Functions to handle the resolution of the turbulence modelling within the CDO framework. More...
#include <bft_mem.h>
#include "cs_post.h"
#include "cs_reco.h"
#include "cs_cdo_turbulence.h"
Macros | |
#define | CS_CDO_TURBULENCE_DBG 0 |
cs_turbulence_param_t * | cs_turbulence_param_create (void) |
Allocate the structure storing the set of parameters for the turbulence modelling. More... | |
cs_turbulence_t * | cs_turbulence_create (cs_turbulence_param_t *tbp) |
Allocate the structure managing the turbulence modelling. More... | |
void | cs_turbulence_free (cs_turbulence_t **p_turb_struct) |
Free the structure managing the turbulence modelling. More... | |
void | cs_turbulence_init_setup (cs_turbulence_t *tbs, cs_equation_t *mom_eq) |
Initialize the structure managing the turbulence modelling. More... | |
void | cs_turbulence_finalize_setup (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs) |
Finalize the setup of the turbulence modelling and especially the equations/properties and other related quantities. More... | |
void | cs_turbulence_init_values (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs) |
Initialize the values of quantities related to a turbulence model. More... | |
void * | cs_turb_init_k_eps_context (const cs_turb_model_t *tbm) |
Allocate and initialize the context structure related to the k-epsilon turbulence model. More... | |
void * | cs_turb_free_k_eps_context (void *tbc) |
Free the context structure related to the k-epsilon turbulence model. More... | |
void | cs_turb_update_k_eps (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs) |
Update for the current time step the new state for the turbulence model. This is used to update the turbulent viscosity. More... | |
void | cs_turb_compute_k_eps (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs) |
Compute for the current time step the new state for the turbulence model. This means that all related equations are built and then solved. More... | |
#define CS_CDO_TURBULENCE_DBG 0 |
void cs_turb_compute_k_eps | ( | const cs_mesh_t * | mesh, |
const cs_cdo_connect_t * | connect, | ||
const cs_cdo_quantities_t * | quant, | ||
const cs_time_step_t * | time_step, | ||
cs_turbulence_t * | tbs | ||
[in] | mesh | pointer to a cs_mesh_t structure |
[in] | connect | pointer to a cs_cdo_connect_t structure |
[in] | quant | pointer to a cs_cdo_quantities_t structure |
[in] | time_step | structure managing the time stepping |
[in,out] | tbs | pointer to turbulence structure |
void* cs_turb_free_k_eps_context | ( | void * | tbc | ) |
[in,out] | tbc | pointer to a structure context cast on-the-fly |
void* cs_turb_init_k_eps_context | ( | const cs_turb_model_t * | tbm | ) |
[in] | tbm | structure which defines the turbulence model |
void cs_turb_update_k_eps | ( | const cs_mesh_t * | mesh, |
const cs_turbulence_t * | tbs | ||
[in] | tbs | pointer to a cs_turbulence_t structure |
cs_turbulence_t* cs_turbulence_create | ( | cs_turbulence_param_t * | tbp | ) |
[in] | tbp | pointer to a cs_turbulence_param_t structure |
void cs_turbulence_finalize_setup | ( | const cs_mesh_t * | mesh, |
[in] | time_step | pointer to a cs_time_step_t structure |
[in,out] | tbs | pointer to the turbulence main structure |
void cs_turbulence_free | ( | cs_turbulence_t ** | p_turb_struct | ) |
[in,out] | p_turb_struct | pointer to the structure to free |
void cs_turbulence_init_setup | ( | cs_turbulence_t * | tbs, |
cs_equation_t * | mom_eq | ||
[in,out] | tbs | pointer to the structure to initialize |
[in] | mom_eq | pointer to the structure mom_eq |
void cs_turbulence_init_values | ( | const cs_mesh_t * | mesh, |
cs_turbulence_param_t* cs_turbulence_param_create | ( | void | ) |
