Include dependency graph for cs_sles_petsc.h:Go to the source code of this file.
| typedef void() | cs_sles_petsc_setup_hook_t(void *context, void *ksp) |
| Function pointer for user settings of a PETSc KSP solver setup. More... | |
| typedef struct _cs_sles_petsc_t | cs_sles_petsc_t |
| void | cs_user_sles_petsc_hook (void *context, void *ksp) |
| void | cs_sles_petsc_init (void) |
| cs_sles_petsc_t * | cs_sles_petsc_define (int f_id, const char *name, const char *matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context) |
| Define and associate a PETSc linear system solver for a given field or equation name. More... | |
| cs_sles_petsc_t * | cs_sles_petsc_create (const char *matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context) |
| Create PETSc linear system solver info and context. More... | |
| void * | cs_sles_petsc_copy (const void *context) |
| Create PETSc linear system solver info and context based on existing info and context. More... | |
| void | cs_sles_petsc_destroy (void **context) |
| Destroy PETSc linear system solver info and context. More... | |
| void | cs_sles_petsc_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| Setup PETSc linear equation solver. More... | |
| cs_sles_convergence_state_t | cs_sles_petsc_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| Call PETSc linear equation solver. More... | |
| void | cs_sles_petsc_free (void *context) |
| Free PETSc linear equation solver setup context. More... | |
| bool | cs_sles_petsc_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx) |
| Error handler for PETSc solver. More... | |
| void | cs_sles_petsc_log (const void *context, cs_log_t log_type) |
| void | cs_sles_petsc_log_setup (void *ksp) |
| void | cs_sles_petsc_set_cvg_criteria (const void *context, double rtol, int max_iter) |
| Set some of the convergence criteria for the associated KSP structure. More... | |
| const char * | cs_sles_petsc_get_mat_type (void *context) |
| Return matrix type associated with PETSc linear system solver info and context. More... | |
| void | cs_sles_petsc_library_info (cs_log_t log_type) |
| Print information on PETSc library. More... | |
| cs_sles_petsc_setup_hook_t |
This function is called the end of the setup stage for a KSP solver.
Note that using the advanced KSPSetPostSolve and KSPSetPreSolve functions, this also allows setting further function pointers for pre and post-solve operations (see the PETSc documentation).
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
| [in,out] | context | pointer to optional (untyped) value or structure |
| [in,out] | ksp | pointer to PETSc KSP context |
| typedef struct _cs_sles_petsc_t cs_sles_petsc_t |
| void* cs_sles_petsc_copy | ( | const void * | context | ) |
| [in] | context | pointer to reference info and context (actual type: cs_sles_petsc_t *) |
| cs_sles_petsc_t* cs_sles_petsc_create | ( | const char * | matrix_type, |
| cs_sles_petsc_setup_hook_t * | setup_hook, | ||
| void * | context | ||
| [in] | matrix_type | PETSc matrix type |
| [in] | setup_hook | pointer to optional setup epilogue function |
| [in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
| cs_sles_petsc_t* cs_sles_petsc_define | ( | int | f_id, |
| const char * | name, | ||
| const char * | matrix_type, | ||
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_petsc_create.
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
| void cs_sles_petsc_destroy | ( | void ** | context | ) |
| [in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_petsc_t **) |
| bool cs_sles_petsc_error_post_and_abort | ( | cs_sles_t * | sles, |
| cs_real_t * | vx | ||
In case of divergence or breakdown, this error handler outputs an error message It does nothing in case the maximum iteration count is reached.
| [in] | a | matrix |
| void cs_sles_petsc_free | ( | void * | context | ) |
| [in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_petsc_t *) |
| const char* cs_sles_petsc_get_mat_type | ( | void * | context | ) |
| void cs_sles_petsc_init | ( | void | ) |
| void cs_sles_petsc_library_info | ( | cs_log_t | log_type | ) |
| void cs_sles_petsc_log | ( | const void * | context, |
| cs_log_t | log_type | ||
| [in] | context | pointer to iterative solver info and context (actual type: cs_sles_petsc_t *) |
| void cs_sles_petsc_log_setup | ( | void * | ksp | ) |
| void cs_sles_petsc_set_cvg_criteria | ( | const void * | context, |
| double | rtol, | ||
| int | max_iter | ||
| [in] | rtol | relative tolerance value |
| [in] | max_iter | max. number of iterations |
| void cs_sles_petsc_setup | ( | void * | context, |
| int | verbosity | ||
| cs_sles_convergence_state_t cs_sles_petsc_solve | ( | void * | context, |
| int | verbosity, | ||
| double | precision, | ||
| double | r_norm, | ||
| int * | n_iter, | ||
| double * | residue, | ||
| cs_real_t * | vx, | ||
| size_t | aux_size, | ||
| void * | aux_vectors | ||
| [in] | a | matrix |
| [out] | residue | residue |
| void cs_user_sles_petsc_hook | ( | void * | context, |
| void * | ksp | ||
