7.3
cs_base_accel.cxx File Reference
#include <map>
#include "cs_base_accel.h"
+ Include dependency graph for cs_base_accel.cxx:
int cs_get_device_id (void)
 Return currently associated device id. More...
void * cs_malloc_hd (cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
 Allocate memory on host and device for ni elements of size bytes. More...
void * cs_realloc_hd (void *ptr, cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
 Reallocate memory on host and device for ni elements of size bytes. More...
void cs_free_hd (void *ptr, const char *var_name, const char *file_name, int line_num)
 Free memory on host and device for a given host pointer. More...
void cs_free (void *ptr, const char *var_name, const char *file_name, int line_num)
 Free memory on host and device for a given pointer. More...
void * cs_get_device_ptr (void *ptr)
 Return matching device pointer for a given pointer. More...
const void * cs_get_device_ptr_const (const void *ptr)
 Return matching device pointer for a given constant pointer. More...
const void * cs_get_device_ptr_const_pf (const void *ptr)
 Return matching device pointer for a given constant pointer, prefetching if applicable. More...
cs_alloc_mode_t cs_check_device_ptr (const void *ptr)
 Check if a pointer is associated with a device. More...
void * cs_associate_device_ptr (void *host_ptr, size_t ni, size_t size)
 Associate device memory with a given host memory pointer. More...
void cs_disassociate_device_ptr (void *host_ptr)
 Detach device memory from a given host memory pointer. More...
void cs_set_alloc_mode (void **host_ptr, cs_alloc_mode_t mode)
 Set allocation mode for an already allocated pointer. More...
void cs_sync_h2d (const void *ptr)
 Synchronize data from host to device. More...
void cs_sync_h2d_future (const void *ptr)
 Initiate synchronization of data from host to device for future access. More...
void cs_sync_d2h (void *ptr)
 Synchronize data from device to host. More...
void cs_prefetch_h2d (void *ptr, size_t size)
 Prefetch data from host to device. More...
void cs_prefetch_d2h (void *ptr, size_t size)
 Prefetch data from device to host. More...
void cs_copy_h2d (void *dest, const void *src, size_t size)
 Copy data from host to device. More...
void cs_copy_d2h (void *dest, const void *src, size_t size)
 Copy data from device to host. More...
void cs_copy_d2d (void *dest, const void *src, size_t size)
 Copy data from device to device. More...
int cs_get_n_allocations_hd (void)
 Return number of host-device allocations. More...
size_t cs_get_allocation_hd_size (void *host_ptr)
 Check if a given host pointer is allocated with associated with cs_alloc_hd or cs_realloc_hd. More...
◆ cs_associate_device_ptr()
void* cs_associate_device_ptr ( void *  host_ptr,
size_t  ni,
size_t  size
If the host memory is already associated with the device, the existing device pointer is returned. Otherwise, a new device allocation is called and returned.
[in]host_ptrhost pointer
[in]ninumber of elements
[in]sizeelement size
pointer to allocated memory.
◆ cs_check_device_ptr()
cs_alloc_mode_t cs_check_device_ptr ( const void *  ptr)
If separate pointers are used on the host and device, the host pointer should be used with this function.
allocation mode associated with pointer
◆ cs_copy_d2d()
void cs_copy_d2d ( void *  dest,
const void *  src,
size_t  size
This function should be usable on subsets of arrays allocated on the host and device.
[out]destpointer to destination data on host
[in,out]srcpointer to source data on device
[in]sizenumber of bytes to prefetch
◆ cs_copy_d2h()
void cs_copy_d2h ( void *  dest,
const void *  src,
size_t  size
◆ cs_copy_h2d()
void cs_copy_h2d ( void *  dest,
const void *  src,
size_t  size
[out]destpointer to destination data on device
[in,out]srcpointer to source data on host
◆ cs_disassociate_device_ptr()
void cs_disassociate_device_ptr ( void *  host_ptr)
If the host memory is shared with the device (i.e. using CS_ALLOC_SHARED), device memory stays shared.
