#include "cs_defs.h"#include <assert.h>#include <float.h>#include <stdlib.h>#include <string.h>#include <ctype.h>#include <bft_mem.h>#include <bft_printf.h>#include "cs_base.h"#include "cs_equation.h"#include "cs_log.h"#include "cs_navsto_param.h"
Include dependency graph for cs_navsto_param.c:Functions | |
| double | cs_navsto_param_get_notay_scaling (void) |
| Retrieve the scaling coefficient used in the Notay's transformation devised in "Algebraic multigrid for Stokes equations" SIAM J. Sci. Comput. Vol. 39 (5), 2017 In this article, this scaling is denoted by alpha. More... | |
| void | cs_navsto_param_set_notay_scaling (double scaling_coef) |
| Set the scaling coefficient used in the Notay's transformation devised in "Algebraic multigrid for Stokes equations" SIAM J. Sci. Comput. Vol. 39 (5), 2017 In this article, this scaling is denoted by alpha. More... | |
| cs_navsto_param_t * | cs_navsto_param_create (const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag) |
| Create a new structure to store all numerical parameters related to the resolution of the Navier-Stokes (NS) system. More... | |
| cs_navsto_param_t * | cs_navsto_param_free (cs_navsto_param_t *param) |
| Free a cs_navsto_param_t structure. More... | |
| void | cs_navsto_param_set (cs_navsto_param_t *nsp, cs_navsto_key_t key, const char *keyval) |
| Set a parameter attached to a keyname in a cs_navsto_param_t structure. More... | |
| void | cs_navsto_param_transfer (const cs_navsto_param_t *nsp, cs_equation_param_t *eqp) |
| Apply the numerical settings defined for the Navier-Stokes system to an equation related to this system. More... | |
| void | cs_navsto_param_log (const cs_navsto_param_t *nsp) |
| Summary of the main cs_navsto_param_t structure. More... | |
| cs_navsto_param_boussinesq_t * | cs_navsto_param_add_boussinesq_term (cs_navsto_param_t *nsp, cs_real_t dilatation_coef, cs_real_t reference_value) |
| Add a new Boussinesq term (source term for the momemtum equation) More... | |
| void | cs_navsto_param_set_boussinesq_array (cs_navsto_param_boussinesq_t *bp, const cs_real_t *var) |
| Set the array of values to consider in the Boussinesq term. More... | |
| cs_navsto_param_sles_t * | cs_navsto_param_get_sles_param (const cs_navsto_param_t *nsp) |
| Retrieve the cs_equation_param_t structure related to the velocity equation (momentum equation in most of the cases) More... | |
| cs_equation_param_t * | cs_navsto_param_get_velocity_param (const cs_navsto_param_t *nsp) |
| const char * | cs_navsto_param_get_model_name (cs_navsto_param_model_t model) |
| Retrieve the name of the model system of equations. More... | |
| const char * | cs_navsto_param_get_coupling_name (cs_navsto_param_coupling_t coupling) |
| Retrieve the name of the coupling algorithm. More... | |
| void | cs_navsto_set_reference_pressure (cs_navsto_param_t *nsp, cs_real_t pref) |
| Set the value to consider for the reference pressure. More... | |
| cs_xdef_t * | cs_navsto_add_velocity_ic_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val) |
| Define the initial condition for the velocity unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set to a constant value. More... | |
| cs_xdef_t * | cs_navsto_add_velocity_ic_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define the initial condition for the velocity unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set according to an analytical function. More... | |
| cs_xdef_t * | cs_navsto_add_pressure_ic_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val) |
| Define the initial condition for the pressure unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set to a constant value. More... | |
| cs_xdef_t * | cs_navsto_add_pressure_ic_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define the initial condition for the pressure unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set according to an analytical function. More... | |
| void | cs_navsto_set_fixed_walls (cs_navsto_param_t *nsp) |
