8.0
Atmospheric examples
Local variables to be added for the Fortran examples
integer ifac, ii
integer izone
integer ilelt, nlelt
integer f_id_rough, f_id_t_rough
double precision d2s3
double precision zref, xuref
double precision ustar, rugd, rugt
double precision zent, xuent, xvent
double precision xkent, xeent
integer, allocatable, dimension(:) :: lstelt
double precision, dimension(:), pointer :: bpro_roughness
double precision, dimension(:), pointer :: bpro_roughness_t
Example 1 (Fortran)
For boundary faces of color 11, assign an inlet boundary condition prescribed from the meteo profile with automatic choice between inlet/ outlet according to the meteo profile.
call getfbr('11',nlelt,lstelt)
! Get a new zone number (1 <= izone <= nozppm)
izone = maxval(izfppp) + 1
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
! - Zone to which the face belongs
izfppp(ifac) = izone
! - Boundary conditions are prescribed from the meteo profile
iprofm(izone) = 1
! - boundary condition type can be set to ientre or i_convective_inlet
itypfb(ifac) = ientre
! - automatic determination of type (inlet/outlet) according to sign of
! mass flux
iautom(ifac) = 1
enddo
subroutine getfbr(fstr, facnb, faces)
Build the list of boundary faces matching a criteria string.
Definition: cs_selector_f2c.f90:111
Example 2 (Fortran)
For boundary faces of color 21, assign an inlet boundary condition prescribed from the meteo profile.
call getfbr('21',nlelt,lstelt)
do ilelt = 1, nlelt
iprofm(izone) = 1
! - Assign inlet boundary conditions
enddo
Example 3
For boundary faces of zone "inlet_3", assign an inlet boundary condition. Here, all other variables prescribed from the meteo profile are assumed to be managed by the GUI, except for dynamic variables which are prescribed with a rough log law.
const cs_lnum_t n_b_faces = domain->mesh->n_b_faces;
const cs_real_3_t *restrict b_face_cog
= (const cs_real_3_t *restrict)domain->mesh_quantities->b_face_cog;
const cs_real_t d2o3 = 2./3;
/* Parameters for the analytical rough wall law (neutral) */
const cs_real_t rugd = 0.10;
const cs_real_t zref = 10.0;
const cs_real_t xuref = 10.0;
const cs_zone_t *zn = cs_boundary_zone_by_name("inlet_3");
for (cs_lnum_t e_idx = 0; e_idx < zn->n_elts; e_idx++) {
const cs_lnum_t face_id = zn->elt_ids[e_idx];
bc_type[face_id] = CS_INLET;
/* Dynamic variables are prescribed with a rough log law;
note: using functions from the `cs_turbulence_bc` series
is preferrable when the appropriate function is available. */
const cs_real_t zent = b_face_cog[face_id][2];
const cs_real_t ustar = cs_turb_xkappa*xuref/log((zref+rugd)/rugd);
const cs_real_t xuent = ustar/cs_turb_xkappa*log((zent+rugd)/rugd);
const cs_real_t xvent = 0.0;
const cs_real_t xkent = cs_math_pow2(ustar)/sqrt(cs_turb_cmu);
const cs_real_t xeent = cs_math_pow3(ustar)/cs_turb_xkappa/(zent+rugd);
CS_F_(k)->bc_coeffs->rcodcl1[face_id] = xkent;
CS_F_(eps)->bc_coeffs->rcodcl1[face_id] = xeent;
else if (cs_glob_turb_model->itytur == 3) {
for (int ii = 0; ii< 3; ii++)
CS_F_(rij)->bc_coeffs->rcodcl1[n_b_faces*ii + face_id] = d2o3*xkent;
for (int ii = 3; ii< 6; ii++)
CS_F_(rij)->bc_coeffs->rcodcl1[n_b_faces*ii + face_id] = 0;
CS_F_(phi)->bc_coeffs->rcodcl1[face_id] = d2o3;
CS_F_(f_bar)->bc_coeffs->rcodcl1[face_id] = 0.0;
CS_F_(omg)->bc_coeffs->rcodcl1[face_id] = xeent/cs_turb_cmu/xkent;
CS_F_(nusa)->bc_coeffs->rcodcl1[face_id]
= cs_turb_cmu*cs_math_pow2(xkent)/xeent;
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:319
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
Definition: cs_defs.h:313
@ nusa
Definition: cs_field_pointer.h:81
@ k
@ eps
Definition: cs_field_pointer.h:71
@ omg
Definition: cs_field_pointer.h:80
@ rij
Definition: cs_field_pointer.h:73
@ phi
Definition: cs_field_pointer.h:75
@ f_bar
Definition: cs_field_pointer.h:76
#define CS_F_(e)
static cs_real_t cs_math_pow2(cs_real_t x)
Definition: cs_math.h:238
static cs_real_t cs_math_pow3(cs_real_t x)
Compute the cube of a real value.
Definition: cs_math.h:254
@ CS_INLET
Definition: cs_parameters.h:83
double cs_turb_cmu
Definition: cs_turbulence_model.c:496
double cs_turb_xkappa
Definition: cs_turbulence_model.c:437
const cs_turb_model_t * cs_glob_turb_model
@ CS_TURB_SPALART_ALLMARAS
Definition: cs_turbulence_model.h:69
@ CS_TURB_V2F_PHI
Definition: cs_turbulence_model.h:66
@ CS_TURB_K_OMEGA
Definition: cs_turbulence_model.h:68
int iturb
Definition: cs_turbulence_model.h:117
int itytur
Definition: cs_turbulence_model.h:139
Definition: cs_zone.h:55
const cs_lnum_t * elt_ids
Definition: cs_zone.h:65
Example 4
Define a rough wall at boundary faces of zone 'b_5'.
cs_real_t *bpro_roughness = NULL;
cs_real_t *bpro_roughness_t = NULL;
if (cs_field_by_name_try("boundary_roughness") != NULL)
bpro_roughness = cs_field_by_name_try("boundary_roughness")->val;
if (cs_field_by_name_try("boundary_thermal_roughness") != NULL)
bpro_roughness = cs_field_by_name_try("boundary_thermal_roughness")->val;
const cs_zone_t *zn = cs_boundary_zone_by_name("b_5");
bc_type[face_id] = CS_ROUGHWALL;
if (bpro_roughness != NULL)
bpro_roughness[face_id] = rugd;
if (bpro_roughness_t != NULL)
bpro_roughness_t[face_id] = 0.01;
Return a pointer to a field based on its name if present.
Definition: cs_field.c:2366
@ CS_ROUGHWALL
Definition: cs_parameters.h:88
cs_real_t * val
Definition: cs_field.h:151
cs_lnum_t n_elts
Definition: cs_zone.h:64
