#include <ctype.h>
#include "cs_gui_util.h"
#include "cs_map.h"
#include "cs_parameters.h"
#include "cs_notebook.h"
void | cs_notebook_load_from_file (void) |
Initialize the notebook object (based on cs_tree_node_t). More... | |
int | cs_notebook_parameter_is_present (const char *name, int *editable) |
Check if a parameter value is present. More... | |
cs_real_t | cs_notebook_parameter_value_by_name (const char *name) |
Return a parameter value (real). More... | |
void | cs_notebook_parameter_set_value (const char *name, cs_real_t val) |
Set a parameter value (real) for an editable parameter. More... | |
int | cs_notebook_parameter_get_openturns_status (char *name) |
Indicate whether the parameter is used for a study with openturns. More... | |
const char * | cs_notebook_parameter_get_description (char *name) |
Returns the description of the parameter (GUI defined). More... | |
int | cs_notebook_parameter_get_id (const char *name) |
Get id associated with a notebook parameter. More... | |
void | cs_notebook_get_values (int n, const int ids[], double values[]) |
Get a group of notebook variable values. More... | |
void | cs_notebook_set_values (int n, const int ids[], const double values[]) |
Set a group of notebook variable values. More... | |
void | cs_notebook_destroy_all (void) |
Destroy the notebook structure. More... | |
void | cs_notebook_log (void) |
Output the notebook info to the setup log. More... | |
void | cs_notebook_uncertain_output (void) |
Write uncertain values to output file. More... | |
void cs_notebook_destroy_all | ( | void | ) |
Destroys the structures related to the notebook.
void cs_notebook_get_values | ( | int | n, |
const int | ids[], | ||
double | values[] | ||
[in] | n | number of notebook variables to query |
[in] | ids | ids of notebook variables to query (value set to 0 where id < 0) |
[out] | values | values of notebook variables to query |
void cs_notebook_load_from_file | ( | void | ) |
void cs_notebook_log | ( | void | ) |
const char* cs_notebook_parameter_get_description | ( | char * | name | ) |
[in] | name | name of the parameter |
int cs_notebook_parameter_get_id | ( | const char * | name | ) |
int cs_notebook_parameter_get_openturns_status | ( | char * | name | ) |
Returns an int flag to indicate whether this paramter is used for an OpenTurns study. -1 : The parameter is not used with OpenTurns 0 : The parameter is used as an input from OpenTurns 1 : The parameter is used as an output to OpenTurns
int cs_notebook_parameter_is_present | ( | const char * | name, |
int * | editable | ||
[out] | editable | 1 if the value is editable, 0 otherwise (optional) |
void cs_notebook_parameter_set_value | ( | const char * | name, |
cs_real_t | val | ||
The name used is the same as the one in the GUI.
[in] | val | value of the parameter |
cs_real_t cs_notebook_parameter_value_by_name | ( | const char * | name | ) |
void cs_notebook_set_values | ( | int | n, |
const double | values[] | ||
[in] | n | number of notebook variables to set |
[in] | ids | ids of notebook variables to set (ignored where id < 0) |
[in] | values | values of notebook variables to set |
void cs_notebook_uncertain_output | ( | void | ) |
If input and output uncertain variables are provided, output values are written to an output file: cs_uncertain_output.dat Results are ordered in the definition order in the notebook.