| Add the definition of boundary conditions related to a fixed wall into the set of parameters for the management of the Navier-Stokes system of equations. More... | |
| void | cs_navsto_set_symmetries (cs_navsto_param_t *nsp) |
| Add the definition of boundary conditions related to a symmetry into the set of parameters for the management of the Navier-Stokes system of equations. More... | |
| void | cs_navsto_set_outlets (cs_navsto_param_t *nsp) |
| Add the definition of boundary conditions related to outlets into the set of parameters for the management of the Navier-Stokes system of equations. More... | |
| cs_xdef_t * | cs_navsto_set_pressure_bc_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values) |
| Set the pressure field on a boundary using a uniform value. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_wall_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values) |
| Define the velocity field for a sliding wall boundary using a uniform value. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_inlet_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *values) |
| Define the velocity field for an inlet boundary using a uniform value. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_inlet_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input) |
| Define the velocity field for an inlet boundary using an analytical function. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_inlet_by_array (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length) |
| Define the velocity field for an inlet boundary using an array of values. More... | |
| cs_xdef_t * | cs_navsto_set_velocity_inlet_by_dof_func (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t dof_loc, cs_dof_func_t *func, void *func_input) |
| Define the velocity field for an inlet boundary using a DoF function. More... | |
| cs_xdef_t * | cs_navsto_add_source_term_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input) |
| Define a new source term structure defined by an analytical function. More... | |
| cs_xdef_t * | cs_navsto_add_source_term_by_val (cs_navsto_param_t *nsp, const char *z_name, cs_real_t *val) |
| Define a new source term structure defined by a constant value. More... | |
| cs_xdef_t * | cs_navsto_add_source_term_by_array (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length) |
| Define a new source term structure defined by an array. More... | |
| void | cs_navsto_add_oseen_field (cs_navsto_param_t *nsp, cs_adv_field_t *adv_fld) |
| Add a advection field for the Oseen problem. More... | |
| void cs_navsto_add_oseen_field | ( | cs_navsto_param_t * | nsp, |
| cs_adv_field_t * | adv_fld | ||
| [in,out] | nsp | pointer to a cs_navsto_param_t |
| [in,out] | adv_fld | pointer to a cs_adv_field_t |
| cs_xdef_t* cs_navsto_add_pressure_ic_by_analytic | ( | cs_navsto_param_t * | nsp, |
| const char * | z_name, | ||
| cs_analytic_func_t * | analytic, | ||
| void * | input | ||
| [in] | z_name | name of the associated zone (if NULL or "" if all cells are considered) |
| [in] | analytic | pointer to an analytic function |
| cs_xdef_t* cs_navsto_add_pressure_ic_by_value | ( | cs_navsto_param_t * | nsp, |
| cs_real_t * | val | ||
| [in] | val | pointer to the value |
| cs_xdef_t* cs_navsto_add_source_term_by_analytic | ( | cs_navsto_param_t * | nsp, |
| cs_analytic_func_t * | ana, | ||
| void * | input | ||
| [in] | z_name | name of the associated zone (if NULL or "" all cells are considered) |
| [in] | ana | pointer to an analytical function |
| cs_xdef_t* cs_navsto_add_source_term_by_array | ( | cs_navsto_param_t * | nsp, |
| cs_flag_t | loc, | ||
| cs_real_t * | array, | ||
| bool | is_owner, | ||
| bool | full_length | ||
| [in] | is_owner | transfer the lifecycle to the cs_xdef_t structure (true or false) |
| [in] | full_length | if true, array size is allocated and filled to access the full-length array corresponding to all locations where are defined the values |
| cs_xdef_t* cs_navsto_add_source_term_by_val | ( | cs_navsto_param_t * | nsp, |
| [in] | val | pointer to the value to set |
