1 #ifndef __CS_MEDCOUPLING_MESH_HXX__ 2 #define __CS_MEDCOUPLING_MESH_HXX__ 47 #if defined(HAVE_MEDCOUPLING) 49 #include "MEDCouplingUMesh.hxx" 81 #if defined(HAVE_MEDCOUPLING) 110 const char *selection_criteria,
Definition: cs_medcoupling_mesh.hxx:61
int cs_medcoupling_mesh_get_dim(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's spatial dimension.
Definition: cs_medcoupling_mesh.cxx:988
const cs_lnum_t * cs_medcoupling_mesh_get_elt_list(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's (parent) elements list.
Definition: cs_medcoupling_mesh.cxx:1028
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_base(cs_mesh_t *csmesh, const char *name, const char *selection_criteria, int elt_dim, int use_bbox)
create a new cs_medcoupling_mesh_t instance based on cs_mesh_t
Definition: cs_medcoupling_mesh.cxx:847
cs_real_t * bbox
Definition: cs_medcoupling_mesh.hxx:79
Definition: cs_defs.h:512
cs_lnum_t cs_medcoupling_mesh_get_n_elts(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's number of elements.
Definition: cs_medcoupling_mesh.cxx:1008
MEDCouplingUMesh * med_mesh
Definition: cs_medcoupling_mesh.hxx:82
cs_lnum_t n_vtx
Definition: cs_medcoupling_mesh.hxx:72
int elt_dim
Definition: cs_medcoupling_mesh.hxx:66
Definition: cs_defs.h:322
cs_lnum_t cs_medcoupling_mesh_get_n_vertices(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's number of vertices.
Definition: cs_medcoupling_mesh.cxx:1049
const cs_lnum_t * cs_medcoupling_mesh_get_vertex_list(cs_medcoupling_mesh_t *m)
Return a cs_medcoupling_mesh_t structure's (parent) vertices list.
Definition: cs_medcoupling_mesh.cxx:1070
const cs_lnum_t * cs_medcoupling_mesh_get_connectivity(cs_medcoupling_mesh_t *m)
Definition: cs_medcoupling_mesh.cxx:1091
cs_lnum_t * new_to_old
Definition: cs_medcoupling_mesh.hxx:76
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_ids(cs_mesh_t *csmesh, const char *name, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int elt_dim, int use_bbox)
Definition: cs_medcoupling_mesh.cxx:900
cs_lnum_t * vtx_list
Definition: cs_medcoupling_mesh.hxx:73
Definition: cs_defs.h:316
Definition: cs_defs.h:513
void cs_medcoupling_mesh_destroy_all(void)
Destroy all cs_medcoupling_mesh_t instances.
Definition: cs_medcoupling_mesh.cxx:963
void cs_medcoupling_mesh_destroy(cs_medcoupling_mesh_t *mesh)
Destroy a cs_medcoupling_mesh_t.
Definition: cs_medcoupling_mesh.cxx:941
cs_lnum_t n_elts
Definition: cs_medcoupling_mesh.hxx:68
cs_lnum_t * elt_list
Definition: cs_medcoupling_mesh.hxx:69
char * sel_criteria
Definition: cs_medcoupling_mesh.hxx:63
