Update the convective mass flux before the velocity prediction step. It is the first step of the compressible algorithm at each time iteration. More...
Functions/Subroutines | |
| subroutine | cfmspr (nvar, nscal, iterns, ncepdp, ncesmp, icepdc, icetsm, itypsm, dt, vela, ckupdc, smacel) |
This function solves the continuity equation in pressure formulation and then updates the density and the mass flux.
| subroutine cfmspr | ( | integer | nvar, |
| integer | nscal, | ||
| integer | iterns, | ||
| integer | ncepdp, | ||
| integer | ncesmp, | ||
| integer, dimension(ncepdp) | icepdc, | ||
| integer, dimension(ncesmp) | icetsm, | ||
| integer, dimension(ncesmp,nvar) | itypsm, | ||
| double precision, dimension(ncelet) | dt, | ||
| double precision, dimension (3 ,ncelet) | vela, | ||
| double precision, dimension(6,ncepdp) | ckupdc, | ||
| double precision, dimension(ncesmp,nvar) | smacel | ||
| [in] | nscal | total number of scalars |
| [in] | ncepdp | number of cells with head loss |
| [in] | icepdc | index of cells with head loss |
| [in] | itypsm | type of mass source term for each variable (see uttsma.f90) |
| [in] | vela | velocity value at time step beginning |
| [in] | ckupdc | work array for the head loss |
| [in] | smacel | variable value associated to the mass source term (for ivar=ipr, smacel is the mass flux |
