1 #ifndef __CS_GWF_SOIL_H__ 2 #define __CS_GWF_SOIL_H__ cs_gwf_soil_model_t
Predefined hydraulic model of soils used in the groundwater flow module.
Definition: cs_gwf_param.h:256
time step descriptor
Definition: cs_time_step.h:64
int cs_gwf_get_n_soils(void)
Get the number of allocated soils.
Definition: cs_gwf_soil.c:240
double m
Definition: cs_gwf_soil.h:129
void cs_gwf_soil_set_shared_properties(cs_property_t *abs_permeability, cs_property_t *soil_porosity)
Set the definition of the soil porosity and absolute porosity (which are properties always defined)...
Definition: cs_gwf_soil.c:928
void() cs_gwf_soil_update_t(const cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_zone_t *zone, cs_gwf_soil_t *soil)
Generic function to update the properties related to a hydraulic model given the soil model...
Definition: cs_gwf_soil.h:74
bool cs_gwf_soil_all_are_saturated(void)
Check if all soils have been set as CS_GWF_SOIL_SATURATED.
Definition: cs_gwf_soil.c:357
Main structure to handle a soil in the groundwater flow module.
Definition: cs_gwf_soil.h:145
void cs_gwf_soil_saturated_set_property(cs_property_t *moisture_content)
Definition: cs_gwf_soil.c:980
cs_gwf_soil_free_param_t * free_model_param
Definition: cs_gwf_soil.h:237
double precision, dimension(ncharm), save alpha
Definition: cpincl.f90:99
int zone_id
Definition: cs_gwf_soil.h:220
const short int * cs_gwf_soil_get_cell2soil(void)
Get the array storing the associated soil for each cell.
Definition: cs_gwf_soil.c:611
void cs_gwf_soil_iso_update_itpf_terms_incr(const cs_time_step_t *ts, cs_gwf_two_phase_t *mc)
Update arrays associated to the definition of terms involved in the immiscible two-phase flow model...
Definition: cs_gwf_soil.c:1317
Structure to handle the modelling of miscible or immiscible two-phase flows in a porous media...
Definition: cs_gwf_priv.h:331
void cs_gwf_soil_update(cs_real_t time_eval, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Update the soil properties.
Definition: cs_gwf_soil.c:1055
Definition: cs_defs.h:512
int id
Definition: cs_gwf_soil.h:219
void * model_param
Definition: cs_gwf_soil.h:232
int abs_permeability_dim
Definition: cs_gwf_soil.h:228
double abs_permeability[3][3]
Definition: cs_gwf_soil.h:229
cs_gwf_model_type_t
Definition: cs_gwf_param.h:118
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
void() cs_gwf_soil_free_param_t(void **p_param)
Generic function to set free the parameter structure associated to a soil.
Definition: cs_gwf_soil.h:91
void cs_gwf_soil_tpf_set_property(cs_gwf_two_phase_t *mc)
Set the definition of some property(ies) in specific situations for the two-phase flow models This re...
Definition: cs_gwf_soil.c:1017
cs_gwf_soil_t * cs_gwf_soil_by_name(const char *name)
Retrieve a soil structure from its name.
Definition: cs_gwf_soil.c:275
double scale
Definition: cs_gwf_soil.h:130
double n
Definition: cs_gwf_soil.h:128
cs_gwf_soil_t * cs_gwf_soil_by_id(int id)
Retrieve a soil structure from its id.
Definition: cs_gwf_soil.c:256
cs_gwf_soil_model_t model
Definition: cs_gwf_soil.h:231
void cs_gwf_soil_set_user(cs_gwf_soil_t *soil, void *param, cs_gwf_soil_update_t *update_func, cs_gwf_soil_free_param_t *free_param_func)
Set a soil defined by a user-defined model.
Definition: cs_gwf_soil.c:898
cs_gwf_soil_t * cs_gwf_soil_create(const cs_zone_t *zone, cs_gwf_model_type_t hydraulic_model, cs_gwf_soil_model_t model, cs_property_type_t perm_type, double k_abs[3][3], double porosity, double bulk_density, void *hydraulic_context)
Create a new cs_gwf_soil_t structure and add it to the array of soils. An initialization by default o...
Definition: cs_gwf_soil.c:436
Structure to handle the Van Genuchten-Mualen model of soil.
Definition: cs_gwf_soil.h:106
void cs_gwf_soil_build_cell2soil(cs_lnum_t n_cells)
Build an array storing the associated soil for each cell The lifecycle of this array is managed by th...
Definition: cs_gwf_soil.c:564
double bulk_density
Definition: cs_gwf_soil.h:226
const double * cs_gwf_soil_get_dual_porous_volume(void)
Get the array storing the dual volume weighted by the soil porosity Array of size n_vertices...
Definition: cs_gwf_soil.c:697
void cs_gwf_soil_set_genuchten_param(cs_gwf_soil_t *soil, double theta_r, double alpha, double n, double L)
Set a soil defined by a Van Genuchten-Mualen model.
Definition: cs_gwf_soil.c:855
void cs_gwf_soil_check(void)
Check that at least one soil has been defined and the model of soil exists. Raise an error if a probl...
Definition: cs_gwf_soil.c:379
Definition: cs_defs.h:316
double tortuosity
Definition: cs_gwf_soil.h:131
void cs_gwf_soil_free_all(void)
Free all cs_gwf_soil_t structures.
Definition: cs_gwf_soil.c:709
void cs_gwf_soil_log_setup(void)
Summary of the settings related to all cs_gwf_soil_t structures.
Definition: cs_gwf_soil.c:764
Definition: cs_gwf_soil.h:222
Definition: cs_defs.h:513
double residual_moisture
Definition: cs_gwf_soil.h:126
void cs_gwf_soil_iso_update_mtpf_terms(cs_gwf_two_phase_t *mc)
Update arrays associated to the definition of terms involved in the miscible two-phase flow model...
Definition: cs_gwf_soil.c:1101
cs_flag_t cs_property_type_t
Definition: cs_property.h:117
void cs_gwf_soil_iso_update_itpf_terms_incr_submesh(const cs_time_step_t *ts, const cs_cdo_connect_t *connect, cs_gwf_two_phase_t *mc)
Definition: cs_gwf_soil.c:1446
cs_real_t cs_gwf_soil_get_saturated_moisture(int soil_id)
Get the saturated moisture for the given soil id.
Definition: cs_gwf_soil.c:305
double porosity
Definition: cs_gwf_soil.h:227
void * hydraulic_context
Definition: cs_gwf_soil.h:223
void cs_gwf_soil_iso_update_itpf_terms(cs_gwf_two_phase_t *mc)
Definition: cs_gwf_soil.c:1184
cs_gwf_soil_update_t * update_properties
Definition: cs_gwf_soil.h:236
void cs_gwf_soil_build_dual_porous_volume(const cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect)
Build an array storing the dual volume associated to each vertex taking into account the porosity of ...
Definition: cs_gwf_soil.c:631
int cs_gwf_soil_get_permeability_max_dim(void)
Retrieve the max dim (aniso=9; iso=1) for the absolute permeability associated to each soil...
Definition: cs_gwf_soil.c:325
