◆ cs_notebook_destroy_all()
| void cs_notebook_destroy_all |
void |
Destroy the notebook structure.
Destroys the structures related to the notebook.
◆ cs_notebook_get_values()
| void cs_notebook_get_values |
int |
n, |
const int |
ids[], |
double |
values[] |
Get a group of notebook variable values.
- Parameters
| [in] | n | number of notebook variables to query |
| [in] | ids | ids of notebook variables to query (value set to 0 where id < 0) |
| [out] | values | values of notebook variables to query |
◆ cs_notebook_load_from_file()
| void cs_notebook_load_from_file |
void |
Initialize the notebook object (based on cs_tree_node_t).
◆ cs_notebook_log()
| void cs_notebook_log |
void |
Output the notebook info to the setup log.
◆ cs_notebook_parameter_get_description()
| const char* cs_notebook_parameter_get_description |
char * |
name | ) |
Returns the description of the parameter (GUI defined).
- Parameters
| [in] | name | name of the parameter |
- Returns
- a const char pointer containing the description.
◆ cs_notebook_parameter_get_id()
| int cs_notebook_parameter_get_id |
const char * |
name | ) |
Get id associated with a notebook parameter.
- Parameters
- Returns
- -1 if not present, id if present
◆ cs_notebook_parameter_get_openturns_status()
| int cs_notebook_parameter_get_openturns_status |
char * |
name | ) |
Indicate whether the parameter is used for a study with openturns.
Returns an int flag to indicate whether this paramter is used for an OpenTurns study. -1 : The parameter is not used with OpenTurns 0 : The parameter is used as an input from OpenTurns 1 : The parameter is used as an output to OpenTurns
- Parameters
- Returns
- an int flag value
◆ cs_notebook_parameter_is_present()
| int cs_notebook_parameter_is_present |
const char * |
name, |
int * |
editable |
Check if a parameter value is present.
- Parameters
| [out] | editable | 1 if the value is editable, 0 otherwise (optional) |
- Returns
- 0 if not present, 1 if present
◆ cs_notebook_parameter_set_value()
| void cs_notebook_parameter_set_value |
const char * |
name, |
cs_real_t |
val |
Set a parameter value (real) for an editable parameter.
The name used is the same as the one in the GUI.
- Parameters
| [in] | val | value of the parameter |
◆ cs_notebook_parameter_value_by_name()
| cs_real_t cs_notebook_parameter_value_by_name |
const char * |
name | ) |
Return a parameter value (real).
- Parameters
- Returns
- value of the given parameter
◆ cs_notebook_set_values()
| void cs_notebook_set_values |
int |
n, |
const int |
ids[], |
const double |
values[] |
Set a group of notebook variable values.
- Parameters
| [in] | n | number of notebook variables to set |
| [in] | ids | ids of notebook variables to set (ignored where id < 0) |
| [in] | values | values of notebook variables to set |
◆ cs_notebook_uncertain_output()
| void cs_notebook_uncertain_output |
void |
Write uncertain values to output file.
If input and output uncertain variables are provided, output values are written to an output file: cs_uncertain_output.dat Results are ordered in the definition order in the notebook.
