1 #ifndef __CS_CDO_ADVECTION_H__
2 #define __CS_CDO_ADVECTION_H__
void cs_cdo_advection_vb_upwcsv_wpty(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme with an upwind sche...
Definition: cs_cdo_advection.c:1958
void cs_cdo_advection_vcb_bc(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Compute the BC contribution for the convection operator with CDO V+C schemes.
Definition: cs_cdo_advection.c:2862
double cs_cdo_advection_get_cip_coef(void)
Get the value of the stabilization coefficient used in CIP scheme.
Definition: cs_cdo_advection.c:1243
void cs_cdofb_advection_upwnoc(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Compute the convection operator attached to a cell with a CDO face-based scheme.
Definition: cs_cdo_advection.c:1617
void cs_cdo_advection_vb_upwcsv(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme without diffusion a...
Definition: cs_cdo_advection.c:2049
void cs_cdo_advection_vb_upwnoc(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme without diffusion w...
Definition: cs_cdo_advection.c:2357
void cs_cdofb_advection_close_default_vect(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Operation done after the matrix related to the advection term has been defined. Follow the prototype ...
Definition: cs_cdo_advection.c:1339
void cs_cdofb_advection_no_diffusion(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb)
Main function to build the cellwise advection operator for CDO-Fb schemes The local matrix related to...
Definition: cs_cdo_advection.c:1475
void cs_cdofb_advection_close_default_scal(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.c:1310
void cs_cdo_advection_vcb_cw_cst(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex+cell-based scheme when the advec...
Definition: cs_cdo_advection.c:2469
void cs_cdofb_advection_cennoc(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.c:1811
void cs_cdofb_advection_cencsv(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.c:1883
void cs_cdo_advection_vb_bc(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Compute the BC contribution for the convection operator.
Definition: cs_cdo_advection.c:2740
void cs_cdofb_advection(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb)
Main function to build the cellwise advection operator for CDO face-based schemes....
Definition: cs_cdo_advection.c:1556
void cs_cdofb_advection_close_exp_none_scal(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.c:1384
void() cs_cdofb_adv_build_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb)
Build the cellwise advection operator for CDO-Fb schemes The local matrix related to this operator is...
Definition: cs_cdo_advection.h:116
void cs_cdo_advection_vcb(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex+cell-based scheme.
Definition: cs_cdo_advection.c:2609
void() cs_cdofb_adv_scheme_t(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Define the local convection operator in CDO-Fb schemes. Case of an operator that should be assemble i...
Definition: cs_cdo_advection.h:92
void cs_cdo_advection_vb_upwnoc_wpty(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Definition: cs_cdo_advection.c:2268
void cs_cdo_advection_set_cip_coef(double new_value)
Set the value of the stabilization coefficient used in CIP scheme.
Definition: cs_cdo_advection.c:1229
void() cs_cdovb_advection_bc_t(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Compute the BC contribution for the advection operator in CDO vertex-based (or vertex+cell-based) sch...
Definition: cs_cdo_advection.h:182
void() cs_cdofb_adv_close_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.h:136
void cs_cdo_advection_vb_mcucsv(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme when a mixed center...
Definition: cs_cdo_advection.c:2165
void cs_cdo_advection_vb_mcunoc(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Definition: cs_cdo_advection.c:2216
void cs_cdo_advection_vb_cennoc(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme when a centered sch...
Definition: cs_cdo_advection.c:2421
void cs_cdo_advection_cell_upwind_coef(const cs_cdo_quantities_t *cdoq, cs_param_advection_scheme_t scheme, cs_real_t coefval[])
Compute the value of the upwinding coefficient in each cell knowing the related Peclet number.
Definition: cs_cdo_advection.c:2927
void cs_cdofb_advection_upwcsv(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.c:1714
void() cs_cdofb_adv_open_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, void *input, cs_cell_builder_t *cb)
Perform preprocessing such as the computation of the advection flux at the expected location in order...
Definition: cs_cdo_advection.h:71
void cs_cdofb_advection_close_exp_none_vect(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.c:1422
void() cs_cdovb_advection_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme....
Definition: cs_cdo_advection.h:161
void cs_cdo_advection_vb_cencsv(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Definition: cs_cdo_advection.c:2114
void cs_cdofb_advection_open_default(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, void *input, cs_cell_builder_t *cb)
Definition: cs_cdo_advection.c:1264
Definition: cs_defs.h:509
Definition: cs_defs.h:319
@ fm
Definition: cs_field_pointer.h:128
Definition: cs_param_types.h:351
Definition: cs_cdo_quantities.h:137
Definition: cs_cdo_local.h:60
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:279
Structure storing the evaluation of a property and its related data.
Definition: cs_property.h:211
