1 #ifndef __CS_CDO_TURBULENCE_H__
2 #define __CS_CDO_TURBULENCE_H__
49 #define CS_NAVSTO_TOTAL_VISCOSITY "total_viscosity"
50 #define CS_NAVSTO_LAM_VISCOSITY "laminar_viscosity"
51 #define CS_NAVSTO_TURB_VISCOSITY "turbulent_viscosity"
void cs_turbulence_finalize_setup(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
Finalize the setup of the turbulence modelling and especially the equations/properties and other rela...
Definition: cs_cdo_turbulence.c:479
void cs_turbulence_init_setup(cs_turbulence_t *tbs, cs_equation_t *mom_eq)
Initialize the structure managing the turbulence modelling.
Definition: cs_cdo_turbulence.c:391
void *() cs_turb_free_context_t(void *turb_context)
Free the context structure related to a given turbulence modelling.
Definition: cs_cdo_turbulence.h:134
void * cs_turb_free_k_eps_context(void *tbc)
Free the context structure related to the k-epsilon turbulence model.
Definition: cs_cdo_turbulence.c:731
cs_turbulence_t * cs_turbulence_create(cs_turbulence_param_t *tbp)
Allocate the structure managing the turbulence modelling.
Definition: cs_cdo_turbulence.c:312
cs_turbulence_param_t * cs_turbulence_param_create(void)
Allocate the structure storing the set of parameters for the turbulence modelling.
Definition: cs_cdo_turbulence.c:285
void cs_turbulence_free(cs_turbulence_t **p_turb_struct)
Free the structure managing the turbulence modelling.
Definition: cs_cdo_turbulence.c:363
void() cs_turb_compute_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
Compute for the current time step the new state for the turbulence model. This means that all related...
Definition: cs_cdo_turbulence.h:151
void * cs_turb_init_k_eps_context(const cs_turb_model_t *tbm)
Allocate and initialize the context structure related to the k-epsilon turbulence model.
Definition: cs_cdo_turbulence.c:633
void *() cs_turb_init_context_t(const cs_turb_model_t *tbm)
Allocate and initialize the context structure related to a given turbulence modelling.
Definition: cs_cdo_turbulence.h:121
void cs_turbulence_init_values(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
Initialize the values of quantities related to a turbulence model.
Definition: cs_cdo_turbulence.c:600
void() cs_turb_update_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs)
Update properties, arrays related to the turbulent variables.
Definition: cs_cdo_turbulence.h:170
void cs_turb_compute_k_eps(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
Definition: cs_cdo_turbulence.c:832
void cs_turb_update_k_eps(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs)
Update for the current time step the new state for the turbulence model. This is used to update the t...
Definition: cs_cdo_turbulence.c:757
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_cdo_turbulence.h:182
cs_property_t * mu_l
Definition: cs_cdo_turbulence.h:222
cs_turb_update_t * update
Definition: cs_cdo_turbulence.h:301
void * context
Definition: cs_cdo_turbulence.h:269
cs_turb_compute_t * compute_steady
Definition: cs_cdo_turbulence.h:294
cs_turbulence_param_t * param
Definition: cs_cdo_turbulence.h:194
cs_turb_free_context_t * free_context
Definition: cs_cdo_turbulence.h:281
cs_equation_t * mom_eq
Definition: cs_cdo_turbulence.h:199
cs_property_t * mu_t
Definition: cs_cdo_turbulence.h:228
cs_turb_init_context_t * init_context
Definition: cs_cdo_turbulence.h:275
Definition: cs_cdo_turbulence.h:287
cs_field_t * mu_t_field
Definition: cs_cdo_turbulence.h:245
cs_property_t * rho
Definition: cs_cdo_turbulence.h:210
cs_field_t * rij
Definition: cs_cdo_turbulence.h:251
cs_real_t * mu_tot_array
Definition: cs_cdo_turbulence.h:233
cs_property_t * mu_tot
Definition: cs_cdo_turbulence.h:216
Definition: cs_cdo_quantities.h:137
Definition: cs_field.h:130
time step descriptor
Definition: cs_time_step.h:64
LES turbulence model descriptor.
Definition: cs_turbulence_model.h:245
Turbulence model general options descriptor.
Definition: cs_turbulence_model.h:115
RANS turbulence model descriptor.
Definition: cs_turbulence_model.h:176
Definition: cs_turbulence_model.h:165
Structure storing the parameters related to the resolution of the turbulence modelling....
Definition: cs_cdo_turbulence.h:64
cs_turb_les_model_t * les_param
Definition: cs_cdo_turbulence.h:87
cs_turb_ref_values_t * reference_values
Definition: cs_cdo_turbulence.h:93
cs_turb_model_t * model
Definition: cs_cdo_turbulence.h:71
cs_turb_rans_model_t * rans_param
Definition: cs_cdo_turbulence.h:79
