Module for definition of general parameters. More...
Modules | |
| module | paramx |
| integer | nscamx |
maximum number of scalars solutions of an advection equation, apart from the variables of the turbulence model ) , that is to say the temperature and other scalars (passive or not, user-defined or not) More... | |
| integer | nvarmx |
| maximal number of variables = nscamx + 12 (u,v,w,P,Rij,e,alp) More... | |
| integer | ntypmx |
| Maximal possible boundary condition types. More... | |
| integer | iindef |
| integer | ientre |
| integer | isolib |
| integer | isymet |
| integer | iparoi |
| integer | iparug |
| integer | iesicf |
| if itypfb=iesicf: imposed inlet/outlet for compressible flow (for example, supersonic inlet). More... | |
| integer | isspcf |
| if itypfb=isspcf: supersonic outlet for compressible flow. More... | |
| integer | isopcf |
| if itypfb=isopcf: mixed outlet for compressible flow with a given pressure. More... | |
| integer | iephcf |
| if itypfb=iephcf: mixed inlet for compressible flow with given total pressure and total enthalpy (reservoir boundary conditions). More... | |
| integer | ieqhcf |
| integer | icscpl |
| integer | icscpd |
| integer | ifrent |
| integer | ifresf |
| integer | i_convective_inlet |
| integer | nestmx |
| maximal number of valuators for Navier-Stokes More... | |
| integer | iespre |
Error estimator for Navier-Stokes. iest = iespre: prediction, (default name: EsPre). After the velocity prediction step (yielding ), the estimator , local variable calculated at every cell , is created from , which represents the residual of the equation solved during this step: and :
. More... | |
| integer | iesder |
Error estimator for Navier-Stokes. iest = iesder: drift (default name: EsDer). The estimator is based on the following quantity (intrinsic to the code):
. More... | |
| integer | iescor |
Error estimator for Navier-Stokes. iest = iescor: correction, (default name: EsCor). The estimator comes directly from the mass flow calculated with the updated velocity field:
. More... | |
| integer | iestot |
Error estimator for Navier-Stokes. iest = iestot: total, (default name: EsTot). The estimator , local variable calculated at every cell , is based on the quantity , which represents the residual of the equation using the updated values of and :
. More... | |
| integer | ibfixe |
| integer | igliss |
| integer | ivimpo |
| integer | ibalfs |
| integer | nstrmx |
| maximum number of structures in ALE More... | |
| integer | cs_user_boundary_conditions |
| integer | cs_user_parameters |
| integer | cs_user_initialization |
| integer | cs_user_physical_properties |
| integer | cs_user_extra_operations |
| integer | ushist |
| integer | cs_f_user_head_losses |
| integer | cs_user_mass_source_terms |
| integer | cs_user_turbulence_source_terms |
| integer | cs_user_turbulence_source_terms2 |
| integer | usatph |
| integer | ussmag |
| integer | usvosy |
| integer | usvpst |
| integer | usati1 |
| integer | usthht |
| integer | usatsoil |
