1 #ifndef __CS_NOTEBOOK_H__
2 #define __CS_NOTEBOOK_H__
167 const double values[]);
Definition: cs_defs.h:509
Definition: cs_defs.h:319
int cs_notebook_parameter_is_present(const char *name, int *editable)
Check if a parameter value is present.
Definition: cs_notebook.c:351
void cs_notebook_uncertain_output(void)
Write uncertain values to output file.
Definition: cs_notebook.c:605
cs_real_t cs_notebook_parameter_value_by_name(const char *name)
Return a parameter value (real).
Definition: cs_notebook.c:383
void cs_notebook_get_values(int n, const int ids[], double values[])
Get a group of notebook variable values.
Definition: cs_notebook.c:484
void cs_notebook_log(void)
Output the notebook info to the setup log.
Definition: cs_notebook.c:566
int cs_notebook_parameter_get_id(const char *name)
Get id associated with a notebook parameter.
Definition: cs_notebook.c:465
void cs_notebook_parameter_set_value(const char *name, cs_real_t val)
Set a parameter value (real) for an editable parameter.
Definition: cs_notebook.c:401
void cs_notebook_load_from_file(void)
Initialize the notebook object (based on cs_tree_node_t).
Definition: cs_notebook.c:277
int cs_notebook_parameter_get_openturns_status(char *name)
Indicate whether the parameter is used for a study with openturns.
Definition: cs_notebook.c:431
void cs_notebook_set_values(int n, const int ids[], const double values[])
Set a group of notebook variable values.
Definition: cs_notebook.c:509
void cs_notebook_destroy_all(void)
Destroy the notebook structure.
Definition: cs_notebook.c:536
const char * cs_notebook_parameter_get_description(char *name)
Returns the description of the parameter (GUI defined).
Definition: cs_notebook.c:448
