id < 0)
[in]valuesvalues of notebook variables to set
◆ cs_notebook_uncertain_output()
void cs_notebook_uncertain_output ( void  )
If input and output uncertain variables are provided, output values are written to an output file: cs_uncertain_output.dat Results are ordered in the definition order in the notebook.
