7.3
cs_hho_stokes.c File Reference
#include <float.h>
#include <bft_mem.h>
#include "cs_boundary_zone.h"
#include "cs_equation_priv.h"
#include "cs_hho_builder.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_post.h"
#include "cs_quadrature.h"
#include "cs_reco.h"
#include "cs_scheme_geometry.h"
#include "cs_search.h"
#include "cs_sdm.h"
#include "cs_source_term.h"
#include "cs_hho_stokes.h"
+ Include dependency graph for cs_hho_stokes.c:
Macros
#define CS_HHO_STOKES_DBG   1
#define CS_HHO_STOKES_MODULO   4
#define _dp3   cs_math_3_dot_product
static cs_cell_builder_t_cell_builder_create (cs_param_space_scheme_t space_scheme, const cs_cdo_connect_t *connect)
 Initialize the local builder structure used for building the system cellwise. More...
void cs_hho_stokes_initialize (cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_assembler_t *ma0, const cs_matrix_assembler_t *ma1, const cs_matrix_assembler_t *ma2, const cs_matrix_structure_t *ms0, const cs_matrix_structure_t *ms1, const cs_matrix_structure_t *ms2)
 Allocate work buffer and general structures related to HHO schemes Set shared pointers. More...
void cs_hho_stokes_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
void cs_hho_stokes_finalize (void)
 Free buffers and generic structures related to HHO schemes. More...
void * cs_hho_stokes_init_context (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb)
 Initialize a cs_hho_stokes_t structure storing data useful for managing such a scheme. More...
void * cs_hho_stokes_free_context (void *data)
 Destroy a cs_hho_stokes_t structure. More...
void cs_hho_stokes_compute_source (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
 Compute the contributions of source terms (store inside builder) More...
void cs_hho_stokes_build_system (const cs_mesh_t *mesh, const cs_real_t *field_val, double dt_cur, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
 Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme. One works cellwise and then process to the assembly. More...
void cs_hho_stokes_update_field (const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
 Store solution(s) of the linear system into a field structure Update extra-field values required for hybrid discretization. More...
double * cs_hho_stokes_get_face_values (const void *data)
 Get the computed values at faces (DoF used in the linear system are located at primal faces) More...
double * cs_hho_stokes_get_cell_values (const void *data)
 Get the computed values at cells (DoF used in the linear system are located at primal faces) More...
void cs_hho_stokes_extra_op (const char *eqname, const cs_field_t *field, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
static cs_cell_sys_t ** cs_hho_cell_sys = NULL
static cs_cell_builder_t ** cs_hho_cell_bld = NULL
static cs_hho_builder_t ** cs_hho_builders = NULL
static const cs_cdo_quantities_tcs_shared_quant
static const cs_cdo_connect_tcs_shared_connect
static const cs_time_step_tcs_shared_time_step
static const cs_matrix_assembler_tcs_shared_ma0
static const cs_matrix_structure_tcs_shared_ms0
static const cs_matrix_assembler_tcs_shared_ma1
static const cs_matrix_structure_tcs_shared_ms1
static const cs_matrix_assembler_tcs_shared_ma2
static const cs_matrix_structure_tcs_shared_ms2
◆ _dp3
◆ CS_HHO_STOKES_DBG
◆ CS_HHO_STOKES_MODULO
◆ _cell_builder_create()
static cs_cell_builder_t* _cell_builder_create ( cs_param_space_scheme_t  space_scheme,
const cs_cdo_connect_t connect
static
[in]space_schemediscretization scheme
a pointer to a new allocated cs_cell_builder_t structure
◆ cs_hho_stokes_build_system()
void cs_hho_stokes_build_system ( const cs_mesh_t mesh,
const cs_real_t field_val,
double  dt_cur,
const cs_equation_param_t eqp,
cs_equation_builder_t eqb,
void *  data
[in]field_valpointer to the current value of the field
[in]dt_curcurrent value of the time step
[in,out]datapointer to cs_hho_stokes_t structure
◆ cs_hho_stokes_compute_source()
void cs_hho_stokes_compute_source ( const cs_equation_param_t eqp,
void *  data
[in,out]datapointer to a cs_hho_stokes_t structure
◆ cs_hho_stokes_extra_op()
void cs_hho_stokes_extra_op ( const char *  eqname,
const cs_field_t field,
void *  data
[in]eqnamename of the equation
[in]fieldpointer to a field structure
◆ cs_hho_stokes_finalize()
void cs_hho_stokes_finalize ( void  )
◆ cs_hho_stokes_free_context()
void* cs_hho_stokes_free_context ( void *  data)
a NULL pointer
◆ cs_hho_stokes_get()
void cs_hho_stokes_get ( cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb,
cs_hho_builder_t **  hhob
[out]hhobpointer to a pointer on a cs_hho_builder_t structure
◆ cs_hho_stokes_get_cell_values()
double* cs_hho_stokes_get_cell_values ( const void *  data)
[in]datapointer to a data structure
a pointer to an array of double
◆ cs_hho_stokes_get_face_values()
double* cs_hho_stokes_get_face_values ( const void *  data)
◆ cs_hho_stokes_init_context()
void* cs_hho_stokes_init_context ( const cs_equation_param_t eqp,
a pointer to a new allocated cs_hho_stokes_t structure
◆ cs_hho_stokes_initialize()
void cs_hho_stokes_initialize ( cs_flag_t  scheme_flag,
const cs_time_step_t time_step,
const cs_matrix_assembler_t ma0,
const cs_matrix_assembler_t ma1,
const cs_matrix_assembler_t ma2,
const cs_matrix_structure_t ms0,
const cs_matrix_structure_t ms1,
const cs_matrix_structure_t ms2
[in]scheme_flagflag to identify which kind of numerical scheme is requested to solve the computational domain
[in]ma0pointer to a cs_matrix_assembler_t structure (P0)
[in]ma1pointer to a cs_matrix_assembler_t structure (P1)
[in]ma2pointer to a cs_matrix_assembler_t structure (P2)
[in]ms0pointer to a cs_matrix_structure_t structure (P0)
[in]ms1pointer to a cs_matrix_structure_t structure (P1)
[in]ms2pointer to a cs_matrix_structure_t structure (P2)
◆ cs_hho_stokes_update_field()
void cs_hho_stokes_update_field ( const cs_real_t solu,
const cs_real_t rhs,
void *  data,
cs_real_t field_val
[in]solusolution array
[in]rhsrhs associated to this solution array
[in,out]field_valpointer to the current value of the field
◆ cs_hho_builders
cs_hho_builder_t** cs_hho_builders = NULL
static
◆ cs_hho_cell_bld
cs_cell_builder_t** cs_hho_cell_bld = NULL
static
◆ cs_hho_cell_sys
cs_cell_sys_t** cs_hho_cell_sys = NULL
static
◆ cs_shared_connect
const cs_cdo_connect_t* cs_shared_connect
static
◆ cs_shared_ma0
const cs_matrix_assembler_t* cs_shared_ma0
static
◆ cs_shared_ma1
const cs_matrix_assembler_t* cs_shared_ma1
static
◆ cs_shared_ma2
const cs_matrix_assembler_t* cs_shared_ma2
static
◆ cs_shared_ms0
const cs_matrix_structure_t* cs_shared_ms0
static
◆ cs_shared_ms1
const cs_matrix_structure_t* cs_shared_ms1
static
◆ cs_shared_ms2
const cs_matrix_structure_t* cs_shared_ms2
static
◆ cs_shared_quant
const cs_cdo_quantities_t* cs_shared_quant
static
◆ cs_shared_time_step
const cs_time_step_t* cs_shared_time_step
static
