7.3
cs_walldistance.c File Reference
#include <errno.h>
#include <locale.h>
#include <float.h>
#include "cs_blas.h"
#include "cs_boundary.h"
#include "cs_equation.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_post.h"
#include "cs_reco.h"
#include "cs_walldistance.h"
+ Include dependency graph for cs_walldistance.c:
Macros
#define _dp3   cs_math_3_dot_product
#define CS_WALLDISTANCE_DBG   0
static void _compute_poisson_cdovcb (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_field_t *field, const cs_equation_t *eq, cs_real_t dist[])
 Compute the wall distance for a vertex+cell-based scheme Estimation based on a Poisson equation. More...
static void _compute_poisson_cdovb (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_field_t *field, cs_real_t dist[])
 Compute the wall distance for a vertex-based scheme Estimation based on a Poisson equation. More...
static void _compute_poisson_cdofb (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_field_t *field, cs_real_t dist[])
 Compute the wall distance for a face-based scheme Estimation based on a Poisson equation. More...
bool cs_walldistance_is_activated (void)
 Test if the computation of the wall distance is activated. More...
void cs_walldistance_activate (void)
 Activate the future computation of the wall distance. More...
void cs_walldistance_setup (void)
 Setup the equation related to the wall distance. More...
void cs_walldistance_compute (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
 Compute the wall distance. More...
static cs_equation_tcs_wd_poisson_eq = NULL
◆ _dp3
◆ CS_WALLDISTANCE_DBG
◆ _compute_poisson_cdofb()
static void _compute_poisson_cdofb ( const cs_cdo_connect_t connect,
const cs_cdo_quantities_t cdoq,
const cs_equation_t eq,
const cs_field_t field,
cs_real_t  dist[]
static
[in]eqpointer to the associated cs_equation_t structure
[in]fieldpointer to a cs_field_t structure
[in,out]distarray storing the wall distance to compute
◆ _compute_poisson_cdovb()
static void _compute_poisson_cdovb ( const cs_cdo_connect_t connect,
cs_real_t  dist[]
static
◆ _compute_poisson_cdovcb()
static void _compute_poisson_cdovcb ( const cs_cdo_connect_t connect,
cs_real_t  dist[]
static
[in]eqpointer to the related cs_equation_t structure
◆ cs_walldistance_activate()
void cs_walldistance_activate ( void  )
◆ cs_walldistance_compute()
void cs_walldistance_compute ( const cs_mesh_t mesh,
const cs_time_step_t time_step,
◆ cs_walldistance_is_activated()
bool cs_walldistance_is_activated ( void  )
true if the wall distance computation is requested, false otherwise
◆ cs_walldistance_setup()
void cs_walldistance_setup ( void  )
◆ cs_wd_poisson_eq
cs_equation_t* cs_wd_poisson_eq = NULL
static
