Translation of the boundary conditions given by cs_user_boundary_conditions in a form that fits to the solver. More...
Functions/Subroutines | |
| subroutine | condli (nvar, nscal, iterns, isvhb, itrale, italim, itrfin, ineefl, itrfup, icodcl, isostd, dt, rcodcl, visvdr, hbord, theipb) |
| subroutine | set_dirichlet_scalar (coefa, cofaf, coefb, cofbf, pimp, hint, hext) |
| subroutine | set_dirichlet_vector (coefa, cofaf, coefb, cofbf, pimpv, hint, hextv) |
| subroutine | set_dirichlet_tensor (coefa, cofaf, coefb, cofbf, pimpts, hint, hextts) |
| subroutine | set_dirichlet_vector_aniso (coefa, cofaf, coefb, cofbf, pimpv, hint, hextv) |
| subroutine | set_neumann_scalar (coefa, cofaf, coefb, cofbf, dimp, hint) |
| subroutine | set_neumann_vector (coefa, cofaf, coefb, cofbf, qimpv, hint) |
| subroutine | set_neumann_tensor (coefa, cofaf, coefb, cofbf, qimpts, hint) |
| subroutine | set_neumann_vector_aniso (coefa, cofaf, coefb, cofbf, qimpv, hint) |
| subroutine | set_generalized_sym_vector (coefa, cofaf, coefb, cofbf, pimpv, qimpv, hint, normal) |
| subroutine | set_generalized_sym_vector_aniso (coefa, cofaf, coefb, cofbf, pimpv, qimpv, hint, normal) |
| subroutine | set_generalized_dirichlet_vector (coefa, cofaf, coefb, cofbf, pimpv, qimpv, hint, normal) |
| subroutine | set_generalized_dirichlet_vector_aniso (coefa, cofaf, coefb, cofbf, pimpv, qimpv, hint, normal) |
| subroutine | set_convective_outlet_scalar (coefa, cofaf, coefb, cofbf, pimp, cfl, hint) |
| subroutine | set_convective_outlet_vector (coefa, cofaf, coefb, cofbf, pimpv, cflv, hint) |
| subroutine | set_convective_outlet_tensor (coefa, cofaf, coefb, cofbf, pimpts, cflts, hint) |
| subroutine | set_convective_outlet_vector_aniso (coefa, cofaf, coefb, cofbf, pimpv, cflv, hint) |
| subroutine | set_affine_function_scalar (coefa, cofaf, coefb, cofbf, pinf, ratio, hint) |
| subroutine | set_neumann_conv_h_neumann_diff_scalar (coefa, cofaf, coefb, cofbf, dimp, hint) |
| subroutine | set_affine_function_conv_neumann_diff_scalar (coefa, cofaf, coefb, cofbf, pinf, ratio, dimp) |
| subroutine | set_total_flux (coefa, cofaf, coefb, cofbf, hext, dimp) |
| subroutine | set_dirichlet_conv_neumann_diff_scalar (coefa, cofaf, coefb, cofbf, pimp, dimp) |
| subroutine | set_dirichlet_conv_neumann_diff_vector (coefa, cofaf, coefb, cofbf, pimpv, qimpv) |
| subroutine | set_dirichlet_conv_neumann_diff_tensor (coefa, cofaf, coefb, cofbf, pimpts, qimpts) |
| subroutine | condli_ini (nvar, nscal, itrale, icodcl, isostd, dt, rcodcl) |
| Initialisation of boundary condition arrays. More... | |
The values at a boundary face
stored in the face center
of the variable
and its diffusive flux
are written as:
and
where
is the value of the variable
at the neighboring cell.
Warning:
Please refer to the boundary conditions section of the theory guide for more informations, as well as the condli section.
