8.0
cs_log_iteration.c File Reference
Log field and other array statistics at relevant time steps. More...
#include <stdarg.h>
#include "cs_array_reduce.h"
#include "cs_ctwr.h"
#include "cs_fan.h"
#include "cs_function.h"
#include "cs_map.h"
#include "cs_mesh_location.h"
#include "cs_parameters.h"
#include "cs_prototypes.h"
#include "cs_range_set.h"
#include "cs_time_moment.h"
#include "cs_time_plot.h"
#include "cs_time_step.h"
#include "cs_lagr_stat.h"
#include "cs_lagr_log.h"
#include "fvm_convert_array.h"
#include "cs_log_iteration.h"
+ Include dependency graph for cs_log_iteration.c:
void cs_log_iteration_destroy_all (void)
 Free arrays possible used by logging of array statistics. More...
void cs_log_iteration (void)
 Log field and other array statistics for the current time step. More...
void cs_log_iteration_add_array (const char *name, const char *category, const cs_mesh_location_type_t loc_id, bool is_intensive, int dim, const cs_real_t val[])
 Add or update array not saved as permanent field to iteration log. More...
void cs_log_iteration_clipping (const char *name, int dim, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[])
 Add or update clipping info for a given array. More...
void cs_log_iteration_clipping_field (int f_id, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[], cs_lnum_t n_clip_min_comp[], cs_lnum_t n_clip_max_comp[])
 Add or update clipping info for a field. More...
void cs_log_iteration_prepare (void)
 Initialize structures used for logging for new iteration. More...
void cs_log_iteration_l2residual (void)
 Log L2 time residual for variable fields. More...
◆ cs_log_iteration()
void cs_log_iteration ( void  )
◆ cs_log_iteration_add_array()
void cs_log_iteration_add_array ( const char *  name,
const char *  category,
bool  is_intensive,
int  dim,
[in]namearray name
[in]categorycategory name
[in]loc_idassociated mesh location id
[in]is_intensiveare the matching values intensive ?
[in]dimassociated dimension (interleaved)
[in]valassociated values
◆ cs_log_iteration_clipping()
void cs_log_iteration_clipping ( const char *  name,
int  dim,
[in]namefield or array name
[in]n_clip_minnumber of local clippings to minimum value
[in]n_clip_maxnumber of local clippings to maximum value
[in]min_pre_clipminimum values prior to clipping
[in]max_pre_clipmaximum values prior to clipping
◆ cs_log_iteration_clipping_field()
void cs_log_iteration_clipping_field ( int  f_id,
[in]f_idassociated field id
[in]n_clip_min_compnumber of clip min by component
[in]n_clip_max_compnumber of clip max by component
◆ cs_log_iteration_destroy_all()
void cs_log_iteration_destroy_all ( void  )
◆ cs_log_iteration_l2residual()
void cs_log_iteration_l2residual ( void  )
◆ cs_log_iteration_prepare()
void cs_log_iteration_prepare ( void  )
