1 #ifndef __CS_BASE_ACCEL_H__ 2 #define __CS_BASE_ACCEL_H__ 64 #define CS_MALLOC_HD(_ptr, _ni, _type, _mode) \ 65 _ptr = (_type *) cs_malloc_hd(_mode, _ni, sizeof(_type), \ 66 #_ptr, __FILE__, __LINE__) 84 #define CS_REALLOC_HD(_ptr, _ni, _type, _mode) \ 85 _ptr = (_type *) cs_realloc_hd(_ptr, _mode, _ni, sizeof(_type), \ 86 #_ptr, __FILE__, __LINE__) 104 #define CS_FREE_HD(_ptr) \ 105 cs_free_hd(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL 123 #define CS_FREE(_ptr) \ 124 cs_free(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL 159 #if defined(HAVE_ACCEL) 165 #define cs_alloc_mode CS_ALLOC_HOST 181 #if defined(HAVE_ACCEL) 217 #if defined(HAVE_ACCEL) 223 const char *var_name,
224 const char *file_name,
233 const char *var_name,
234 const char *file_name,
273 #if defined(HAVE_ACCEL) 280 const char *var_name,
281 const char *file_name,
291 const char *var_name,
292 const char *file_name,
315 #if defined(HAVE_ACCEL) 319 const char *var_name,
320 const char *file_name,
327 const char *var_name,
328 const char *file_name,
350 #if defined(HAVE_ACCEL) 354 const char *var_name,
355 const char *file_name,
362 const char *var_name,
363 const char *file_name,
387 #if defined(HAVE_ACCEL) 418 #if defined(HAVE_ACCEL) 425 inline static const void *
450 #if defined(HAVE_ACCEL) 457 inline static const void *
476 #if defined(HAVE_ACCEL) 508 #if defined(HAVE_ACCEL) 517 #define cs_associate_device_ptr(_host_ptr, _ni, _size); 532 #if defined(HAVE_ACCEL) 539 #define cs_disassociate_device_ptr(_host_ptr); 556 #if defined(HAVE_ACCEL) 564 #define cs_set_alloc_mode(_host_ptr, mode); 586 #if defined(HAVE_ACCEL) 625 #if defined(HAVE_ACCEL) 659 #if defined(HAVE_ACCEL) 687 #if defined(HAVE_ACCEL) 718 #if defined(HAVE_ACCEL) 736 #if defined(HAVE_ACCEL) 802 #if defined(HAVE_ACCEL) 827 #if defined(HAVE_ACCEL) 843 #if defined(HAVE_OPENMP_TARGET) 857 cs_omp_target_select_default_device(
void);
884 #if defined(HAVE_ACCEL) 888 cs_set_alloc_mode_r(T* &host_ptr,
898 #define cs_set_alloc_mode_r(_host_ptr, mode); #define cs_disassociate_device_ptr(_host_ptr)
Detach device memory from a given host memory pointer.
Definition: cs_base_accel.h:539
static size_t cs_get_allocation_hd_size(void *host_ptr)
Check if a given host pointer is allocated with associated with cs_alloc_hd or cs_realloc_hd.
Definition: cs_base_accel.h:835
void cs_copy_h2d(void *dest, const void *src, size_t size)
Copy data from host to device.
Definition: cs_base_accel.cxx:1406
static int cs_get_n_allocations_hd(void)
Return number of host-device allocations.
Definition: cs_base_accel.h:810
Definition: cs_defs.h:512
static void cs_sync_d2h(void *ptr)
Synchronize data from device to host.
Definition: cs_base_accel.h:667
#define CS_UNUSED(x)
Definition: cs_defs.h:498
Definition: cs_base_accel.h:144
static int cs_get_device_id(void)
Return currently associated device id.
Definition: cs_base_accel.h:189
static void cs_sync_h2d(const void *ptr)
Synchronize data from host to device.
Definition: cs_base_accel.h:594
Definition: cs_field_pointer.h:67
Definition: cs_base_accel.h:146
void * bft_mem_realloc(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Reallocate memory for ni elements of size bytes.
Definition: bft_mem.c:899
Definition: cs_base_accel.h:145
Associate device memory with a given host memory pointer.
Definition: cs_base_accel.h:517
Definition: cs_base_accel.h:165
static void * cs_realloc_hd(void *ptr, cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Reallocate memory on host and device for ni elements of size bytes.
Definition: cs_base_accel.h:287
static cs_alloc_mode_t cs_check_device_ptr(const void *ptr)
Check if a pointer is associated with a device.
Definition: cs_base_accel.h:484
cs_alloc_mode_t
Definition: cs_base_accel.h:142
static void cs_prefetch_d2h(void *ptr, size_t size)
Prefetch data from device to host.
Definition: cs_base_accel.h:727
Set allocation mode for an already allocated pointer.
Definition: cs_base_accel.h:564
static void * cs_malloc_hd(cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Allocate memory on host and device for ni elements of size bytes.
Definition: cs_base_accel.h:230
Definition: cs_base_accel.h:149
static const void * cs_get_device_ptr_const(const void *ptr)
Return matching device pointer for a given constant pointer.
Definition: cs_base_accel.h:426
Definition: cs_defs.h:513
static void cs_free_hd(void *ptr, const char *var_name, const char *file_name, int line_num)
Free memory on host and device for a given host pointer.
Definition: cs_base_accel.h:326
void cs_copy_d2h(void *dest, const void *src, size_t size)
Copy data from device to host.
Definition: cs_base_accel.cxx:1436
void cs_copy_d2d(void *dest, const void *src, size_t size)
Copy data from device to device.
Definition: cs_base_accel.cxx:1466
Definition: cs_base_accel.h:151
void * bft_mem_free(void *ptr, const char *var_name, const char *file_name, int line_num)
Free allocated memory.
Definition: bft_mem.c:1056
static void cs_prefetch_h2d(void *ptr, size_t size)
Prefetch data from host to device.
Definition: cs_base_accel.h:696
static void * cs_get_device_ptr(void *ptr)
Return matching device pointer for a given pointer.
Definition: cs_base_accel.h:395
static const void * cs_get_device_ptr_const_pf(const void *ptr)
Return matching device pointer for a given constant pointer, prefetching if applicable.
Definition: cs_base_accel.h:458
void * bft_mem_malloc(size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Allocate memory for ni elements of size bytes.
Definition: bft_mem.c:815
static void cs_sync_h2d_future(const void *ptr)
Initiate synchronization of data from host to device for future access.
Definition: cs_base_accel.h:633
static void cs_free(void *ptr, const char *var_name, const char *file_name, int line_num)
Free memory on host and device for a given pointer.
Definition: cs_base_accel.h:361
