| cs_halo_t * | cs_halo_create (const cs_interface_set_t *ifs) |
| | Create a halo structure given an interface set. More...
| void | cs_halo_create_complete (cs_halo_t *halo) |
| | Ready halo for use. More...
| cs_halo_t * | cs_halo_create_from_ref (const cs_halo_t *ref) |
| | Create a halo structure, given a reference halo. More...
| cs_halo_t * | cs_halo_create_from_rank_neighbors (const cs_rank_neighbors_t *rn, cs_lnum_t n_local_elts, cs_lnum_t n_distant_elts, const int elt_rank_id[], const cs_lnum_t elt_id[]) |
| | Create a halo structure from distant element distant ranks and ids. More...
| void | cs_halo_destroy (cs_halo_t **halo) |
| cs_halo_state_t * | cs_halo_state_create (void) |
| | Create a halo state structure. More...
| void | cs_halo_state_destroy (cs_halo_state_t **halo_state) |
| | Destroy a halo state structure. More...
| cs_halo_state_t * | cs_halo_state_get_default (void) |
| | Get pointer to default halo state structure. More...
| void | cs_halo_renumber_cells (cs_halo_t *halo, const cs_lnum_t new_cell_id[]) |
| void | cs_halo_renumber_ghost_cells (cs_halo_t *halo, const cs_lnum_t old_cell_id[]) |
| void * | cs_halo_sync_pack_init_state (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *send_buf, cs_halo_state_t *hs) |
| | Initialize halo state prior to packing halo data to send. More...
| void | cs_halo_sync_pack (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *val, void *send_buf, cs_halo_state_t *hs) |
| | Pack halo data to send into dense buffer. More...
| void | cs_halo_sync_start (const cs_halo_t *halo, void *val, cs_halo_state_t *hs) |
| | Launch update array of values in case of parallelism or periodicity. More...
| void | cs_halo_sync_wait (const cs_halo_t *halo, void *val, cs_halo_state_t *hs) |
| | Wait for completion of update array of values in case of parallelism or periodicity. More...
| void | cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *val) |
| | Update array of values in case of parallelism or periodicity. More...
| void | cs_halo_sync_untyped (const cs_halo_t *halo, cs_halo_type_t sync_mode, size_t size, void *val) |
| void | cs_halo_sync_num (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_lnum_t num[]) |
| void | cs_halo_sync_var (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[]) |
| void | cs_halo_sync_var_strided (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[], int stride) |
| bool | cs_halo_get_use_barrier (void) |
| void | cs_halo_set_use_barrier (bool use_barrier) |
| cs_halo_comm_mode_t | cs_halo_get_comm_mode (void) |
| | Get default communication mode for halo exchange. More...
| void | cs_halo_set_comm_mode (cs_halo_comm_mode_t mode) |
| | Set default communication mode for halo exchange. More...
| cs_alloc_mode_t | cs_halo_get_buffer_alloc_mode (void) |
| | Get default host/device allocation mode for message packing arrays. More...
| void | cs_halo_set_buffer_alloc_mode (cs_alloc_mode_t mode) |
| | Set default host/device allocation mode for message packing arrays. More...
| void | cs_halo_dump (const cs_halo_t *halo, int print_level) |
A local state handler may be provided, or the default state handler will be used.
A local state and/or buffer may be provided, or the default (global) state and buffer will be used. If provided explicitely, the buffer must be of sufficient size.
- Parameters
| [in] | halo | pointer to halo structure |
| [in] | sync_mode | synchronization mode (standard or extended) |
| [in] | data_type | data type |
| [in] | stride | number of (interlaced) values by entity |
| [in] | val | pointer to variable value array |
| [out] | send_buf | pointer to send buffer, NULL for global buffer |
| [in,out] | hs | pointer to halo state, NULL for global state |
This function is included in cs_halo_sync_pack, but may be called separately for specific implementations, such as for accelerator devices.
- Parameters
- Returns
- pointer to halo send buffer
This function aims at copying main values from local elements (id between 1 and n_local_elements) to ghost elements on distant ranks (id between n_local_elements + 1 to n_local_elements_with_halo).
The cs_halo_sync_start function should have been called before this function, using the same hs argument.
- Parameters