| subroutine condli | ( | integer | nvar, |
| integer | nscal, | ||
| integer | iterns, | ||
| integer | isvhb, | ||
| integer | itrale, | ||
| integer | italim, | ||
| integer | itrfin, | ||
| integer | ineefl, | ||
| integer | itrfup, | ||
| integer, dimension(:,:), pointer | icodcl, | ||
| integer, dimension(nfabor+1) | isostd, | ||
| double precision, dimension(:), pointer | dt, | ||
| double precision, dimension(:,:,:), pointer | rcodcl, | ||
| double precision, dimension(:), pointer | visvdr, | ||
| double precision, dimension(:), pointer | hbord, | ||
| double precision, dimension(:), pointer | theipb | ||
| [in] | nscal | total number of scalars |
| [in] | iterns | iteration number on Navier-Stokes equations |
| [in] | isvhb | indicator to save exchange coeffient at the walls |
| [in] | itrale | ALE iteration number |
| [in] | italim | for ALE |
| [in] | itrfin | for ALE |
| [in] | ineefl | for ALE |
| [in] | itrfup | for ALE |
| [in,out] | icodcl | face boundary condition code:
| [in,out] | isostd | indicator for standard outlet and reference face index |
| [in,out] | rcodcl | boundary condition values:
| [out] | visvdr | dynamic viscosity after V. Driest damping in boundary cells |
| [out] | hbord | exchange coefficient at boundary |
| [out] | theipb | value of thermal scalar at |
| subroutine condli_ini | ( | integer | nvar, |
| double precision, dimension(:,:,:), pointer | rcodcl | ||
| [in,out] | icodcl | face boundary condition code (see condli) |
| subroutine set_affine_function_conv_neumann_diff_scalar | ( | double precision | coefa, |
| double precision | cofaf, | ||
| double precision | coefb, | ||
| double precision | cofbf, | ||
| double precision | pinf, | ||
| double precision | ratio, | ||
| double precision | dimp | ||
| [out] | coefa | explicit BC coefficient for gradients |
| [out] | cofaf | explicit BC coefficient for diffusive flux |
| [out] | coefb | implicit BC coefficient for gradients |
| [out] | cofbf | implicit BC coefficient for diffusive flux |
| [in] | pinf | affine part |
| [in] | ratio | linear part |
| [in] | dimp | Flux value to impose |
| subroutine set_affine_function_scalar | ( | double precision | coefa, |
| double precision | hint | ||
| [in] | hint | internal exchange coefficient |
| subroutine set_convective_outlet_scalar | ( | double precision | coefa, |
| double precision | pimp, | ||
| double precision | cfl, | ||
| [in] | pimp | Flux value to impose |
| [in] | cfl | Local Courant number used to convect |
| [in] | hint | Internal exchange coefficient |
| subroutine set_convective_outlet_tensor | ( | double precision, dimension(6) | coefa, |
| double precision, dimension(6) | cofaf, | ||
| double precision, dimension(6,6) | coefb, | ||
| double precision, dimension(6,6) | cofbf, | ||
| double precision, dimension(6) | pimpts, | ||
| double precision, dimension(6) | cflts, | ||
| [in] | pimpts | Dirichlet value to impose |
| [in] | cflts | Local Courant number used to convect |
| subroutine set_convective_outlet_vector | ( | double precision, dimension(3) | coefa, |
| double precision, dimension(3) | cofaf, | ||
| double precision, dimension(3,3) | coefb, | ||
| double precision, dimension(3,3) | cofbf, | ||
| double precision, dimension(3) | pimpv, | ||
| double precision, dimension(3) | cflv, | ||
| [in] | pimpv | Dirichlet value to impose |
| [in] | cflv | Local Courant number used to convect |
| subroutine set_convective_outlet_vector_aniso | ( | double precision, dimension(3) | coefa, |
| double precision, dimension(6) | hint | ||
| subroutine set_dirichlet_conv_neumann_diff_scalar | ( | double precision | coefa, |
| [in] | pimp | Dirichlet value to impose |
| subroutine set_dirichlet_conv_neumann_diff_tensor | ( | double precision, dimension(6) | coefa, |
| double precision, dimension(6) | qimpts | ||
| [in] | qimpts | Flux value to impose |
| subroutine set_dirichlet_conv_neumann_diff_vector | ( | double precision, dimension(3) | coefa, |
| double precision, dimension(3) | qimpv | ||
| [in] | qimpv | Flux value to impose |
| subroutine set_dirichlet_scalar | ( | double precision | coefa, |
| double precision | hint, | ||
| double precision | hext | ||
| [in] | hext | External exchange coefficient (10^30 by default) |
| subroutine set_dirichlet_tensor | ( | double precision, dimension(6) | coefa, |
| double precision, dimension(6) | hextts | ||
| [in] | hextts | External exchange coefficient (10^30 by default) |
| subroutine set_dirichlet_vector | ( | double precision, dimension(3) | coefa, |
| double precision, dimension(3) | hextv | ||
| [in] | hextv | External exchange coefficient (10^30 by default) |
| subroutine set_dirichlet_vector_aniso | ( | double precision, dimension(3) | coefa, |
| double precision, dimension(6) | hint, | ||
| subroutine set_generalized_dirichlet_vector | ( | double precision, dimension(3) | coefa, |
| double precision, dimension(3) | qimpv, | ||
| double precision, dimension(3) | normal | ||
| [in] | pimpv | Dirichlet value to impose on the tangential components |
| [in] | qimpv | Flux value to impose on the normal component |
| [in] | normal | normal |
| subroutine set_generalized_dirichlet_vector_aniso | ( | double precision, dimension(3) | coefa, |
| subroutine set_generalized_sym_vector | ( | double precision, dimension(3) | coefa, |
| [in] | pimpv | Dirichlet value to impose on the normal component |
| [in] | qimpv | Flux value to impose on the tangential components |
| subroutine set_generalized_sym_vector_aniso | ( | double precision, dimension(3) | coefa, |
| subroutine set_neumann_conv_h_neumann_diff_scalar | ( | double precision | coefa, |
| double precision | dimp, | ||
| subroutine set_neumann_scalar | ( | double precision | coefa, |
| subroutine set_neumann_tensor | ( | double precision, dimension(6) | coefa, |
| double precision, dimension(6) | qimpts, | ||
| subroutine set_neumann_vector | ( | double precision, dimension(3) | coefa, |
| subroutine set_neumann_vector_aniso | ( | double precision, dimension(3) | coefa, |
| subroutine set_total_flux | ( | double precision | coefa, |
| double precision | hext, | ||
| [in] | hext | convective flux to be imposed |
