7.3
cs_sles_default.h File Reference
#include "cs_halo_perio.h"
#include "cs_matrix.h"
#include "cs_sles.h"
+ Include dependency graph for cs_sles_default.h:
void cs_sles_default_log_setup (void)
void cs_sles_default (int f_id, const char *name, const cs_matrix_t *a)
 Default definition of a sparse linear equation solver. More...
void cs_sles_default_setup (void)
 Default setup for sparse linear equation solver API. More...
int cs_sles_default_get_verbosity (int f_id, const char *name)
 Return default verbosity associated to a field id, name couple. More...
void cs_sles_default_finalize (void)
 Default finalization for sparse linear equation solver API. More...
void cs_sles_setup_native_conv_diff (int f_id, const char *name, const cs_lnum_t diag_block_size, const cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa, bool conv_diff)
 Call sparse linear equation solver setup for convection-diffusion systems. More...
cs_sles_convergence_state_t cs_sles_solve_native (int f_id, const char *name, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx)
 Call sparse linear equation solver using native matrix arrays. More...
void cs_sles_free_native (int f_id, const char *name)
 Free sparse linear equation solver setup using native matrix arrays. More...
bool cs_sles_default_error (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t rhs[], cs_real_t vx[])
 Error handler attempting fallback to alternative solution procedure for sparse linear equation solver. More...
◆ cs_sles_default()
void cs_sles_default ( int  f_id,
const char *  name,
const cs_matrix_t a
[in]nameassociated name if f_id < 0, or NULL
[in]amatrix
◆ cs_sles_default_error()
bool cs_sles_default_error ( cs_sles_t sles,
const cs_matrix_t a,
cs_real_t  vx[]
In case of divergence with an iterative solver, this error handler switches to a default preconditioner, then resets the solution vector.
The default error for the solver type handler is then set, in case the solution fails again.
Note that this error handler may rebuild solver contexts, so should not be used in conjunction with shared contexts (such as multigrid ascent/descent contexts), but only for "outer" solvers.
[in,out]slespointer to solver object
[in]stateconvergence status
[in]amatrix
[in]rhsright hand side
[in,out]vxsystem solution
true if fallback solution is possible, false otherwise
◆ cs_sles_default_finalize()
void cs_sles_default_finalize ( void  )
This includes performance data logging output.
◆ cs_sles_default_get_verbosity()
int cs_sles_default_get_verbosity ( int  f_id,
const char *  name
verbosity associated with field or name
◆ cs_sles_default_log_setup()
void cs_sles_default_log_setup ( void  )
◆ cs_sles_default_setup()
void cs_sles_default_setup ( void  )
This includes setup logging.
◆ cs_sles_free_native()
void cs_sles_free_native ( int  f_id,
const char *  name
◆ cs_sles_setup_native_conv_diff()
void cs_sles_setup_native_conv_diff ( int  f_id,
const char *  name,
const cs_real_t da,
const cs_real_t xa,
bool  conv_diff
[in]diag_block_sizeblock sizes for diagonal, or NULL
[in]extra_diag_block_sizeblock sizes for extra diagonal, or NULL
[in]dadiagonal values (NULL if zero)
[in]xaextradiagonal values (NULL if zero)
[in]conv_diffconvection-diffusion mode
◆ cs_sles_solve_native()
cs_sles_convergence_state_t cs_sles_solve_native ( int  f_id,
const char *  name,
bool  symmetric,
const cs_real_t da,
const cs_real_t xa,
double  precision,
double  r_norm,
int *  n_iter,
double *  residue,
const cs_real_t rhs,
cs_real_t vx
[in]symmetricindicates if matrix coefficients are symmetric
[in]precisionsolver precision
[in]r_normresidue normalization
[out]residueresidue
convergence state