| cs_xdef_t* cs_navsto_add_velocity_ic_by_analytic | ( | cs_navsto_param_t * | nsp, |
| void * | input | ||
| cs_xdef_t* cs_navsto_add_velocity_ic_by_value | ( | cs_navsto_param_t * | nsp, |
| cs_navsto_param_boussinesq_t* cs_navsto_param_add_boussinesq_term | ( | cs_navsto_param_t * | nsp, |
| cs_real_t | dilatation_coef, | ||
| cs_real_t | reference_value | ||
| [in,out] | nsp | pointer to a cs_navsto_param_t struct. |
| [in] | dilatation_coef | value of the dilatation coefficient |
| [in] | reference_value | reference value of the associated variable |
| cs_navsto_param_t* cs_navsto_param_create | ( | const cs_boundary_t * | boundaries, |
| cs_navsto_param_model_t | model, | ||
| cs_navsto_param_model_flag_t | model_flag, | ||
| cs_navsto_param_coupling_t | algo_coupling, | ||
| cs_navsto_param_post_flag_t | post_flag | ||
| [in] | boundaries | pointer to a cs_boundary_t structure |
| [in] | model | type of model related to the NS system |
| [in] | model_flag | additional high-level model options |
| [in] | algo_coupling | algorithm used for solving the NS system |
| [in] | post_flag | predefined post-processings options |
| cs_navsto_param_t* cs_navsto_param_free | ( | cs_navsto_param_t * | param | ) |
| [in,out] | param | pointer to a cs_navsto_param_t structure |
| const char* cs_navsto_param_get_coupling_name | ( | cs_navsto_param_coupling_t | coupling | ) |
| [in] | coupling | a cs_navsto_param_coupling_t |
| const char* cs_navsto_param_get_model_name | ( | cs_navsto_param_model_t | model | ) |
| [in] | model | a cs_navsto_param_model_t |
| double cs_navsto_param_get_notay_scaling | ( | void | ) |
| cs_navsto_param_sles_t* cs_navsto_param_get_sles_param | ( | const cs_navsto_param_t * | nsp | ) |
| cs_equation_param_t* cs_navsto_param_get_velocity_param | ( | const cs_navsto_param_t * | nsp | ) |
| void cs_navsto_param_log | ( | const cs_navsto_param_t * | nsp | ) |
| void cs_navsto_param_set | ( | cs_navsto_param_t * | nsp, |
| cs_navsto_key_t | key, | ||
| const char * | keyval | ||
| [in,out] | nsp | pointer to a cs_navsto_param_t structure to set |
| void cs_navsto_param_set_boussinesq_array | ( | cs_navsto_param_boussinesq_t * | bp, |
| const cs_real_t * | var | ||
| [in,out] | bp | pointer to a cs_navsto_param_boussinesq_t structure |
| [in] | var | shared pointer to the array of values to consider |
| void cs_navsto_param_set_notay_scaling | ( | double | scaling_coef | ) |
| [in] | scaling_coef | valued of the scaling coefficient |
| void cs_navsto_param_transfer | ( | const cs_navsto_param_t * | nsp, |
| cs_equation_param_t * | eqp | ||
| [in,out] | eqp | pointer to a cs_equation_param_t structure |
| void cs_navsto_set_fixed_walls | ( | cs_navsto_param_t * | nsp | ) |
| void cs_navsto_set_outlets | ( | cs_navsto_param_t * | nsp | ) |
| cs_xdef_t* cs_navsto_set_pressure_bc_by_value | ( | cs_navsto_param_t * | nsp, |
| cs_real_t * | values | ||
| [in] | z_name | name of the associated zone (if NULL or "" all boundary faces are considered) |
| [in] | values | value to set |
| void cs_navsto_set_reference_pressure | ( | cs_navsto_param_t * | nsp, |
| cs_real_t | pref | ||
| [in] | pref | value of the reference pressure |
| void cs_navsto_set_symmetries | ( | cs_navsto_param_t * | nsp | ) |
| cs_xdef_t* cs_navsto_set_velocity_inlet_by_analytic | ( | cs_navsto_param_t * | nsp, |
| void * | input | ||
| cs_xdef_t* cs_navsto_set_velocity_inlet_by_array | ( | cs_navsto_param_t * | nsp, |
| [in] | full_length | if true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection. |
| cs_xdef_t* cs_navsto_set_velocity_inlet_by_dof_func | ( | cs_navsto_param_t * | nsp, |
| cs_flag_t | dof_loc, | ||
| void * | func_input | ||
| [in] | dof_loc | where are located DoFs |
| [in] | func | pointer to a cs_dof_function_t |
| [in] | func_input | NULL or pointer to a structure cast on-the-fly |
| cs_xdef_t* cs_navsto_set_velocity_inlet_by_value | ( | cs_navsto_param_t * | nsp, |
| [in] | values | array of three real values |
| cs_xdef_t* cs_navsto_set_velocity_wall_by_value | ( | cs_navsto_param_t * | nsp, |
