8.0
cs_lagr_extract.h
1
#ifndef __CS_LAGR_EXTRACT_H__
2
#define __CS_LAGR_EXTRACT_H__
4
5
* Extract information from lagrangian particles.
6
8
9
This file is part of code_saturne, a general-purpose CFD tool.
11
Copyright (C) 1998-2023 EDF S.A.
13
14
15
16
version.
18
19
20
21
details.
23
24
25
26
28
30
* Standard C library headers
32
34
* Local headers
36
38
#include "
fvm_nodal.h
#include "
fvm_writer.h
#include "
cs_base.h
#include "
cs_lagr_particle.h
#include "
cs_time_step.h
45
46
BEGIN_C_DECLS
48
49
50
* Macro definitions
51
52
53
54
* Local type definitions
55
56
57
58
* Global variables
59
60
61
62
* Public function prototypes
63
64
65
66
* Get the local number of particles.
67
68
* returns:
69
* current number of particles.
70
71
72
cs_lnum_t
73
cs_lagr_get_n_particles
void
74
75
76
* Extract a list of particles using an optional cell filter and
77
* statistical density filter.
78
79
* The output array must have been allocated by the caller and be of
80
* sufficient size.
81
82
* parameters:
83
* n_cells <-- number of cells in filter
84
* cell_list <-- optional list of containing cells filter
85
* (1 to n numbering)
86
* density <-- if < 1, fraction of particles to select
87
* n_particles --> number of selected particles, or NULL
88
* particle_list --> particle_list (1 to n numbering), or NULL
89
90
91
void
92
cs_lagr_get_particle_list
cs_lnum_t
n_cells,
93
const
cs_lnum_t
cell_list[],
94
double
density
95
cs_lnum_t
*n_particles,
96
cs_lnum_t
*particle_list);
97
98
99
* Extract values for a set of particles.
100
101
102
* sufficient size.
103
104
* parameters:
105
* particle_set <-- associated particle set
106
* attr <-- attribute whose values are required
107
* datatype <-- associated value type
108
* stride <-- number of values per particle
109
* component_id <-- if -1 : extract the whole attribute
110
* if >0 : id of the component to extract
111
* n_particles <-- number of particles in filter
112
* particle_list <-- particle_list (1 to n numbering), or NULL
113
* values --> particle values for given attribute
114
115
* returns:
116
* 0 in case of success, 1 if attribute is not present
117
118
119
int
120
cs_lagr_get_particle_values
const
cs_lagr_particle_set_t
*particles,
121
cs_lagr_attribute_t
attr,
122
cs_datatype_t
datatype,
123
int
stride,
124
int
component_id,
125
cs_lnum_t
n_particles,
126
const
cs_lnum_t
particle_list[],
127
void
*values);
128
129
130
* Extract trajectory values for a set of particles.
131
132
* Trajectories are defined as a mesh of segments, whose start and end
133
* points are copied in an interleaved manner in the segment_values array
134
* (p1_old, p1_new, p2_old, p2_new, ... pn_old, pn_new).
135
136
137
* sufficient size.
138
139
* parameters:
140
* particles <-- associated particle set
141
142
143
144
145
146
147
148
* segment_values --> particle segment values
149
150
* returns:
151
152
153
154
int
155
cs_lagr_get_trajectory_values
const
*particles,
156
cs_lagr_attribute_t
attr,
157
cs_datatype_t
datatype,
158
int
stride,
159
int
component_id,
160
cs_lnum_t
n_particles,
161
const
cs_lnum_t
particle_list[],
162
void
*segment_values);
163
164
165
166
END_C_DECLS
167
168
#endif
/* __CS_LAGR_EXTRACT_H__ */
cs_base.h
cs_datatype_t
cs_datatype_t
Definition:
cs_defs.h:272
BEGIN_C_DECLS
Definition:
cs_defs.h:509
END_C_DECLS
Definition:
cs_defs.h:510
cs_lnum_t
Definition:
cs_defs.h:313
int cs_lagr_get_particle_values(const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id, cs_lnum_t n_particles, const cs_lnum_t particle_list[], void *values)
Definition:
cs_lagr_extract.c:260
int cs_lagr_get_trajectory_values(const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id, cs_lnum_t n_particles, const cs_lnum_t particle_list[], void *segment_values)
Definition:
cs_lagr_extract.c:362
void cs_lagr_get_particle_list(cs_lnum_t n_cells, const cs_lnum_t cell_list[], double density, cs_lnum_t *n_particles, cs_lnum_t *particle_list)
Extract a list of particles using an optional cell filter and statistical density filter.
Definition:
cs_lagr_extract.c:134
cs_lnum_t cs_lagr_get_n_particles(void)
Definition:
cs_lagr_extract.c:105
cs_lagr_particle.h
cs_lagr_attribute_t
cs_lagr_attribute_t
Definition:
cs_lagr_particle.h:79
cs_time_step.h
fvm_nodal.h
fvm_writer.h
atimbr::density
double precision, dimension(:,:,:), allocatable density
Definition:
atimbr.f90:124
Definition:
cs_lagr_particle.h:222
src
lagr
cs_lagr_extract.h
Generated on Wed Jun 21 2023 15:40:19 for code_saturne by
1.9.1
