#include <stdarg.h>
#include "MEDCouplingUMesh.hxx"
◆ cs_medcoupling_mesh_destroy()
◆ cs_medcoupling_mesh_destroy_all()
| void cs_medcoupling_mesh_destroy_all |
void |
◆ cs_medcoupling_mesh_from_base()
| cs_medcoupling_mesh_t* cs_medcoupling_mesh_from_base |
cs_mesh_t * |
csmesh, |
const char * |
name, |
const char * |
selection_criteria, |
int |
elt_dim, |
int |
use_bbox |
create a new cs_medcoupling_mesh_t instance based on cs_mesh_t
- Parameters
| [in] | csmesh | pointer to cs_mesh_t instance |
| [in] | name | name of the mesh |
| [in] | selection_criteria | selection criteria string |
| [in] | elt_dim | dimension of elements (2: faces, 3: cells) |
| [in] | use_bbox | Use a reduced bounding box |
- Returns
- pointer to the newly created cs_medcoupling_mesh_t struct
◆ cs_medcoupling_mesh_from_ids()
- Parameters
| [in] | n_elts | local number of elements |
| [in] | elt_ids | list of local elements |
| [in] | use_bbox | use a reduced bounding box |
- Returns
◆ cs_medcoupling_mesh_get_connectivity()
Return a cs_medcoupling_mesh_t structure's (parent) elements list.
- Parameters
- Returns
- ids of associated elements, or NULL
◆ cs_medcoupling_mesh_get_dim()
Return a cs_medcoupling_mesh_t structure's spatial dimension.
- Parameters
- Returns
- associated spatial dimension
◆ cs_medcoupling_mesh_get_elt_list()
- Parameters
- Returns
◆ cs_medcoupling_mesh_get_n_elts()
Return a cs_medcoupling_mesh_t structure's number of elements.
- Parameters
- Returns
- associated number of elements
◆ cs_medcoupling_mesh_get_n_vertices()
Return a cs_medcoupling_mesh_t structure's number of vertices.
- Parameters
- Returns
- associated number of vertices
◆ cs_medcoupling_mesh_get_vertex_list()
Return a cs_medcoupling_mesh_t structure's (parent) vertices list.
- Parameters
- Returns
- ids of associated vertices, or NULL if all or no local vertices o parent mesh are present.