◆ cs_free()
void cs_free ( void *  ptr,
const char *  var_name,
const char *  file_name,
int  line_num
Compared to , this function also allows freeing memory allocated through BFT_MEM_MALLOC / bft_mem_malloc.
[in]ptrpointer to free
[in]var_nameallocated variable name string
[in]file_namename of calling source file
[in]line_numline number in calling source file
◆ cs_free_hd()
void cs_free_hd ( void *  ptr,
int  line_num
◆ cs_get_allocation_hd_size()
size_t cs_get_allocation_hd_size ( void *  host_ptr)
allocated memory size, or zero if not allocated with this mechanism.
◆ cs_get_device_id()
int cs_get_device_id ( void  )
currently available device id, or -1 if none is available.
◆ cs_get_device_ptr()
void* cs_get_device_ptr ( void *  ptr)
If memory is not allocated on device yet at the call site, it will be allocated automatically by this function.
[in]ptrpointer
pointer to device memory.
◆ cs_get_device_ptr_const()
const void* cs_get_device_ptr_const ( const void *  ptr)
[in]ptrpointer
◆ cs_get_device_ptr_const_pf()
const void* cs_get_device_ptr_const_pf ( const void *  ptr)
If separate pointers are used on the host and device, the host pointer should be used with this function. In this case, it is assumed that the host and device values have already been synchronized, unless memory is not allocated on device yet at the call site, in which case it will be allocated automatically by this function.
[in]ptrpointer
◆ cs_get_n_allocations_hd()
int cs_get_n_allocations_hd ( void  )
current number of host-device allocations.
◆ cs_malloc_hd()
void* cs_malloc_hd ( cs_alloc_mode_t  mode,
size_t  ni,
size_t  size,
int  line_num
This function calls the appropriate allocation function based on the requested mode, and allows introspection of the allocated memory.
If separate pointers are used on the host and device, the host pointer is returned.
[in]modeallocation mode
◆ cs_prefetch_d2h()
void cs_prefetch_d2h ( void *  ptr,
size_t  size
This function should only be used on arrays using shared host and device memory, shuch as those allocated using CS_ALLOC_HOST_DEVICE_SHARED. It should be usable on a subset of such an array.
[in,out]ptrpointer to data to prefetch
◆ cs_prefetch_h2d()
void cs_prefetch_h2d ( void *  ptr,
size_t  size
◆ cs_realloc_hd()
void* cs_realloc_hd ( void *  ptr,
size_t  ni,
size_t  size,
int  line_num
This function calls the appropriate reallocation function based on the requested mode, and allows introspection of the allocated memory.
If the allocation parameters are unchanged, no actual reallocation occurs on the host.
If the device uses a separate allocation, it is freed, and a new allocation is delayed (as per initial allocation) so as to invalidate copies which will not be up to date anymore after the associated values modification.
[in]ptrpointer to previously allocated memory
◆ cs_set_alloc_mode()
void cs_set_alloc_mode ( void **  host_ptr,
If the allocation mode is different from the previous one, the associated memory will be reallocated with the desired mode, and the previous allocation freed.
[in,out]host_ptrpointer to host pointer to modify
[in]modedesired allocation mode
◆ cs_sync_d2h()
void cs_sync_d2h ( void *  ptr)
If separate allocations are used on the host and device (mode == CS_ALLOC_HOST_DEVICE), the host pointer should be passed to this function.
Depending on the allocaton type, this can imply a copy, data prefetch, or a no-op.
This function assumes the provided pointer was allocated using CS_MALLOC_HD or CS_REALLOC_HD, as it uses the associated mapping to determine associated metadata.
[in,out]ptrpointer to values to copy or prefetch
◆ cs_sync_h2d()
void cs_sync_h2d ( const void *  ptr)
Depending on the allocation type, this can imply a copy, data prefetch, or a no-op.
[in,out]ptrhost pointer to values to copy or prefetch
◆ cs_sync_h2d_future()
void cs_sync_h2d_future ( const void *  ptr)
If separate pointers are used on the host and device, the host pointer should be used with this function. In this case, synchronization is started (asynchronously if the allocation mode supports it).
In other cases, synchronization will be delayed until actual use. the host pointer should be used with this function.
