7.3
cs_notebook.h
1 #ifndef __CS_NOTEBOOK_H__
2 #define __CS_NOTEBOOK_H__
5  * Notebook management.
29  * Local headers
32 #include "cs_defs.h"
34 /*----------------------------------------------------------------------------*/
44 void
46
47 /*----------------------------------------------------------------------------*/
56 /*----------------------------------------------------------------------------*/
57
58 int
59 cs_notebook_parameter_is_present(const char *name,
60  int *editable);
61
73
75 cs_notebook_parameter_value_by_name(const char *name);
76
77 /*----------------------------------------------------------------------------*/
86 /*----------------------------------------------------------------------------*/
87
88 void
89 cs_notebook_parameter_set_value(const char *name,
90  cs_real_t val);
91
92 /*----------------------------------------------------------------------------*/
106 /*----------------------------------------------------------------------------*/
107
108 int
110
111 /*----------------------------------------------------------------------------*/
119 /*----------------------------------------------------------------------------*/
120
121 const char *
123
124 /*----------------------------------------------------------------------------*/
132 /*----------------------------------------------------------------------------*/
133
134 int
135 cs_notebook_parameter_get_id(const char *name);
136
137 /*----------------------------------------------------------------------------*/
147
148 void
150  const int ids[],
151  double values[]);
152
153 /*----------------------------------------------------------------------------*/
162 /*----------------------------------------------------------------------------*/
163
164 void
166  const int ids[],
167  const double values[]);
168
169 /*----------------------------------------------------------------------------*/
175 /*----------------------------------------------------------------------------*/
176
177 void
179
180 /*----------------------------------------------------------------------------*/
184 /*----------------------------------------------------------------------------*/
185
186 void
187 cs_notebook_log(void);
188
189 /*----------------------------------------------------------------------------*/
197 /*----------------------------------------------------------------------------*/
198
199 void
201
202 /*----------------------------------------------------------------------------*/
203
205
206 #endif /* __CS_NOTEBOOK_H__ */
cs_real_t cs_notebook_parameter_value_by_name(const char *name)
Return a parameter value (real).
Definition: cs_notebook.c:383
Definition: cs_defs.h:512
void cs_notebook_load_from_file(void)
Initialize the notebook object (based on cs_tree_node_t).
Definition: cs_notebook.c:277
const char * cs_notebook_parameter_get_description(char *name)
Returns the description of the parameter (GUI defined).
Definition: cs_notebook.c:448
Definition: cs_defs.h:322
void cs_notebook_get_values(int n, const int ids[], double values[])
Get a group of notebook variable values.
Definition: cs_notebook.c:484
int cs_notebook_parameter_is_present(const char *name, int *editable)
Check if a parameter value is present.
Definition: cs_notebook.c:351
void cs_notebook_log(void)
Output the notebook info to the setup log.
Definition: cs_notebook.c:566
Definition: cs_defs.h:513
int cs_notebook_parameter_get_openturns_status(char *name)
Indicate whether the parameter is used for a study with openturns.
Definition: cs_notebook.c:431
void cs_notebook_parameter_set_value(const char *name, cs_real_t val)
Set a parameter value (real) for an editable parameter.
Definition: cs_notebook.c:401
void cs_notebook_uncertain_output(void)
Write uncertain values to output file.
Definition: cs_notebook.c:605
void cs_notebook_set_values(int n, const int ids[], const double values[])
Set a group of notebook variable values.
Definition: cs_notebook.c:509
int cs_notebook_parameter_get_id(const char *name)
Get id associated with a notebook parameter.
Definition: cs_notebook.c:465
void cs_notebook_destroy_all(void)
Destroy the notebook structure.
Definition: cs_notebook.c:536
